Power lock actuators for shell
Discussion in 'FBC Harness Solutions' started by Jack C, Apr 26, 2023.
  1. Apr 26, 2023 at 11:23 AM
    Jack C
    Jack C [OP] Member
    Jack
    2023 SR Access Cab 2WD
    Hi,
    I have a 2023 SR....
    How many power lock actuators can the factory harness and relay handle? Or, do you have a kit that'll fulfill my request?
    I'd like to run the tailgate and all three shell doors on the OEM fob if possible.
  2. Apr 26, 2023 at 11:25 AM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    You have windoors? Do they come with a single handle? I haven’t seen that yet.
    The pop n lock kits I know of are for the rear glass only. Windoor T handles don’t have any auto lock options.
  3. Apr 26, 2023 at 11:26 AM
    daveeasa
    David
    PNW
    I believe the Oem tailgate lock harness has a fuse at the T inside the passenger kick panel so that much is covered as far as load.
  4. Apr 26, 2023 at 11:32 AM
    Jack C
    Jack C [OP] Member
    Jack
    No windows, single flush t handle on all doors. It's a Leer shell but I haven't received it yet so I'm not sure if it's predrilled for power locks on the sides.
    I'll look up the fuse and draw per popper, I'm hoping not to have to create some sort of diode harness to run relays.
  5. Apr 26, 2023 at 11:37 AM
    daveeasa
    David
    PNW
    I don’t think the actuators have massive draw. The one thing you might want is milspec from the T to minimize resistance if you’re branching to 3 actuators. Beyond that, I’d try and see. If you can. Would be convenient to lock everything up at once.
