Power Inverter Project
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Twom07, Sep 4, 2017.
  1. Sep 4, 2017 at 3:23 PM
    Twom07
    Twom07 [OP] Well-Known Member
    Ty
    State College, Pennsylvania
    2014 Black Tacoma DoubleCab
    So I'm looking to add a power inverter to my 2014 double cab base model. I removed the console today just to get a look around. I have a factory wire run behind the top right switch blank on the drivers side where the power inverter switch usually is from what I've seen. Would the factory inverter sit under that silver bracket in the picture and connect to that white switch connector towards the top left side? Basically could I plug and play the oem inverter if that's what I wanted to do?
  2. Sep 4, 2017 at 3:30 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    Mine sits as far back as possible in that area. I'm not 100% positive but I remember more than 1 connector going to it.
  3. Sep 4, 2017 at 3:36 PM
    Justinlhc
  4. Sep 4, 2017 at 3:59 PM
    Twom07
    Ty
    yea that helps a bit at least to be able to see the factory power inverter how it's connected and placed. It looks like I could buy the inverter and just plug and play. The other wiring coming out of the converter in that picture I'm guessing goes to the bed outlet? But I'm not sure. This would be the easy thing to do, however I also want to look into adding a larger after market power inverter that has a little more power to it. Anyone have any thoughts on this or experience?
  5. Sep 4, 2017 at 4:04 PM
    medic2230
    Murph
    Bama! Roll Tide
    I would imagine that the bigger inverter will need bigger wiring than the factory provides. My 700watt would need a 4 gauge wire for that run from the battery.
    SOSC likes this.
  6. Sep 4, 2017 at 4:34 PM
    Twom07
    Ty
    Yea I figured if I went with a larger inverter I probably wouldn't use the factory wiring at all. I would still like to put it underneath the console preferably and connect a couple 110 and USB outlets with an external power switch for the converter as well. How I would wire all that up is mainly the part I have trouble with
  7. Sep 4, 2017 at 4:43 PM
    Justinlhc
    Something like this:
  8. Sep 4, 2017 at 4:44 PM
    Justinlhc
    Plug the cord into the inverter and wire it into the outlet.
    Larzzzz likes this.
  9. Sep 4, 2017 at 6:25 PM
    Twom07
    Ty
    Alright that's exactly what I'm looking for what would you call that wire if I were to search for it? How would I wire the switch in to turn the inverter on and off, just wire a switch in between the inverter and the power source?
  10. Sep 4, 2017 at 6:35 PM
    Justinlhc
    Any 120v 3-prong appliance pigtail will work. Home Depot and lowes carry plenty. A switch between the power supply and inverter would be the best.
    OneFastGeek likes this.
  11. Sep 4, 2017 at 9:27 PM
    Muddinfun
    Muddinfun Well-Known Member
    You're not exactly going to run 4 gauge welding cable to a dash switch. Surely the aftermarket inverter has a low current turn on switch. You might have to disect the switch from the inverter though.
    SOSC likes this.
  12. Sep 5, 2017 at 5:19 AM
    Justinlhc
    They make these things called "relays". :cookiemonster:
    Whitetrash likes this.
  13. Sep 5, 2017 at 7:51 AM
    Muddinfun
    Too much current for a Bosch relay. You could probably use one of the constant duty solenoids that look like a Ford starter solenoid.
  14. Sep 5, 2017 at 8:20 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Wire the outlet before plugging into the inverter...
  15. Sep 5, 2017 at 9:20 AM
    Twom07
    Ty
    Yea I'll need to narrow down what inverter I want to get. Is it worth it to invest in a larger one than the 400 watt oem? Any suggestions on a brand to purchase or any particular specs if I go aftermarket?
  16. Sep 5, 2017 at 1:28 PM
    road2cycle
    road2cycle Well-Known Member
    Sonoma County, CA
    2014 Tacoma DCLB 4x4 Limited
    It all depends on what you decide to power with the ac inverter. Personally I have not run into a situation requiring more than 100w while the truck is moving nor 400w while idling so I left the stock inverter power selector as is. I did add an AC usb outlet combo in the cab.
  17. Sep 5, 2017 at 1:49 PM
    Larzzzz
    Larry
    MA
    The cord with the plug is called an appliance cord. Usually available with #14 or #16 AWG wire, 3 or 6 feet long. They got them pretty much at all the home improvement stores
    Stuffing a #4 wire through the firewall grommet will be a challenge I think. I'd consider running the feed along the frame and go into the cab from the grommet under the driver's seat. Some will say, poke a hole in the grommet. I remove the tape and feed my wires in with the rest. Then use scotch 33+ electrical tape to redo the grommet.
    You could also drill a hole in the firewall and use a compression cord connector with a sealing (gasketed) washer. That'll squeeze around the cord and the washer seals the firewall.
    The insulation type should have a W in it. Such as thhw, xhhw. This tells you that the insulation is water resistant, water proof...
    Welding cable is easy to run and is very flexible, but the insulation isn't very tough.
    I think this would work nicely.
    https://www.wireandcableyourway.com/Type-W-Cable/
    Here's a100 amp rated relay.
    https://www.zoro.com/white-rodgers-...eYeKQLf7ywc4d34MiyqXx0VE8GO8XNnxoChM8QAvD_BwE
    However you decide to run your wire, dooooooooon't forget the fuse!
    Any questions, hmu...:thumbsup:
    Justinlhc likes this.
  18. Sep 5, 2017 at 5:20 PM
    bluesguy3
    bluesguy3 New Member
    Rick
    The bed outlet in my 2014 is as road2cycle said, 400w idle, 100w running. unfortunately I need 200w running so I can recharge the battery for my e-bike while driving. It charges fine at idle but I can't justify idling for a couple of hours for that. What should I do?
  19. Sep 5, 2017 at 5:29 PM
    uh_salt_rifle
    uh_salt_rifle High velocity lead dispenser
    Sal
    27203
    2005 Tacoma TRD Sport DCLB
    6" Fabtech lift 295/70 18
  20. Sep 6, 2017 at 4:42 PM
    bluesguy3
    Rick
    It didn't work, BTW its a 2014 automatic tranny. Clarification: rather than adding another interior receptacle, I'm just using the existing bed outlet. I cut and capped both ends of the violet wire w/ white stripe. The green 400w light on the dash switch still goes out and switches to 100w when shifted to drive. Any ideas?
