power drain?
Discussion in 'Audio & Video' started by LBtaco, May 7, 2009.
  1. May 7, 2009 at 11:39 PM
    LBtaco
    LBtaco [OP] Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    Today I installed an Alpine PDX 5 and a JL sub in my truck. Hooked it to a AVIC 900 and only running the sub on the amp. Install went real easy and there didn't seem to be any issues untill I drove to the store. The truck seems to be idling lower than usual, almost wanting to stall it seems. Driving at speed normally it was fine. So, I pulled the fuse on the amp power wire and it all runs good now.
    I imagine since I have an 05 it may be my battery and/or alternator just showing their age.
    I sure hope its not the alternator but it seems to be pointing that way.
    I'm going to pull it out this weekend and have it tested.
    Anyone else have this problem?
  2. May 8, 2009 at 10:24 AM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    If you've never swapped your battery and are still running the original one that was manufactured in 2005.. then yes, that could very well be the issue.
    You could also have a weak ground on the amplifier. Make sure that the metal you've attached it to is bare and clean (of paint, oil and other residue).
  3. May 8, 2009 at 11:11 AM
    LBtaco
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    yeah it could be the battery. the ground should be nice n tight and is on clean bare metal. I'll double check and go look for batteries too.
  4. May 8, 2009 at 3:09 PM
    LBtaco
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    well, I got a Optima yellow top and all is well again. After testing the old stock battery, it showed a big drain under load, but the check light was green. So, the new amp potentailly saved me by showing my old battery was failing. Is there anything Rock and Roll cant fix? :rockband:
