Power loss on hill in 4H, manual trans.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by vroomvroom_19, Aug 26, 2021.
  1. Aug 27, 2021 at 6:55 AM
    usmc2msu
    usmc2msu Well-Known Member
    TJ
    2017 SR5
    I cannot believe the MT has a fault...I'll take this rare opportunity (like the MT guys do on auto trans posts) to say I can go up steep inclines in 2H with no issues. All in fun. :rofl:
  2. Aug 27, 2021 at 7:00 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    ATs are different. The torque converter would be open (unlocked) in this situation and acts as a very high loss torque multiplier. So, the engine can spin at a higher rpm (more torque) than a locked up MT.
  3. Aug 27, 2021 at 7:02 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The Taco MTs certainly have faults. The clutch accumulator, the tall ratio reverse gear, a 6th gear that could be a bit taller, the lack of feel in the clutch, clanging from the friction plate, the same desperate need for a tune, and some other stuff.
  4. Aug 27, 2021 at 7:03 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Correct!
    OP, were you riding the clutch (letting it slip) to get in a better/stronger RPM range?
    tonered[QUOTED] likes this.
  5. Aug 27, 2021 at 7:06 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Agreed that it just sounds like normal manual things. This is why I'm usually in low range offroad so I don't have to constantly ride the clutch. If this driveway is a normal occurrence, it sounds like the 2 low mod is your friend. It will allow you to take advantage of the lower gearing but remain in 2wd so you don't get any binding on pavement.
    Or just hit it in 2hi and maintain a little speed up it.
    cryptolyme and tonered like this.
  6. Aug 27, 2021 at 7:06 AM
    dnlskier
    dnlskier Well-Known Member
    17' TRD SPORT MT
    Picture of driveway OP?
    My driveway is long and somewhat steep where I need 1st gear to get up it.
    tacotoe likes this.
  7. Aug 27, 2021 at 7:09 AM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Has anyone suggested taking a run at it?
    tacotoe, tcjacado and whatstcp like this.
  8. Aug 27, 2021 at 7:19 AM
    mynameistory
    mynameistory My member is well known
    Tory
    Redondo Beach, CA
    4Runner
    This one. 3rd gen trucks have been known to have oil build up in the valve covers and seep into the valves if left on an incline long enough.
    Kev250R[QUOTED] likes this.
  9. Aug 27, 2021 at 7:20 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    What's that smell?
    whatstcp likes this.
  10. Aug 27, 2021 at 7:31 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    While I haven't had the chance to drive an MT Tacoma, I have driven many, many MT compact pickups, and other vehicles. This description does NOT sound 'normal' in any way.
    OP: You've done this before many times I assume, and this time was different?
    What sort of RPM were you showing?
  11. Aug 27, 2021 at 7:37 AM
    mauctopa
    mauctopa Well-Known Member
    Off roading with MT is hard as hell as there's no power over obstacles when crawling. Have to ride the clutch alot....
    Chew likes this.
  12. Aug 27, 2021 at 7:50 AM
    Sasquatchian
    Sasquatchian Well-Known Member
    When I still had my '93 Toyota 3.0 5-speed, I had a photo shoot way up in Laurel Canyon in the Hollywood Hills where the driveway was so steep that I had to drive up to the security gate, get them to open the gate, then back down the hill into a neighbor's driveway to get a running start and because there was a sharp bend in the paved hill you couldn't use low-range. The owner's told me that many delivery trucks simply could not make it to the top. So, yes, there are driveways that steep. Maybe some of them are on purpose. Who knows. On the other hand, these folks had a giant picture window from the living room into their swimming pool.
    tonered likes this.
  13. Aug 27, 2021 at 8:17 AM
    dr4g1116
    dr4g1116 Well-Known Member
    2019 Silver Sky Metallic TRD OR SB M/T
    This thing is gutless but MAN that must be a steep hill. I had a similar situation once but I was towing a few thousand pounds. Really steep driveway that I wanted to get all the way up but straight up couldn't without absolutely smoking the clutch. So I just left it at the bottom and prayed the ebrake and the transmission wouldn't let it roll away.
  14. Aug 27, 2021 at 8:26 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Very strange my 2011 has none of those problems. Maybe because I have only been driving a stick for 60 years and I'm not used to a stick yet.
  15. Aug 27, 2021 at 8:28 AM
    #35
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Welcome to the 3rd Gen section. Great input. Keep it coming.
    Chew, Kev250R, Pablo8 and 1 other person like this.
  16. Aug 27, 2021 at 8:28 AM
    #36
    NorrinRadd
    NorrinRadd Well-Known Member
    WA
    2019 Sport, access cab, MT, Eibach 2.0 stage 2, tow, silver.
    Just takes skillz..
    INSAYN likes this.
  17. Aug 27, 2021 at 8:32 AM
    #37
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    OP later that day
  18. Aug 27, 2021 at 8:35 AM
    #38
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That one never gets old.
    :cheers:
  19. Aug 27, 2021 at 8:40 AM
    #39
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
    :worthless:
    tacotoe, Pablo8, PzTank and 1 other person like this.
  20. Aug 27, 2021 at 8:49 AM
    #40
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The manual has a better crawl ratio than the automatic
    02Duck, Kev250R and tonered like this.
