Powder Coated Bed Brackets, Ready to Ship
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KB Voodoo, Feb 10, 2014.
  1. Feb 10, 2014 at 11:25 AM
    KB Voodoo
    KB Voodoo [OP] Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    We've tried aluminum and stainless steel, and they were ok.......but powder coated steel is the BEST.
    I have a new powder coating guy, so production times should be more consistent.
    PM for pricing and shipping quote. I respond right away
    Here is the original thread with lots of customer pic's: http://www.tacomaworld.com/forum/2nd-gen-tacomas/273017-bed-brackets-pic-heavy.html
    And my pic's....
    Here is a map that breaks down shipping costs:
    Zone 0 - $18
    Zone 1 - $15
    Zone 2 - $18
    Zone 3 - $25
    Zone 4 - $18
    Zone 5 - $25
    Zone 6 - $25
    Zone 7 - $25
    Zone 8 - $25
    Zone 9 - $25
  2. Feb 11, 2014 at 4:45 PM
    SCOTTRODS
    SCOTTRODS JAFO
    Scott
    Garland, TX
    2014 Super White
    Probbly be a good idea to post "how to buy them" in this thread as well.
    I'm really interested... Just not gonna go hunt through the other thread to find out and *maybe* get the right info to get some... Pricing might be a good idea too since there are a few itterations of them... I remember reading that you were changing to aluminum, and now back to steel sounds less expensive than stainless... Just sayin'
    They look great. Might buy if the price is right. At least one bar if not 2.
  3. Feb 11, 2014 at 5:03 PM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Aluminum was way too much work to buff each one.
    Same with stainless.
    Steel cuts the best with my plasma table, and cleanup is easy, then the powder coat guy does the rest.
    Powder coated steel looks the best too. It's a textured coating, so it matches the bed nicely.
    I changed the first post to include how to obtain pricing.
  4. Feb 11, 2014 at 5:31 PM
    williams63
    williams63 Well-Known Member
    chili
    nh
    2011 dblcb
    boss-c/o, boss rear leafs
    payment sent
  5. Feb 17, 2014 at 1:28 PM
    Germ
    Germ Master Navigator/Zipper Operator
    Arizona
    2013 TRD OR DCSB
    Man those are sharp. Wish I had a use for a set. Glws.
  6. Feb 17, 2014 at 5:55 PM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    If you ride bikes, ski or snowboard, fish, hunt, or camp, there's a ton of uses.
  7. Feb 20, 2014 at 4:34 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    This is becoming a popular setup:
  8. Feb 20, 2014 at 4:18 PM
    williams63
    chili
    nh
    2011 dblcb
    came in today and look great. thanks KB these will work great for a few different things I have planned
  9. Feb 24, 2014 at 8:33 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Sweet!!
    Post pic's of your setup once you get it all done.
  10. Feb 24, 2014 at 3:42 PM
    Reel Tuff
    Reel Tuff Well-Known Member
    Gary
    western Pa.
    2014 tacoma sport DC
    Wet okoles,weather tech digital mats,Tacoma bed mat and stage II light kit, LP & 3rd brake
    pm sent
  11. Feb 24, 2014 at 5:42 PM
    williams63
    chili
    nh
    2011 dblcb
    I will post pics when im done. I will be using them for the skis and bikes like in your pics and also will try making some kind of set up for my fishing rods when spring gets here.
  12. Feb 25, 2014 at 9:20 AM
    ThomasMore66
    Dallas/Fort Worth & Durango
    I've scanned the last thread and I may have missed it, but I need somebody to explain to me the slot system. My Thule ski racks are designed to go over the bar on a typical luggage rack. Are you guys removing some parts to fit it through the slot?
  13. Feb 25, 2014 at 9:26 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    It's simple. If you have a rack that can be bolted, you would use the slots to bolt them in.
    If you have a rack that clamps onto a luggage style rack, you would just clamp it around the brackets without using the slot.
  14. Feb 25, 2014 at 9:28 AM
    ThomasMore66
    Cool. I was trying to remember all the pieces on my rack. Need to go home and look at it.
  15. Feb 25, 2014 at 8:19 PM
    kjmahoney85
    kjmahoney85 Member
    NY
    13 DCSB TRD Off Road
    Tried to PM you, not showing up as sent. Could you please send pricing info to kjmahoney85@gmail.com? I am interested in a pair shipped to 10950. Thank you.
  16. Feb 25, 2014 at 8:42 PM
    outxider
    outxider Never stop exploring. Rest in Paradise Big Bro.
    Sang
    East Bay, CA
    06 DCSB 4x4
    A few mods here and there and counting....
    The Thule snowboard rack and other variants will bolt to these bed bars with ease. I use these bars year around. Bikes in the summer and snowboards in the winter. Superb product.
  17. Feb 26, 2014 at 5:00 PM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    :kona::kona::kona::kona::kona:
  18. Mar 4, 2014 at 10:03 AM
    skotsour
    skotsour Member
    Northwest Indiana
    2013 TRD Sport Access Cab
    Just installed mine, looks like it will be super handy. I should've ordered two, but I will order another one very soon. Thanks!
  19. Mar 9, 2014 at 9:00 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Post pic's when you put them to use!!
  20. Mar 13, 2014 at 11:01 AM
    Skinny Rogers
    Skinny Rogers U know fish can hear u thinking just b4 u sneeze
    Lance
    NC
    10 taco
    What r y'all guys using to hold ur snowboards/skis? R there certain ones that work only?
