Power Loss w/ 35's???
Discussion in 'Suspension' started by ahigginsdeca, Dec 31, 2008.
  1. Dec 31, 2008 at 7:22 PM
    ahigginsdeca
    ahigginsdeca [OP] Higgins
    Alex
    Fort Collins, CO
    08 TRD shortbed
    3" Revtek Suspension Lift with a rear aal, 285/70/17 Pro Comp Xtreme M/T & Pro Comp Extreme Alloy 7189 wheels, magna flow exhaust, CB with dual antennas, AFE Cold Air Intake, CB Radio with dual antennas and a bull horn
    I have a 3" revtek lift with 33's and was fine with the little bit of power loss I experienced, but now I'm thinking about moving up to the 6" with 35's. Can anyone tell me what i can expect with a lift and tires of that size?
  2. Dec 31, 2008 at 7:24 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    from a 3 inch lift to a 6 with 35's...you'll probably have a good bit that you can tell of a loss. regear and you should be fine!
  3. Dec 31, 2008 at 7:26 PM
    ahigginsdeca
    Alex
    Fort Collins, CO
    08 TRD shortbed
    how much is it to regear?
  4. Dec 31, 2008 at 7:31 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    that i have no idea man! im imagining somewhere around $650 or so.
  5. Dec 31, 2008 at 7:44 PM
    AUDITECH
    AUDITECH Carolina Alliance: LAZY DIVISION
    charlotte nc
    07 double cab prerunner
    none
    unless you put a lower gear the bigger or wider the tire the more it will take to move it and stop it.
    If you go big tires
    1 regear the drive axles
    2 expect gas milage to go down
    3 need better breaks
  6. Dec 31, 2008 at 8:00 PM
    Alaskaflyer
    Alaskaflyer My other ride Hovers
    Cape Cod, MA
    08 Prerunner DC TRD Off Road
    OME 885 AAL, 2.5* shim, Light Racing UCA's. BFG AT KO 285/75/16, Spidertrax spacers, OME Shocks up front, Bilstein 5100 Shocks in back.
    Depends on if you are 2wd or 4wd. The gears themselves aren't usually expensive, it's the labor to install them correctly. I'd call a reputable shop and ask them. I would guess anywhere from 500 to 1000, again depending on if you require front and rear or just rear.
  7. Dec 31, 2008 at 8:18 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    x2... and a big one for better brakes... :D
  8. Dec 31, 2008 at 8:19 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yep.....good rotors and pads, or bigger rotors and pads/calipers will be even better!!
  9. Jan 1, 2009 at 3:43 PM
    nighthawk87
    nighthawk87 Well-Known Member
    If you wanted such a big truck, why didn't you just buy the Tundra or a full size. I don't get the guys that lift a compact truck so much. Why make a compact truck big? Isn't that contradictive?
  10. Jan 1, 2009 at 3:49 PM
    RedTaco2134
    RedTaco2134 Well-Known Member
    Scott
    Portland, Or
    08 Long Bed TRD Sport
    285/70/17 Goodyear BFG KM2's, Revtek 3" lift. TSB rear and Blistein 5100's http://www.cardomain.com/ride/3097063
    That is the Cheapest I have ever heard of!! Almost everywhere around or in Portland, Oregon costs $950-$1,200. That is front and rear.
    If you go with 6", 35's re-gear. ASAP once its all installed, or "Goodnight, Automatic Transmission". If you have an Auto that is..
  11. Jan 1, 2009 at 4:02 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    well, that was just a guess i had..........as i have never regeared anything, so im not sure.
