Pounding the rear axle into place!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mainmoe02, Aug 27, 2015.
  1. Aug 27, 2015 at 7:46 PM
    Mainmoe02
    Mainmoe02 [OP] Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    Had the driver side rear wheel bearing replaced along with the axle seals. When I got the truck back it had dent marks on the outer edge of the axle hub. I removed the drum and jacked up the rear axle and turned the engine on and now I can see a slight wobble when the axle rotates on the driver side.
    I get the feeling that when the mechanic inserted the axle shaft back into the axle housing he must have hammered it into place instead of fitting it into place. Should I be worried about the differential gears?
    I'm now looking for a new rear driver side axle shaft and they are hard to find. I was wondering if any other axle shafts would fit my 2001 double cab Tacoma prerunner (no abs) w/ 4.10 gear ratio? Would a 2nd or 3rd gen 4Runner axle work? Or....?
  2. Aug 27, 2015 at 7:53 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Um make them fix it ..
  3. Aug 27, 2015 at 7:56 PM
    Mainmoe02
    Moe
    Austin, Texas
    It was a mobile mechanic who said "it was fine when I test drove it" so he's claiming no responsibility
  4. Aug 27, 2015 at 8:00 PM
    anthony250f
    Anthony
    San Diego, CA
    Threaten to take it to court
