power loss with ac
Discussion in '4 Cylinder' started by Yota1, Jul 21, 2011.
  1. Jul 21, 2011 at 6:02 PM
    Yota1
    Yota1 [OP] Well-Known Member
    So this little 4 banger seems to lose more power than any other ride i have had with the ac on, especially if on MAX.
    From a stop, it feels as if i am half throttle and shes is just over 1200 rpm, and sounds like she is under a huge load. At any speed in any gear if you give try and accelerate she feels like i am trying to climb the largest hill in a gear to high.
    Its like the motor wont gain any rpms fast enough, as if the peddle response is super slow.
    I am due for my 15k which will be my last dealer service anyways, so i might have them check it out, just wondering if anyone else notices this issue.
  2. Jul 21, 2011 at 7:32 PM
    o5iiawah
    o5iiawah Well-Known Member
    Tim
    Philly 'burbs, PA
    '11 4x2 access cab 2.7l
    Your freebie dealer services should go until 25k. That should be part of the national toyotacare program.
    i live in FL and hot is a way of life... most vehicles will have impacted performance with the AC on. Have you tried running the blower on halfway with the cooling on 3/4 cold? I find its just as cold and the truck seems to run happier.
  3. Jul 21, 2011 at 8:50 PM
    TacomaBuzz
    TacomaBuzz Well-Known Member
    CT
    2014 RegCab 4x4 TX Special Edition
    Sirius, Bugflector,back-rack, stepsides.
    You read my mind, I was going to post the same thing, I have noticed a huge loss of power with the AC on "Max". if the AC is off, the power is great. I'm glad that I'm not alone here.
  4. Jul 21, 2011 at 8:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Along with the mechanical drag from the compressor, the higher fan speeds, and the current to hold the AC clutch engauged, can create a bit of a loss. Add to this the less amount of O2 in the hotter air, and you can have a significantly reduced feeling of power, when compared to driving with the AC off, and in cooler ambient temps.
  5. Jul 21, 2011 at 9:07 PM
    TacomaBuzz
    CT
    Ah, thanks chris, I used to have the 4.0L Tacoma and i barely noticed a loss when the AC was on "Max". Any tips or mods to inrease power while still being able to run the AC??
  6. Jul 21, 2011 at 11:46 PM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    super charger! would do the trick:)
  7. Jul 22, 2011 at 12:45 AM
    chad68
    chad68 Master Jedi Member I am...
    Chad
    In a (Toyota) van down by the river! Sonoma Cownty
    2009 4x4 reg cab. Modded with more to come
    Polished 16x8 Pro Comp 1069's 4" BS Nitto Mud Grapplers 305/70/16 Magnaflow & glasspack muffler Stainless tip K&N 63 series Aircharger Vent visors Autometer volt and dig. temp. gauge custom mounted Factory chrome rear bumper (not black factory, one) TRD pedal covers TRD skid plate Hurst T handle shift knob Rear Tint Clear bra on the sides Chrome extinguisher Icon non resi coilovers, ICON RR shocks, black seat covers. And some other crap
    I don't look at it that way at all OP.
    I drive with the AC on all year long. When I'm flooring it, I flip the AC off and it's just like hitting a NOS switch!
    When that AC gets flipped off, hold on man cause it will throw you back into the seat.
  8. Jul 22, 2011 at 10:10 AM
    Yota Toy
    Yota Toy Taco Sauce
    FX retros, Blazer fog-light retro, JVC KW-NT30HD head unit, Pioneer 6X9's in front doors, Pioneer 6.5's in rear doors, two Pioneer 12" subs in sealed boxes, Sony X-Plod amp, Hidden Hitch trailer hitch, EGR window visors, two PIAA low-tone horns, Westin light bar with two 100-watt KC low profile driving lights.
    I have seriously considered connecting an A/C cutoff switch triggered by the manifold vacuum level (we have no throttle-plate access with throttle-by-wire). I would like the A/C to just cut off at 90% or more throttle and turn back on as soon as I lift. Many cars already have this, not sure why Toyota elected not to, especially on the 4-cylinder...
  9. Jul 22, 2011 at 11:14 AM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    that sounds like a solid idea! although until chris 4x4 chimes in i suggest no one takes apart their ac system just yet lol.
  10. Jul 22, 2011 at 11:40 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It already does under WOT.
  11. Jul 22, 2011 at 5:33 PM
    Yota1
    at least my gas mileage is decent, even if i can beat and old man on a bike off the line from a red light. in all seriousness i am no newbie to the parasitic loss of ac, just i have never had it this bad.
    time for a tundra i thinks......... actually i am considering it anyways
  12. Aug 4, 2011 at 9:10 AM
    wmdpowell
    wmdpowell Well-Known Member
    Bill
    Essex county NY
    23 trd OR DCSB 4x4 silver
    a cross on my rearview Circle mirror Scotch guard seats
    Normal as far as I can tell.
    Not too worried about a little loss of power as most any car can take off faster than me anyways,
    I rarely put fan on full (I try to keep a little in reserve 'just in case').
    Old AC units used to get stinky if you didn't air out for the last few mile with ac off. I still do that by habit.
    The manual says to make sure recirculate is off if you have been running ac then park. That makes sense, let the air circulate in the ducts.
  13. Aug 9, 2011 at 10:18 AM
    andy2003
    andy2003 Well-Known Member
    Andy
    WV
    16 4Runner SR5
    Average for all vehicles the ac unit can use up to 11hp.
  14. Aug 10, 2011 at 10:20 AM
    billwot
    billwot Well-Known Member
    Eastern NC
    '11 Access 4 cyl auto SR5
    Correct.The ECU disengages the compressor clutch under WOT conditions.
    bill
  15. Aug 14, 2011 at 7:23 AM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    2011 4x4 AC. Its like two different trucks. Great without ac on no issues with enough power. With the ac on its a dog.
  16. Aug 26, 2011 at 9:53 AM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    you also have to realize your driving a 4 cylinder. most 4 cylinders will have this affect with a/c on. 6 cylinder guys hardly feel the loses due to having more power avaiable from the get go. we have very little to start with so any loses will be very noticable.
    curious if an electric vs clutch driven fan would help any with the overall lag?
  17. Jun 27, 2012 at 7:17 PM
    LDurchy
    LDurchy Well-Known Member
    Cedar Falls, Iowa
    Consider too, here in Iowa a hot day can also be a humid day. Internal combustion engines don't perform as well with humid air to burn. Of course, a 4 popper has less in reserve anyway as previously stated by other members. So when you want the cold the most, it is also most taxing on your whole system.
  18. Sep 23, 2013 at 8:32 PM
    airlandsea
    airlandsea New Member
    Syracuse, NY
    2013 Access Cab 2.7 5sp.
    2013 4 cyl. I have significant power loss when not only turning on the A/C but also when I just turn the fan to high without A/C. I realize that with any vehicle especially a 4 cyl. you will notice loss of gumption when turning on A/C but I do not think that I should see lights dim and feel significant decrease in power when just turning on fan for defrost or fresh air.
  19. Sep 23, 2013 at 10:07 PM
    2007 tacoma
    2007 tacoma Well-Known Member
    LEEEEEEROOOYYY JENKINS!
    2007 Access Cab
    16" Alloys, K&N intake, Class III Hitch, US Truck Cap Rack, Carpeted Bed Mat, WeatherTechs, SeatSaver covers, Many more in the works
    You need to take your truck in for service. You may have a short somewhere. That could equal a fire hazard.
