Power Inverter Wire Size
Discussion in 'Technical Chat' started by SixtyDashOne, Sep 25, 2016.
  1. Sep 25, 2016 at 2:40 PM
    SixtyDashOne
    SixtyDashOne [OP] Well-Known Member
    Collegeville, PA
    2021 ArmyGreen TRD Sport, 2007 Regular Cab 4x4
    hey guys. I have purchased a 1000w /2000w peak power inverter for my truck. I wanted to mount it to the backside of my regular cab, under the rear window. So it should be a fairly long wire run from the rear of the interior to the engine compartment battery.
    I was just curious how to determine what guage wire to run. Since its a long wire run, i wanna make sure i size it right. I also want to run an inline breaker near the battery and i wasnt sure how to size that either lol
    Any help is much appreciated. Thanks guys!
  2. Sep 25, 2016 at 5:00 PM
    SixtyDashOne
    Collegeville, PA
  3. Sep 25, 2016 at 5:21 PM
    caribe makaira
    Caribbean, Puerto Rico
    I'd go #4 on the wire and 120 breaker...
  4. Sep 25, 2016 at 5:24 PM
    SixtyDashOne
    Collegeville, PA
    thanks man.. yeah I figured 2-4awg was about right.. ive read some charts that said I could run 8, but that didn't seem correct whatsoever..
    And I had no idea on the breaker size.. :(
  5. Sep 25, 2016 at 5:27 PM
    medic2230
    Murph
    Bama! Roll Tide
    Doesn't the paperwork in the box tell you gauge size for length of run?
  6. Sep 25, 2016 at 5:28 PM
    SixtyDashOne
    Collegeville, PA
    No i didnt see anything like that :(
  7. Sep 25, 2016 at 5:31 PM
    medic2230
    Murph
    Bama! Roll Tide
    That's odd. My inverter came with a chart on the paperwork showing how far placement from battery was as to how big a wire needed to be run. Mine is a 700 watt and I want to say 6 ft run recommended 4 awg for it.
  8. Sep 25, 2016 at 6:20 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
  9. Sep 25, 2016 at 6:38 PM
    SixtyDashOne
    Collegeville, PA
    Norton[QUOTED] likes this.
  10. Sep 25, 2016 at 8:45 PM
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
    In short, The main fuse/circuit breaker on a wire will always be sized to the total amount of amps the equipment will pull under normal operating loads.
  11. Sep 25, 2016 at 8:58 PM
    SixtyDashOne
    Collegeville, PA
    Thank u sir. I guess what i meant to say was, being that it is an inverter, how can i be sure what kind of amps it will pull if it varies on the load? Thats why i included the 1000w/2000w peak. I will probably never use it for anything crazy but id rather play safe. Hehe
  12. Sep 26, 2016 at 8:18 AM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    Modified sine wave=be careful what you plug into it, it may harm some equipment. Also I would be leary of installing it under a seat. At full capacity it is going to produce a significant amount of heat.
    1000W/12V=83.33A
    I would use #2 wire, good for 10.3' at 90A
    I would use a 100A circuit breaker. 83.33A X 125%=104A
    This is just my advice, you should consult a professional (stereo installer or auto electric tech) #2 cause of car fires are electrical issues.
    Good luck
    Personally I would not buy this unit because it uses a modified sine wave, and it is to large (more heat). Pure sine wave inverters are expensive but worth it IMO.
    medic2230 likes this.
  13. Sep 26, 2016 at 11:14 AM
    SixtyDashOne
    Collegeville, PA
    I appreciate your insight! All notes have been made hehe. I already purchased it. To be frank with u, its mostly an emergency thing. Id be lying if i said id use it regularly. If at all. Lol
  14. Sep 26, 2016 at 2:17 PM
    RobertHyatt
    RobertHyatt You just can't fix stupid...
    Robert
    Birmingham AL
    2007 Tacoma Prerunner SR5
    Ohm's law. watts = volts * amps.
    If you want to know amps, solve the above and you get
    amps = watts / volts. Since voltage = 12.5, to provide 1000 watts of output, you would need 80 amps assuming the inverter is 100% efficient, which is impossible. That's why it has those heat fins on it, to get rid of the heat it produces. Figure 80% efficient, so you will need closer to 100 amps, and that assumes you stop at 1kw of power. If you surge to 2kw, you will need 200 amps. If the wire is too small, you will never get to 2kw of output peak.
    Note that you are NOT going to run 1kw for very long, battery will die. That's why the Toyota inverter is much smaller and also further limits the output if the engine is not running. The stock hi-cap alternator will barely keep up. This is the problem with DC power, you can't step the voltage up with a transformer which reduces the wire size requirement dramatically.
  15. Sep 26, 2016 at 5:40 PM
    chilioil.514
    chilioil.514 Well-Known Member
    2003 Tacoma TRD Prerunner 4-Door
    Prodigy P2, Alpine 235BT, Hayden Aux Trans Cooler, Scan Gauge II
    It's been shown that AC power transmits more efficiently over long distances and that's the reason all power lines transmit AC. Most household components only require DC hence requires a conversion from AC to DC. However, anytime you convert (AC->DC) or invert (DC->AC) there is always loss and heat generated. Most equipment can make this conversion at 80% efficiency of power.
  16. Sep 26, 2016 at 5:42 PM
    chilioil.514
    Agreed. The pure sine wave inverters are less likely to damage your components. I wouldn't use modified sine wave inverters for a $2k Apple laptop.
  17. Sep 26, 2016 at 7:38 PM
    RobertHyatt
    Robert
    Birmingham AL
    This is wrong. A/C works better because it is trivial to step the voltage way up, which steps the current way down (to maintain the same power level). Lower current = smaller wire sizes to transmit same amount of power. I don't know about you, but I don't have any DC motors in my house, except for those that run off of batteries.
    A simple transformer can double the voltage and halve the current, trivially. With A/C. For DC it is a major pain to change the voltage / current. An inverter first converts DC to AC, whether it is a true sine wave or square wave doesn't matter much. Once you have A/C, you can run it through a transformer to step it up to any voltage you want. Simple A/C to A/C voltage-changing transformers still lose a lot of energy to heat. An inverter loses even more.
    As far as damaging things with non pure sine wave power, I wouldn't worry about things with a power brick that step the power right back down in voltage and then rectify it to DC. I wouldn't want an oddball line voltage in significant electronics, but I have run my macbook many times on a cheap inverter without any hitches..
