Power outlet added (with pics)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TAC1, May 27, 2012.
  1. May 27, 2012 at 12:03 PM
    TAC1
    TAC1 [OP] Well-Known Member
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Hello Forum,
    I just added a power outlet on the panel behind the center console of my '08 Prerunner DCSB 4.0. I used an add-a-circuit & plugged it into the original fuse location of the front 2 outlets. I had previously done the "power all the time mod" so now all 3 of my outlets have constant power. As per the instructions, one of the 2 slots on the add-a-circuit is for the original fuse in that location & the other slot is to fuse the accessory that is being installed.
    It also says not to use more than 10 amps but the person who installed my rear view mirror with built in compass used the fuse that powers the 4WD, which I don't have, but it has a 20 amp fuse. The rear view mirror fuse is either 4 or 5 amps.:)
    http://i1056.photobucket.com/albums/t379/TACRUN1/Photo1063.jpg
    http://i1056.photobucket.com/albums/t379/TACRUN1/Photo1064.jpg
  2. May 27, 2012 at 1:08 PM
    lowrange
    lowrange Supreme Commander of the Army of the Tacoma
    Joe
    Are Can Saw
    15 TRD Sport
    Looks nice. Clean install.
  3. May 27, 2012 at 1:15 PM
    Johns Taco
    Johns Taco I'm not 4x4, and have an open diff. So i'm 4x1
    Albuquerque, NM
    05 DSM Base SR5 Slug Taco
    Full custom stereo, onboard air compressor, train horns, spacer lift, 30" tires, optima yellow top, rear slider window & tailgate anti-theft mod, pop & lock, class 3 tow hitch, lights in bed, Ultra Gauge, Weather Tech mats, yellow fog lights, camper top, air lift rear airbags, rear diff breather mod, soon to be more...
