Potential stupid question about oil leak
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 08Scrambler, Apr 6, 2021.
  1. Apr 6, 2021 at 5:21 PM
    08Scrambler
    08Scrambler [OP] Member
    2019 Gray SR Double Cab
    Still fairly new here. Have a 2019 SR double cab but haven't done anything to it yet. Been on covid work from home detail for the last year so its only got 11,000 miles on it too.
    I did a search first and did not find what I was looking for.
    Got the oil changed a week ago and have a few small drops of oil in the driveway after driving since.
    Took the air dam off(truck looks better without it) and dropped the skid plate. Nice puddle inside the skid plate, a little on the filter housing, and a little on the oil drain plug. Cleaned everything and still getting a few drops of oil after driving the truck.
    The potentially stupid question is this: Can I remove the oil filter housing (draining that first) without draining all of the engine oil from the pan/sump? Not good with all the terminology.
    I just want to check that the o-rings are in place and that the filter housing wasn't overtightened but dont want to have to drain all the new oil.
    One good thing to come from this is that I realized I can get under the truck without jacking it up, and will be changing the oil myself from now on.
    Thanks for any info.
  2. Apr 6, 2021 at 5:23 PM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Novice tech spilled it all over the skid. $100 an hour labor at that.
  3. Apr 6, 2021 at 5:29 PM
    2016Tacoman
    J
    You can put a large piece of newspaper between the skid and filter at night, pull it out in the morning and see if it's dripped. That way you don't have to wait til it runs from the skid which would be a while.
    shakerhood, whatstcp and Junkhead like this.
  4. Apr 6, 2021 at 5:32 PM
    ksimms92
    ksimms92 Well-Known Member
    Kevin
    West of Chicago
    2020 Silver TRD OR DCLB 4X4
    When you buy a new filter it usually comes with a little plastic thing that screws into the metal filter cover and allows the oil to drain out the bottom of the cover before removing the cover itself. As long as you do this, it shouldn’t be too messy when removing the cover to check those o rings. But you’ll obviously need to replace the oil that has drained out so it’s at the proper level again.
  5. Apr 6, 2021 at 5:34 PM
    NC_Pinz
    NC_Pinz Well-Known Member
    North Carolina
    2018 Cavalry Blue TRD Pro
    To clarify the post above, yes you can pull the filter and replace o-rings without draining the oil in the pan. You are just losing oil from the filter housing itself.
    Skidog1, Capespencer68 and ksimms92 like this.
  6. Apr 6, 2021 at 5:38 PM
    08Scrambler
    Thanks for all the replies so far!
    I thought I would be able to pull the filter and only lose the oil that was in the filter housing. I have seen those plastic pieces mentioned, and was also looking at the MotivX filter wrench and drain hose. That drain hose looks like it just does the job a little cleaner than the plastic that comes with replacement filters.
    Whizard likes this.
  7. Apr 6, 2021 at 5:39 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    If you drop the filter you'll only lose the oil in the filter housing , maybe 1/2 qt..
    I'd just clean it up and monitor it
  8. Apr 6, 2021 at 6:17 PM
    2016Tacoman
    J
    I wonder how many techs at the dealer use that ?
    I had a white Tundra oil changed at the dealer once.
    About a quart of oil on the skid blew all over the undercarriage.
    Messy handprints all over the hood etc.
    Total bs.
    shakerhood likes this.
  9. Apr 6, 2021 at 6:20 PM
    ksimms92
    Kevin
    West of Chicago
    Not sure, my guess is they have something better. Maybe with a hose to a container?
  10. Apr 6, 2021 at 6:23 PM
    MJTH
    MJTH PretenderLander
    Joe
    Colorado-Westslopebestslope
    19 OR- Land Yacht, w/ fireplace
    Had the same thing happen twice with my free toyota oil changes.
    Clean it and monitor
  11. Apr 6, 2021 at 9:44 PM
    4×4×4
    4×4×4 Well-Known Member
    I'd be surprised if it was anything more than spilled oil heating up and dripping down.
  12. Apr 7, 2021 at 12:52 AM
    Whizard
    Whizard Member
    Richard
    2021 Tacoma SR Supert White V6 4WD Auto
    None Yet
    FWIW - Recently picked up the MotivX kit(wrench, adapter w/drain hose, and funnel) and changed the oil on my 2021 SR @1700 miles. Well worth the $60 for the kit.
    Capespencer68 likes this.
  13. Apr 7, 2021 at 1:07 AM
    BK68
    BK68 Well-Known Member
    Like others have said Tech splattered oil all over the place. IMO take it back to where you had service, be respectful and ask for the manager and explain what's going on. If they correct their error and clean up the mess then I would return to them, if not find a new servicer for your truck.
    JaxJacket and bulalo like this.
  14. Apr 8, 2021 at 7:12 AM
    Capespencer68
    Capespencer68 Well-Known Member
    Scott
    Massachusetts
    2021 DCSB AG Trail edition
    Just picked up a 2021 3.5L. Amazon and Motivx both say it’s not for the 2021, I’m assuming both sites are not updated that’s all. Does yours fit? What was your Motivx part number?
  15. Apr 8, 2021 at 7:33 AM
    b3itz
    b3itz Camp Life
    Northern KY
    2016 MT OR DCSB
    Tuned, geared, armored, BP51s...
    This is the most helpful thing i've read all week... thanks!
  16. Apr 8, 2021 at 9:16 AM
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    It will fit.
    Capespencer68[QUOTED] likes this.
  17. Apr 8, 2021 at 9:25 AM
    SRBenjamin
    SRBenjamin Well-Known Member
    Benny
  18. Apr 8, 2021 at 10:53 AM
    Whizard
    Whizard Member
    Richard
    None Yet
    This is the one I got and it said the same thing(that it wouldn't fit). Worked like a champ. This is a quality product.
    Kit contains :
    Motivx Tools MX2320
    MX2341 oil filter drain tool
    MX2301 threaded oil funnel for Toyota and Lexus vehicles
    https://www.amazon.com/gp/product/B0791MWXDC/ref=ppx_yo_dt_b_asin_title_o01_s01?ie=UTF8
  19. Apr 8, 2021 at 11:10 AM
    Capespencer68
    Scott
    Massachusetts
  20. Apr 8, 2021 at 11:16 AM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
