Power in the glove box for GPS
Discussion in '2nd Gen. Tacomas (2005-2015)' started by COtacoma, May 20, 2012.
  1. May 20, 2012 at 11:52 AM
    COtacoma
    COtacoma [OP] Member
    Denver, Colorado
    2011 Tacoma sport
    K&N CAI, Weathertech, floor liners, Weathertech deflectors, Totec 3" w/ spacers, Center console lock, Helo 17" rims, 285/70/17
    Looking for info on wiring behind glove box for ignition power for new GPS on 2011 tacoma.
    thanks
  2. May 20, 2012 at 5:07 PM
    obscurotron
    obscurotron Well-Known Member
    Bay Area, California
    '14 DCSB 4x4
    That's kind of a broad question.
    Do you want to tap power? If so get an Add-A-Circuit from LittelFuse or one of the the other companies. Run wires from the interior fuse panel (where you add the Add-A-Circuit) to the glove box and call it done.
    You don't want to go cutting and splicing wires behind the dash. It's a recipe for random failure at the Worst Possible Time. I know this firsthand.
  3. May 20, 2012 at 5:56 PM
    COtacoma
    Denver, Colorado
    2011 Tacoma sport
    I will look into the Add-a-circuit, Obscur... I jumped into the instal of the gps and fried the first unit. Got the second one and got it all hooked up through the 12v outlet coming out right beside it. Not as clean as I would like it to be, and don't want to loose that outlet, but works for now until I get more info. Hopefully learned my lesson on this one.
    I was hoping to slice into some power behind the glove box, but a little scared after frying the first unit.
  4. May 20, 2012 at 6:28 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Add-a-fuse is the best way to go.
    Other than the lighter/power outlets, the only power behind the glovebox is the ECU and you don't want to mess with that.
  5. May 20, 2012 at 8:03 PM
    obscurotron
    '14 DCSB 4x4
    If it was me, I wouldn't even bother with the add-a-circuit. I would get a nice Blue Sea fuse box, run power and ground from the engine compartment to the fuse box (fuse the power leads, of course), and then tap a circuit on the Blue Sea for m GPS power. That's how I wired up my 2m/440, CB, spare rear lights and a couple of other things in my old Tacoma. The only thing that did not run through the Blue Sea was my KC's (big mistake).
    It's more work, but it's cleaner and troubleshooting is methodical.
  6. May 20, 2012 at 8:06 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Blue Sea power boxes are awesome, but if you are only adding a couple of accessories, they are overkill.
    Big lights and amps? Ya... much cleaner than a bunch of ATO fuse holders hanging off the battery.
  7. May 20, 2012 at 9:33 PM
    aptech
    aptech Jetfixer
    Adrian
    houston (angleton)
    10 dc offroad
    daystar level kit, tsb rear spring, ghostflames, sport hood, tsb steering, trd cai, red map lights. backup cam any time mod, fog light any time mod. bed light mod. 400watt inverter mod. 2857516 dura tracs. beach sand intsall
    :thumbsup:
