Power for CB /GMRS Radio
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mr. Excitement, Aug 9, 2022.
  1. Aug 9, 2022 at 9:10 AM
    Mr. Excitement
    Mr. Excitement [OP] Well-Known Member
    J
    Custom floormats, fuzzy dice
    Hey Guys,
    I've looked a round a bit, but haven't found what i'm looking for. Curious if anyone has hard wired their radio? I know a lot of people use the accessory power cigarette lighter adapter, but I kinda hate having wires all over the place. Do you guys have a clean solution for wiring up a radio to accessory power? Would you just run it right to the fuse block? Sorry for the dumb question, but figured some of you would have the answer. Thanks
  2. Aug 9, 2022 at 9:48 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    I ran mine straight to the battery. With a fuse of course.
    NmapFE, Holling and MR E30 like this.
  3. Aug 9, 2022 at 9:50 AM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    I ran a fuse expansion tap from ignition. My CB and my 2 way are hard wired
  4. Aug 9, 2022 at 9:50 AM
    MR E30
    MR E30 Well-Known Member
    Michael
    Wherever it's parked
    2021 Silver TRD OR DCLB w/ AluCab and All the Mods
    Same
    snakeplissken likes this.
  5. Aug 9, 2022 at 9:56 AM
    Mr. Excitement
    J
    So its on all the time unless you turn it off? I was hoping for something tied to accessories. Maybe I'll try the tap into something off the ignition
    or just deal with the wire. I only use it every few weeks.
  6. Aug 9, 2022 at 9:59 AM
    Technique
    Alex
    Utah
    Correct. You can tap an accessory fuse but it's not an issue with it being wired directly to the battery. I've left it on overnight with no issues.
    I like it being ran to the battery so it gets 'clean' power and mainly so I can use it while the truck is off.
  7. Aug 9, 2022 at 9:59 AM
    Doc62
    Doc62 Well-Known Member
    Dave
    SE Pennsylvania
    2025 Tacoma TRD Off Road i-FORCE Max, 2019 Sahara
    Just remember with newer vehicles, don't go to the battery's ground directly. Tap the ground where the battery's ground connects to the vehicle. I believe it is on the left side just behind the battery.
    Mr. Excitement[OP] likes this.
  8. Aug 9, 2022 at 12:15 PM
    cowfootball
    cowfootball Well-Known Member
    South Lake Tahoe, CA
    2022 TRD OR
    If you search for specific Midland models you'll find a bunch of good threads about this, e.g, MXT575 or MXT275.
    There's basically two schools of thought here:
    • Direct to the battery provides the least interference and best SNR. You risk flattening your battery if you forget to turn it off but it's a pretty slim chance.
    • Wired to an under the hood electrical system, e.g., sPOD or Blue Sea. Potentially more RFI/worse SNR but you get low voltage cutoff protection.
    It really depends how hard you wheel and how much you need comms/what your distance is. I run off my sPOD rather than off the battery directly because I have a lot of faith in sPOD's electrical protection and LVCO and I don't have any interference issues. YMMV.
  9. Aug 9, 2022 at 1:44 PM
    MR E30
    Michael
    Same here. A close friend ran his directly from the battery, no issues. Best part about it is you can leave it on at night, in case you are waiting for someone to join you. You also don't have to power it on each and everytime you turn your truck off. When we adventure we stop all the time to explore. Remembering to power up your radio each time can get annoying.
    Mine is direct wired due to cleanliness of signal. Both of my truck batteries are topped off by solar, so draining the battery is of zero concern to me.
  10. Aug 9, 2022 at 1:53 PM
    Mr. Excitement
    J
    Nice. I just came across some brand new hand held units Midland GTX 1000 vp4 in the used REI store. Not the same range obviously but they will get some use around camp so i don't have to leave the truck on. I can see I'm going to have to finally make the secondary fuse block before all the relays start getting out of control. Or just get something like a switch pro or Spod. Appreciate all the input
  11. Aug 9, 2022 at 2:06 PM
    cowfootball
    2022 TRD OR
    I use one of these and hand’em to folks I do recoveries on if they don’t have their own. Great for coordination with strangers.
  12. Aug 29, 2022 at 10:02 PM
    2013TacoDCLB
    2013TacoDCLB Well-Known Member
    Mark
    2013DCLB4x4
    Military hitch, CB install, cargo rail brackets
    What fuse tap did you guys use 10 amp or 15 amp?
  13. Aug 29, 2022 at 10:25 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    If you want to use the radio when broken down, directly to the battery is the most dependable way to hook it up.
  14. Aug 30, 2022 at 1:45 AM
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    I'm wired directly to the Aux box. GMRS with no issues so far. There are a couple ideas in the video you can use for placement. If you do decide on a radio with a remote box like the MXT275. You could pick up an extension and an RJ45 POE coupler in order to mount the mic connection anywhere in the cab.
    https://youtu.be/8K2gd-WbyzE
    Dtax and Mr. Excitement[OP] like this.
  15. Aug 30, 2022 at 1:57 AM
    Doc62
    Dave
    SE Pennsylvania
    Just remember with most modern cars, the ground should not go directly to the battery.
  16. Aug 30, 2022 at 5:04 AM
    willtill
    willtill Well-Known Member
    Maryland
    2018 Cement Off Road V6 Access cab
    Why is that?
  17. Aug 30, 2022 at 5:07 AM
    willtill
    Maryland
    I pulled the center console and spliced in to the power/negative wire of the accessory power adapter inside of the middle console. I don't use that accessory power adapter anyway.
  18. Aug 30, 2022 at 5:10 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I'm curious to hear this logic as well because it doesn't make any sense. No difference in going directly to the battery or to the body ground that's 5" away. It's all the same ground.
  19. Aug 30, 2022 at 5:20 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I can tell you why I do it. It's because its a waste to fish two wires through the firewall when one will do.
    However, so long as the battery has a sufficient ground cable (it does), I don't see how it endangers the electronics to hook up a direct route. (with the caveat that the ground cable must maintain connection to the battery while hooking up the electronic.) Technically hooking to the negative terminal is still grounded so long as that cable is maintained. It's ugly as hell and is looked down upon, but everything should still be safe.
    :notsure:
  20. Aug 30, 2022 at 6:34 AM
    OnHartung'sRoad
    There’s less of a chance to have electrical interference noises in the radio going directly to battery.
    Mr. Excitement[OP] and vicali like this.
