Potential Project Truck
Discussion in '1st Gen. Tacomas (1995-2004)' started by JohnDavid, Nov 16, 2011.
  1. Nov 16, 2011 at 7:38 PM
    JohnDavid
    JohnDavid [OP] Active Member
    Martinsburg, WV
    02 Tacoma TRD
    100% Stock
    So recently I was afforded the opportunity to turn my Tacoma into an off roader/weekend driver/project truck. For the time being, I plan to use it as an around the farm truck...go get a load of firewood, buck season starts next monday in WV so hopefully a trophy buck will need to be retrieved from the field next week, etc.
    It is a 2002 4x4 TRD with 252k on the clock. Aside from the herculiner I recently laid down, it is 100% stock. Since I bought it from my dad, I have babied it. My dad never did any of the needed preventative maintenance for the first 200k. I have changed the timing belt, water pump, t-stat, diff fluids, t-case fluid. My dad never even greased the u-joints on the driveshafts!!
    Anyways, back in June, I was rear-ended and thought the truck was headed to the grave. Frame was bent, driverside of bed was bent up like an accordian, bed pushed up into the cab...$6500 worth of body and frame later...I have a shiny repaired truck. I drove it for a few more months, and it just doesnt do well on the interstate anymore. Its hard to control, engine seems to have a shimmy in it since the wreck, and a couple other things. Overall, it is still a good truck and I want to keep it around for a long time because I know how good these trucks are...this is my 2nd tacoma and 4th out of 5 toyotas i have owned overall.
    I need some ideas on what I could potentially do to my truck. Im open to almost anything, while keeping in mind the truck will be used for trips to 84Lumber/Lowes, hauling firewood, gravel, furniture, etc. Any ideas would be appreciated.
    Attached are some pics of the truck. The first pic was taken the day I got her back from the body shop after the wreck. I had the fender flares painted to match. 2nd pic is of my tacoma and tundra in the rare Oct. snow we got a few weeks ago. 3rd was from the wreck.
  2. Nov 16, 2011 at 7:45 PM
    dayNnite4
    dayNnite4 We can't stop here, this is bat country.
    Nick
    Southern NH
    '11 4x4 5-speed AC
    long travel suspension!!!
  3. Nov 16, 2011 at 7:49 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    no SAS it!
  4. Nov 16, 2011 at 7:54 PM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    X2
    Did they replace the frame or just repair it?
  5. Nov 16, 2011 at 7:55 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C, OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; aFe POWER Magnum FLOW Pro DRY S Air Filter; NSB-AGM27F Battery w/Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Cooper Discoverer A/T3s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; MetalMiller TRD Skid; jsi's Locker Anytime & ramonortiz55's Always on Power Outlet Relay Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades (RallyLights Harnesses, Osram 85/80W H4 & Flösser 90W H11 Bulbs); mattgecko's Underhood Lighting; ND4's Fog Light Anytime Mod; Interior & Reverse LEDs; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; 4Runner 4X4 & FJ Fog Light Switches; Husky Floor Liners; UltraGauge EM; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Toyota Bed Extender; Pop & Lock Power Tailgate Lock; ARE Z-Series Cap, SolarGard Tint; BlendMounted BEL Vector 995; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Get it right-side-up before you do anything... :laughing:
  6. Nov 16, 2011 at 7:57 PM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
  7. Nov 16, 2011 at 7:58 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Breaks, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    It's a shame to have to turn a truck with $6500 in bodywork into a farm only truck. With that being said, if you no longer feel it to be a safe highway vehicle, and you plan on using it for serious payloads, the first thing I would do, assuming the springs are good, would be look into a helper spring set up or even air bag set up to even the load for gravel and firewood. Keep in mind, it's not a full sized truck. Just make sure you can stop the truck with any serious amount of weight in the bed. There is a video on here somewhere of a stock single cab 4x4 that is used on the farm only and it does really well. If you plan on doing serious off road, then you can spend as much as you can afford and probably want more. You can do so much to these trucks and be able to drive it on the street legally or go nuts and have a trailer rig. Like the commercial says, "What's in your wallet?"
  8. Nov 16, 2011 at 8:01 PM
    JohnDavid
    Martinsburg, WV
    02 Tacoma TRD
    100% Stock
    dayNnite & fireturk...I definitely had those 2 options in mind while starting this thread
    kmok...the frame was not replaced, just straightened as much as possible by the repair shop. My local Toyota dealer had applied the protective coating approx. 2 years ago.
    Norton...yeah my bad, I forgot to rotate before uploading
  9. Nov 16, 2011 at 8:09 PM
    Norton
    I couldn't help my sarcastic response. :eek:
    That said, I have to agree with Monkeysuncle's initial thought, it's a shame to relegate the truck to "project" status. Have you had the alignment checked? What about getting the shop that did the work to "make it right"? (Aside from high miles and minimal preventative maintenance before the wreck, I understand it drove/road well. Assuming that's the case, it SHOULD drive/ride correctly now that the insurance company invested $6500 to "fix" it...)
  10. Nov 16, 2011 at 8:10 PM
    JohnDavid
    Martinsburg, WV
    02 Tacoma TRD
    100% Stock
    Monkey...Luckily the other guy's insurance picked up the tab for the repairs and a 2011 Ram 1500 rental to drive for the 30 days it took the body shop to repair. The entire suspension could be replaced...shocks/struts are def. shot, leaf packs will need to be replaced, as well as the coils, bushings, ball joints, tie rod ends, and so on. Like I said before, my dad had it for the first 200k and replaced absolutely nothing. When you drive it, you can def. tell almost all components of the suspension need replaced.
    The truck will stay as is til after the holidays. I just want to get a plan in place so I can start on it once spring time rolls around. Thanks for the info!
  11. Nov 16, 2011 at 8:22 PM
    JohnDavid
    Martinsburg, WV
    02 Tacoma TRD
    100% Stock
    No problem! I picked up on your facetiousness! The body shop did a thrust force alignment before I picked it up. I got up under it and took measurements as best as I could...rail to rail across, diagonally from the front of the bed to rear, from ground to bottom of rails, etc. Everything checked out fairly well. It could just be in my head that it doesnt drive right! The truck will get used but in no way abused even as a farm truck/hauler. I like to think I take pretty good care of my vehicles.
