Power Invertor - External
Discussion in 'Audio & Video' started by BLACKFIREPDX, Oct 11, 2018.
  1. Oct 11, 2018 at 8:22 PM
    BLACKFIREPDX
    BLACKFIREPDX [OP] BlackFire PDX
    2015 TACOMA DBL CAB
    Front BP-51 and rear Firestone airbags
    Anyone install an extra PI in the back of their truck. Going to build a new drawer system and wondered how I could mount a new one in there. I am a photographer and have a drone. So creating a charging station would be helpful.
  2. Oct 12, 2018 at 12:53 AM
    mctechhweng
    mctechhweng Well-Known Member
    Matthew
    2015 TRD Sport V6.
    Audio: Focal PC165, Focal KX2, JL VX800/8i, Pioneer AVIC-8200.
    I saw some guy put one in a toolbox on youtube. Just make sure you fuse the wire you run close to the battery!
  3. Oct 12, 2018 at 5:54 PM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    Good quality wire from the battery to your inverter location (with a fuse/circuit breaker at the battery)
    I personally would recommend a battery isolator right behind the fuse/circuit breaker that is tied to a key'd signal. Power inverters can draw lots of power and unless you have a dual battery setup, you'll kill your starting battery pretty fast. For example, the factory 400w inverter pulls over 12 amps when at peak draw. This amount of power draw is enough to drain your battery below cranking voltage in 2-3 hours. And some of these new drone chargers need some serious power. Same with camera battery chargers.
  4. Oct 12, 2018 at 6:29 PM
    mctechhweng
    Matthew
    2015 TRD Sport V6.
    How do you get 400 Watts with 12 amps in a 12 volt system? That's only 135-168 Watts according to my physics unless the factory 400W inverter isn't actually 400 watts. Maybe Toyota used the wrong ohms law. Just keep in mind if you use a battery isolator that you're going to lose 0.6-0.7 volts from diode drop on the output of the isloator. So you will burn power on the isloation circuitry, but I'll leave it up to you as far as deciding if you care about that power loss.
  5. Oct 12, 2018 at 6:41 PM
    destin_meeks
    Destin
    Tuscaloosa, AL
    I have no earthly idea how I typed 12 lol. I meant 33. Which is why I was saying it’s a ton of power!
    mctechhweng[QUOTED] likes this.
  6. Oct 22, 2018 at 5:50 AM
    Mountain2018
    Mountain2018 Well-Known Member
    Harpers Ferry/Leesburg VA
    2018 4x4 SB gray
    I. Installed a Dewalt 1000w inverter on back wall of my DC that I took seats out of and constructed a carpeted wood rear mounting piece. I mainly use to charge lithium batteries for my cordless air compressor and other tools for various projects. Though I mainly use while running and on the move, this unit has an auto cutout off when the battery is being drained below a certain level.
    Used 6ga wire with a 150amp inline fuse with 12" pigtail from battery. Wire/fuse from InvertersR Us.
  7. Oct 24, 2018 at 11:29 AM
    dualstroke
    dualstroke Well-Known Member
    2017 OR AC
    Following. Great info. Thx
