Power locks wont lock from keychain
Discussion in '2nd Gen. Tacomas (2005-2015)' started by craigstr, Oct 17, 2010.
  1. Oct 17, 2010 at 2:56 PM
    craigstr
    craigstr [OP] New Member
    Craig
    Reno NV
    06 Tacoma LB Double Cab
    My power locks in my 06 Tacoma Double Cab wont lock from the keychain remote. The will unlock fine, I tried my spare remote and I have the same problem. I checked the fuse too. I have rea don here that it could be an actuator but why would they unlock? Any help would be appreciated.
  2. Oct 17, 2010 at 4:23 PM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4R MGM TRDOR Premium Daddy Wagon
    You are probably in a area that has a lot of RF Interference going on. This used to happen at one of my friends house so i had to use the key. But when I got home it worked fine. I suspect this could be the same thing. Try it in a little while and you may be good.
  3. Oct 17, 2010 at 4:25 PM
    JAG
    JAG Well-Known Member
    One time this happened to me and one of the doors was ever so slightly open.... make sure the doors are all closed good.
  4. Oct 17, 2010 at 4:40 PM
    outlawtacoma
    W. TN
    probably not if both of them arent working.
  5. Oct 17, 2010 at 4:42 PM
    AlaskaTacoma
    AlaskaTacoma Well-Known Member
    Shane
    Tempe
    TRD The Good Stuff
    6000K HIDs w/Fogs Smoked Tail lights Window Tint Dual Exhaust Sockmonkey Decal's Billet Grille Wet Okole Seat Covers Tacomaworld.com Sticker :) Painted Engine Cover Ultragauge WeatherTech Floor Mats
    I had the same problem, I just bought a new one.[​IMG]
  6. Oct 17, 2010 at 4:51 PM
    Nick Sells
    Nick Sells Well-Known Member
    Elgin, South Carolina
    2016 TRD Off Road
    Bone Stock
    I blame aliens bro
  7. Oct 17, 2010 at 4:53 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Do they lock from the switch on your armrest?
  8. Oct 18, 2010 at 7:41 AM
    craigstr
    Craig
    Reno NV
    Thanks! Rear driver's side door was being blocked by the strap from my laptop case, it looked closed but wasnt!
  9. Oct 18, 2010 at 7:54 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    I hate that. My rear pass. door is harder to close and sometimes people don't shut it all the way and I have the same issue. Glad the truck let me know.
  10. Oct 18, 2010 at 2:02 PM
    JAG
    Anytime! Thats what were here for.
    Welcome to TacomaWorld.
