Power issues since botched water crossing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 06Offroad, Sep 22, 2014.
  1. Oct 3, 2014 at 2:17 AM
    #101
    TacomaRobert
    TacomaRobert Well-Known Member
    Exactly. :bowdown:
  2. Oct 3, 2014 at 5:00 AM
    #102
    06Offroad
    06Offroad [OP] Active Member
    06 TRD Offroad
    K, I've got a good idea where to start.
    -Take filler neck vent apart and blow air bothways at tank connection.
    -Inspect Evap vent hose
    -Research charcoal cannister
    Gotta be honest, I was very careful jacking the tank back up and had bags sealing all hoses and vents on the truck and tank while it was removed. I am not expecting to see kinks/obstructions. I hope im wrong.
    The tank is 100% full now, and by the sounds of it, I will be dropping that f'ing tank again.
    Gunna put some miles on the trail this weekend. That should burn some of that fuel up :)
    Should I cross the river again? I know I can make it!
  3. Oct 3, 2014 at 5:07 AM
    #103
    06Offroad
    06 TRD Offroad
    Oh and as far as electronics go, I think all that is down there is the vacuum pump for the evap.
  4. Oct 3, 2014 at 6:52 AM
    #104
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    I've had pump click off problems off and on at different times and different vehicles. Before you drop your tank I'd;
    - Change gas stations a couple times to see if the gas pump is just too fast.
    - Any chance the evap got soaked and the charcoal inside as well ??
    I'd fill it up at least three times to confirm before I'd go chasing this ...
  5. Oct 3, 2014 at 11:12 PM
    #105
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I think you pretty much got all your potentials posted here. Go crazy OP and before doing anything, try Canufixit's method. I have had the problem on my 12 before as well. The pumps are sometimes way too fast at filling, slowing it down on the lower settings at the same station seemed to resolve the problem. If it keeps doing it then I would go about chasing the demon. If not, don't go chasing ghosts.
