Power outlet mod
Discussion in '1st Gen. Tacomas (1995-2004)' started by smuook, Nov 26, 2009.
  1. Nov 26, 2009 at 9:02 AM
    smuook
    smuook [OP] Daily Driver "Plus"
    Frank
    Loganville, GA
    2004 DC V6 PreRunner
    Billy 5100, Satoshi, MBW Wheels, All Pro Front Bumper with 3x PIAA 530, LED dash lighting, other stuff too much to list
    Simple mod that allows your 12v power outlets to be on when the truck is off. I wanted to be able to charge my phone while the truck is off. Simple schematic... remove the power outlet relay in the engine compartment relay box and install a jumper. Also provides a Accessory power tap for fog lights, etc.
    Here's the jumper:
    Relay location:
    Remove relay and install jumper:
    All finished:
    The white wire is my new fog light tap into ACC Pwer that makes sure the fog lights turn on only when the truck is on so I won't accidentally kill my battery. Pretty simple, only about 10 min job. Everything tested and works great.
    lucky13don likes this.
  2. Nov 26, 2009 at 9:14 AM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    nice write up. like the way you put time into it
  3. Mar 18, 2010 at 10:59 AM
    MK ULTRA
    MK ULTRA Well-Known Member
    JIM
    Huntsville Ala
    4X4
    Do all Tacoma's have power outlets?
    What years did it start and is this an option?
    Thanks
    Great site.
  4. Mar 18, 2010 at 11:01 AM
    NeoMoose
    NeoMoose Possibly Batman
    Houston, TX
    2010 PreRunner DC TRD O.R.
    Kenwood eXcelon X993, Kenwood KFC-1693PS (Front), Kenwood KFC-G1620 (Rear), Luverne Black Nerf Bars, OEM Brush Guard, AFE Pro Dry S Drop-In, Some kickass wheel locks, Removed front mud flaps, All windows tinted, Anti-theft tailgate mod
    The 05+ TRD packages have the power outlet.
  5. Mar 18, 2010 at 5:52 PM
    Beau02
    Beau02 Black Taco
    Beau
    Indianapolis, IN
    2002 4x4 Limited TRD V6 Auto (190k+, 1-owner)
    Lots of small stuff; Grillcraft MX, Bilstein 5100's, Deck Plate Mod w/ K&N air filter, Airaid MIT, braided SS brake lines, Redline Tuning QuickLIFT hood struts, Extang Full-Tilt tonneau cover, fog light mod, gray wire mod, power outlets on-demand, Diff breather ext, additional contours to passenger side from oak tree.
    I'm not sure when the additional power outlets started, but my '02 has them, so I would assume that means they're on '01-'04 Tacos. Based on the post above, 05+ trucks have them too. I don't know if they were in the '00 and below?
  6. Mar 18, 2010 at 5:55 PM
    RoyB
    RoyB Well-Known Member
    Chicago burbs
    '09 TRD DC Sport
    you have a 110v outlet?
  7. Mar 18, 2010 at 6:09 PM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    The separate power outlets (other than the cigarette lighter) were available as early as the 1998 model year.
  8. Mar 18, 2010 at 6:10 PM
    Beau02
    Beau02 Black Taco
    Beau
    Indianapolis, IN
    No, first gens don't have 110VAC outlets. See the first post in the thread - the author has an '04 and refers to the 12V power outlets in the truck. That is also what I'm referring to. I see you're probably right in that the post about the 05+ is referring to a 110VAC outlet, but the thread starter wasn't.
  9. Mar 21, 2010 at 6:37 AM
    krlang
    krlang NewEnglander
    Commonwealth of Massachusetts
    03 2WD 2.4L Tacoma Reg Cab
    Chrome Bumpers F&R, Grille & Corner Lights, Wheel Skins, Red/Clear LED taillights, Remote start, PDL, Cruise, K&N, All Kenwood, DNX-5120 6.1" NAV/TRAFFIC/DTV/DVD/XM/BLUETOOTH/USB/IPOD/SUB/rear cam, Tint, Air Band radio, Class 3 Hitch with 4/7 pin harness, Transmission Cooler, Red Top Battery, "Deck Plate" mod.
    If it wasnt mentioned earlier,
    There are three outlets in my 03
    The one next to the ashtray, which has its own power source.
    The two below on the filler panel, operated by the relay.
    I jumpered out the relay and then added a relabled hazard switch in an empty switch hole next to them to turn the ground on and off.
    I got the Hazard switch in a junkyard, cleaned off the red box and p-touched the area with "12V".
    I wanted to be able to turn them on and off, when not in use.
    It works good, my scanner is plugged into the upper socket normally, but if I want to listen with the truck off, I move it down a hole and press the button.
    This picture shows the fusebox, the jumpered relay, and where I put the relay to use it for my foglights, the next relay socket is powered from the factory, so you just need to add the output and control wires. I ran the output to the two 10a fuses in the bottom corner of the box. One for each foglamp. then I tied the control wire through a switch to ground at the headlight ground, so it shuts off the foglights when the headlights are off.
  10. Mar 22, 2010 at 3:57 PM
    RoyB
    Chicago burbs
    '09 TRD DC Sport
    i only read what i want to :D
  11. Apr 1, 2010 at 7:23 PM
    althorp
    althorp New Member
    Western Massachusetts
    98 Tacoma 4WD
    Pace Edwards JackRabbit tonneau cover.
    Thanks, SMUOOK, for that excellent mod description. Exactly what I was looking for! Great Site.
  12. Apr 4, 2010 at 9:43 AM
    sp0di
    sp0di Active Member
    Jay
    10 DC OR
    any thoughts if this would work on a Gen 2?
  13. Apr 4, 2010 at 12:58 PM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    Nice job. I'll be doing that soon then.
  14. Apr 4, 2010 at 6:14 PM
    Rattler
    Rattler Wandering But Not Lost
    Bay City MI
    '04 DoubleCab "3 Lift on 285/75/16s
    All Pro rear bumper with an Ironman Offroad swing-out spare carrier, Bajarack on top, blacked-out grill, Lightforce 140s Mombasa Rooftop Tent
    I need to do this too.
  15. Apr 4, 2010 at 6:27 PM
    2004Taco
    2004Taco Well-Known Member
    Long Beach,CA
    04 PreRunner SR5 Trd
    Proformance: Magnaflow K&N CAI Billet grille Suspension: Fox 2.5 Coil-overs with DSC Total Chaos UCA Deaver j59 Leaf Springs Bilstein 5100 0"-2" Rear Shocks
    (stupid question) Now having this mod done. Will it eventually kill the battery if you have something plugged in over night?
  16. Apr 4, 2010 at 6:46 PM
    EnolaGaia
    Midwest USA
    '01 & '04 S-Runners
    Conceivably - yes. Bypassing the relay like this essentially makes for a 'constant hot' circuit direct to the battery.
  17. Jun 18, 2011 at 6:09 PM
    rberumen2
    rberumen2 Well-Known Member
    Ralph
    California
    2017 White Tacoma TRD Sport 4x4 DCSB
    where can you buy a jumper?
  18. Jun 18, 2011 at 6:37 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C, OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; aFe POWER Magnum FLOW Pro DRY S Air Filter; NSB-AGM27F Battery w/Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Cooper Discoverer A/T3s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; MetalMiller TRD Skid; jsi's Locker Anytime & ramonortiz55's Always on Power Outlet Relay Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades (RallyLights Harnesses, Osram 85/80W H4 & Flösser 90W H11 Bulbs); mattgecko's Underhood Lighting; ND4's Fog Light Anytime Mod; Interior & Reverse LEDs; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; 4Runner 4X4 & FJ Fog Light Switches; Husky Floor Liners; UltraGauge EM; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Toyota Bed Extender; Pop & Lock Power Tailgate Lock; ARE Z-Series Cap, SolarGard Tint; BlendMounted BEL Vector 995; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Why not just make one, with a piece of wire and a couple of crimp connectors. :confused: (Took less than 5 minutes when I did mine.)
    Great write-up, BTW, OP! Thanks for taking the time to put it together.
  19. Jun 18, 2011 at 9:06 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    This is how I did mine......took out relay and put in jumper wire.
  20. May 13, 2012 at 6:14 PM
    Rdy2offrd88
    Rdy2offrd88 Well-Known Member
    Nick
    St. Louis, MO
    02 DC TRD
    Deckplate, CB w/ 4ft Firestick, Bedrug
    Iv'e been looking at doing this but I can't seem to find a jumper. Ive looked at my local O'Reilys and online. Any help on where to locate on of these. thanks
