Power loss help!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco2525, Oct 3, 2017.
  1. Oct 3, 2017 at 6:53 PM
    Taco2525
    Taco2525 [OP] Well-Known Member
    Los Angeles
    2009 access cab trd-offroad 4x4
    Whatsup guys I need help! So I'm having what I assume to be some sort of fuel system issue. So this is a situation I was put in when I noticed it. I was going up a decent size hill let's say in second gear about 10mph floored it and absolutely nothing happened. It slowly revs down and then eventually will just stall out. Another thing I noticed let's say I'm going up a slightly elevated street I release the clutch in first and let the truck roll the truck revs down pretty low and just about stalls out before I push the clutch in so it won't. Most other trucks I've been in will steadily pull forward. Thanks for reading any opinions would be greatly appreciated. I have already cleaned the maf tried the fuel injector cleaner you out in the gas tank. Leaning towards fuel pump or filter. Thank you. 2009 6speed 4x4 a little over stock tire size 275/70
  2. Oct 3, 2017 at 7:59 PM
    5678ta
    5678ta Well-Known Member
    Hogan
    Henderson, NV
    '18 ECLB Colorado ZR2
    Just throwing it out there but maybe your throttle body is taking a poop. Could be losing connection or shorting. I've had mine just give out. Cruising then drops to idle. Get a scanner on there to measure the TPS signal and simulate what you are doing.
    Its quite possibly the fuel filter. Its easy to replace and good general maintenance on its own.
  3. Oct 3, 2017 at 8:32 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    No check engine light ( CEL )?
  4. Oct 4, 2017 at 4:04 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Sounds like a malf throttle position sensor.
  5. Oct 4, 2017 at 4:49 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    What is a malf throttle position sensor.?
    Do you mean MAF Sensor ( Mass Air Flow Sensor )? If so that is entirely different than the Throttle Position Sensor.
  6. Oct 4, 2017 at 6:55 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    malf(unctioning) tps
    wheeliest likes this.
  7. Oct 4, 2017 at 7:49 AM
    Taco2525
    Los Angeles
    No check engine light and I had it hooked up to a computer last week no codes gonna try again tho
  8. Oct 4, 2017 at 7:54 AM
    wheeliest
    wheeliest ///////////////////
    Json
    TMPE AZ
    05-SWB-DCSB-4X4-V6-SR5-SPORT
    NO SWAYBAR, Spacer lift with dirty4's
    you need to watch TPS. This truck is Drive-By-Wire which means your input on the gas pedal is just telling the ECU how much gas you want to give it rather than actually opening up your throttle.. If you have a failing Throttle position sensor (TPS) your truck will not "open up"
  9. Oct 4, 2017 at 8:55 AM
    Taco2525
    Los Angeles
    If that the case tho how does it let it open up the throttle when it flattens out/ is under way less load?
  10. Oct 4, 2017 at 8:55 AM
    Taco2525
    Los Angeles
    But I will also look into that
  11. Oct 4, 2017 at 8:58 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    OMG. Really?
    Kids...
  12. Oct 5, 2017 at 7:49 AM
    wheeliest
    Json
    TMPE AZ
    What?
  13. Oct 5, 2017 at 7:57 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    TPS report?
  14. Oct 5, 2017 at 8:04 AM
    Taco2525
    Los Angeles
    If the tps was having issues it would throw a code tho right and my check engine light would stay on?
  15. Oct 5, 2017 at 9:07 AM
    wheeliest
    Json
    TMPE AZ
    doubt it.
  16. Oct 5, 2017 at 1:52 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I was referencing the fact that a poster used "malf" as an abbreviation for malfunctioning.
    The English language is doomed. Three quarters of Americans cannot spell or speak a complete proper sentence. It is sad. :(
    blu92in99 and Bigbunzilike like this.
  17. Oct 5, 2017 at 1:55 PM
    wheeliest
    Json
    TMPE AZ
    Actually, its a well known acronym. You just live under a rock.
    EatSleepTacos likes this.
  18. Oct 5, 2017 at 2:00 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    No, It isn't a well known acronym. Fuck, it isn't even an acronym.
    Acronym = an abbreviation formed from the initial letters of other words and pronounced as a word (e.g., ASCII, NASA ).
    Thanks, you made my point exactly.
  19. Oct 5, 2017 at 2:03 PM
    gnicks08
    gnicks08 Well-Known Member
    Garrett
    Cullman, Alabama
    2012 DCSB TRD OR 4x4
    In his defense, I've never seen anyone use "malf" in place of malfunctioning either, but also him thinking 3/4 of Americans can't spell or speak a proper sentence doesn't exactly speak much to his credibility lol.
  20. Oct 5, 2017 at 2:05 PM
    wheeliest
    Json
    TMPE AZ
    i'm in the aerospace MFG (That's manufacture jimmy lol) career field and I've seen it plenty. Fucking engineer's are so stoopid
    gnicks08[QUOTED] likes this.
