power inverter fitment
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TAC1, Mar 11, 2012.
  1. Mar 11, 2012 at 7:55 PM
    TAC1
    TAC1 [OP] Well-Known Member
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Hello Forum,
    I'm thinking of purchasing the Cobra 800 watt power inverter for my '08 Tacoma Prerunner DC 4.0. My truck does not come with one but I want to put it under the center console where the OEM would go. I will trim the rear cover of the center console so that the outlets are exposed with the cover on. I am hoping that the inverter can fit flush with the console. H 2.75 x W 5 x D 8.5. My questions are:
    Will it fit there?
    Do any of you run use this inverter?
    Are you happy with it?
    Do you suggest any others that will fit there?
    Will it drain the battery when not in use?
    Is it enough for the few times that I will use it, ex. laptop, 13"tv, charging my drill.
    Is it a PITA to install. I was thinking of having Best Buy do the install.
    Please give me your opinions or any info.
