POWDER COAT RIMS
Discussion in 'Arizona' started by reddot53, Aug 27, 2013.
  1. Aug 27, 2013 at 3:47 PM
    reddot53
    reddot53 [OP] Member
    Tucson
    2008 access cabTRD 4x4
    3" toytech lift, upgrade Bilstein shocks/add a leaf plus TSB leaf/upgrade coils
    I live in the SE side of Tucson - anyone aware of or have contact info for powder coating? I'm interested in having my rims powder coated on my '08 Tacoma 4x4.
    Any info would be of great help...THANKS!
  2. Aug 27, 2013 at 3:58 PM
    Infra
    Infra Well-Known Member
    Az
    2010 MGM DCSB 4x4 TRD OR 6spd
    CBI Bushmaster 2.0 rear bumper with swing out tire carrier & fold down camp table, CBI Moab 2.0 front bumper, Warn M8000-S, Icon 2.5 RR CDC Extended travel CO's with 700lb springs, Icon 2.5 RR CDC rear shocks, Icon hydro bumps, Total Chaos uniball UCA's, All Pro Expo leafs, U-bolt flip kit, Softopper, diff breather mod, extended rear brake lines, Grillecraft mesh grille, Elusive Elements behind grille light bar with B.A.M.F. LED light bar brackets, okLEDlightbars.com 20" double row LED light bar, Relentless Fabrication hood cb antenna mount, Wilson Silver Load CB antenna, Uniden 520 Pro XL CB radio, Wet okole seat covers, Weather tech floor liners, Weather tech in channel window deflectors, trasharoo spare tire trash bag carrier, Box Rocket 2nd gen bed rack with (2) 2 gallon gas rotopax mounted on drivers side, (2) 2 gallon water rotopax mounted on passenger side, (1) 3 gallon gas rotopax & (1) 2 gallon gas rotopax mounted on CBI swing out, Avid weld on sliders, Mattgecko LED bed light
    Anderson Painting has powder coated a few different items for me. They are on S. Country Club I believe
  3. Aug 27, 2013 at 7:10 PM
    reddot53
    Tucson
    Thanks for the info. Must be okay if they've powder coated a few items for you.
    Thanks again and I'll look'em up.
  4. Aug 27, 2013 at 7:56 PM
    bueller
    bueller Well-Known Member
    AZ
    All Valley Powder Coating. He's on the NW side of the valley but travels all around town (hence the name). He does all of our PC on our custom motorcycles and I just saw a set of wheels he did on a Lambo. I don't think he's listed though. If you're interested, I can PM you his info.
  5. Aug 28, 2013 at 2:30 PM
    reddot53
    Tucson
    Absolutely! Thanks for the info.! I've researched the cost of rims but i can't justify it. I'm also unwilling to keep saving a lot longer...money is tight but I can afford powder coat - I hope. THANKS AGAIN!
  6. Aug 28, 2013 at 3:05 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Im pretty sure a member here in Az does it as well. His username is Infamous Coating.
  7. Aug 28, 2013 at 6:37 PM
    JuansTaco
    JuansTaco JuanInAMillion
    Juan
    gilbert az
    2004 PreRunner SR5 stormtrooper
    ESB long travel kit, Deaver f67s with DTF 12 inch shackles.
    ya his name is chris i beleive. does some amazing work. ive seen a couple cars he has done and they look sweet
  8. Aug 28, 2013 at 7:16 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Yeah ill probably be going to him for my center caps and rings.
