Power Loss & Vibration
Discussion in '4 Cylinder' started by rtg34, May 13, 2010.
  1. May 13, 2010 at 2:31 PM
    rtg34
    rtg34 [OP] Member
    Hull
    2005 4cyl
    Hello,
    I have a 2005 2wd 4cyl auto reg cab Tacoma with 65K on the engine. About 2 months ago I would periodically lose power @ 20mph-50mph with slight vibrations occuring in those speeds. Recently it has gotten worse with stronger vibration, and it happens between 20mph-65mph.
    I changed the air filter.
    Changed the plugs, and checked for spark. There is spark
    Cleaned the throttle body.
    checked all hoses.
    I noticed a slight vaccum coming from the exhaust. The exhaust needed to be forced out w/the gas pedal down, otherwise I could barely feel it.
    I'm thinking either:
    clogged catalytic converter
    egr valve
    Thanks in advance for any suggestions!
  2. May 13, 2010 at 10:10 PM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    Welcome to TW. Run some SeaFoam through your engine. Maybe that can help.
  3. May 13, 2010 at 10:12 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    Try this I think it will help you determine if the problem lies in the engine or in the cats
  4. May 20, 2010 at 3:00 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    aFe Pro Dry air filter, magnetic oil drain plug, synthetic seat covers, steering wheel cover
    Is it just me or does this sound wrong to everyone else too? I understand the exhaust to be a one-way pipeline from cyl port to tailpipe and there should be no way no how there is ever a vacuum in the exhaust. ??? /????
  5. May 21, 2010 at 8:47 AM
    rtg34
    rtg34 [OP] Member
    Hull
    2005 4cyl
    The exhaust is not sucking back up into the engine. When i put my hand over the pipe I can barely feel it coming out. I put my hand over the pipes of 2 other vehicles and there was a big difference between them and the tacoma.
  6. Jun 15, 2010 at 10:03 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Loss of power is a symptom of a blocked or obstructed exhaust. Your engine can't breathe if it can't exhale.
    If you can, pull the pre-cat o2 sensor and check pressure.
  7. Jun 15, 2010 at 10:07 AM
    OCTaco
    OCTaco Well-Known Member
    OC
    '16 TRD Sport DCSB
    02 sensor
