Powdercoating
Discussion in 'Wheels & Tires' started by youngmc, May 3, 2013.
  1. May 3, 2013 at 9:53 AM
    youngmc
    youngmc [OP] Well-Known Member
    Do the stock wheels on a 2006 TRD need to be blasted before having powdercoating? Any help would be greatly appreciated. Thanks
  2. May 3, 2013 at 10:13 AM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    wow good question, I'm looking to have a set of PC'd myself and was wondering the same thing!
    also how much should PC cost per rim? I got quoted $90ea which seams like an aweful lot..
  3. May 3, 2013 at 10:19 AM
    Me Likey TRD
    Me Likey TRD Well-Known Member
    Stan
    Eastern Oregon
    2012 TRD Sport DCSB
    Toytec Ultimate w/Dakar leaf packs, Michilin 265/75/16 LTX AT2, FJ Trail Team replica wheels, Access Ltd bed cover, Katzkin leather, Brute Force rear bumper, Relentless Fab front bumper, Beefed sliders
    A reputable powder-coater should blast them as a part of their coating service.
    Now, if there's a prior coating that's difficult to remove, they may charge you a bit more. But a existing clean surface should not be a problem.
  4. May 3, 2013 at 11:01 AM
    youngmc
    We have a real nice facility down the road that will coat them for 25 a wheel, but they don't do the blasting there. Either way they are half to a third of the price as most other powdercoating shops. Just needed to know if I needed the blasting.
  5. May 3, 2013 at 11:07 AM
    TIPICOTACO
    Tyler
    nw nj
    $25 each !!!:eek: where is this place??
  6. May 3, 2013 at 11:57 AM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    It would be best and wise to sand blast anything that's going to be powdercoated. Most shops that quote you will often include the price of sand blasting, but be sure to check with them first.
  7. May 3, 2013 at 12:02 PM
    Toyotacrawler
    Toyotacrawler She's got the jimmy legs
    Cusseta/Opelika AL
    2010 Tacoma DC TRD Sport
    5100's set to 1.75" Wheelers 3 leaf progressive AAL & 5100's for the rear Konig Countersteer Offroads K&N Drop in WeatherTech's Bed Mat Blacked out Badges Rear leaf TSB
    X2
  8. May 3, 2013 at 12:23 PM
    JdMeF9SiR2
    JdMeF9SiR2 FN Wheels
    Corona, CA
    05 Tundra 06 Tacoma 14 FJ Cruiser 19 Tundra
    Definitely have the wheels sand blasted prior to powder coating. The powder coat will not stick well if you don't.
    You can also have the wheels "dipped" or acid washed.
    Some powder coaters will tell you that just hand sanding the wheels first is acceptable. I'd still pay the extra cost for sand blasting to ensure that adhesion is not an issue.
    I'd also make sure that the powder coater doesn't allow paint to get on the backside of the hub (have them mask it off). You don't want paint built up between the wheel and the hub.
