pounds thrust vs. hp
Discussion in 'Boating & Fishing' started by especk, Aug 31, 2011.
  1. Aug 31, 2011 at 4:30 PM
    especk
    especk [OP] Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    I'm getting a little jon boat here shortly and want to throw a little motor on there. I'm not looking at anything too fancy. It will be for doing some fishing in lakes and maybe some rivers.
    So my question here is, how will an electic trolling motor (something like 55lb thrust or 80lb thrust) compare to a 2.5hp outboard? My main concern is if the electric trolling motor will provide enough power for a 10' jon boat. Approximately how fast would each of the electric motors go? Approximately how fast would a 2.5hp move the boat?
    Thanks guys! I dont know a lot about this stuff.
  2. Aug 31, 2011 at 4:46 PM
    fishntaco
    fishntaco Well-Known Member
    Josh
    Mobile Al
    08 Silver Streak DCLB Prerunner Sport
    I would go with the gas motor. You will triple your range over the trolling motors and achieve 10-11 mph.
    With the trolling motor you would be lucky to achieve 3-4(right around walking speed).
    Also,if you're trying to go up current with the trolling motor, good luck.
  3. Aug 31, 2011 at 4:51 PM
    especk
    Erik
    Redding, CA
    fishntaco, thanks for the info! and what is a good brand for that size motor? Mercury, honda, yamaha? and what is an estimated price I should expect to pay for one?
    edit: and wouldnt the 80lb thrust motor move the boat quite a bit faster than the 55lb?
  4. Aug 31, 2011 at 5:12 PM
    fishntaco
    Josh
    Mobile Al
    I would recommend the yamaha for the motor. We had three of them and put over 1000hrs on them with 0 problems.
    As far as price you should be able to find one for 8-900 dollars.
    Thrust does not necessarily equate to more speed. Prop size and pitch play a much larger factor in either acceleration or top speed. The 80 would probably be a little faster just because it has a little bit larger prop but not enough to make a difference.
  5. Aug 31, 2011 at 8:19 PM
    especk
    Erik
    Redding, CA
    thanks! i just got off the phone with one of the dealerships and they said the 80lb thrust motor would be too heavy because it takes 2 batteries. I may just go with a 55lb thrust for now and then get a 2.5hp later and use the 55lb as a troller. I'll look into Yamaha. Thanks for your help.
    And if anyone else has any input, that would be appreciated.
  6. Sep 1, 2011 at 3:28 AM
    tonto340
    tonto340 Well-Known Member
    Gambrills, MD
  7. Sep 3, 2011 at 12:08 AM
    Maverick904
    Maverick904 Resident Fishing Expert
    Kameron
    Northeast Florida
    08 TRD Rugged Trail 4x4
    3" Procomp Lift, BDF Light Bar, Borla Stainless Cat-Back System, 2 10" Polk MM Subs, LED Interior Lighting, Pioneer Touch Screen, Kicker Speakers up front, Sonys in the back, Grillcraft grill, 20% tint, Weathertechs, Projector Retrofit Headlights. BHLM
    Yamaha or Mercury....stay farr farr farr away from anything else.
    Me personally..love my yamaha..always have. always will.
    Plus my sisters dad works with one of the top yamaha mechanics in the south east :D
  8. Sep 3, 2011 at 12:12 AM
    4x4jeep
    4x4jeep Well-Known Member
    Kyle
    Destin FL.
    Yamaha only!
  9. Sep 8, 2011 at 10:21 PM
    especk
    Erik
    Redding, CA
    I am about to buy a new Yamaha 6hp (or maybe the 4hp). But my little boat is only rated to 3hp max. What would happen if I put the bigger motor on? (The 4hp and the 6hp weigh the same)
