Power outlet not working
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Reese986, Jun 11, 2023.
  1. Jun 11, 2023 at 11:37 AM
    Reese986
    Reese986 [OP] New Member
    Tony
    13 Tacoma TRD sport
    I have a 13 trd sport with jbl stereo. Under the heat control knobs is 2 power outlets the passenger side 1 is not working. Ideas? I'm new to the Tacoma only had it for a week.
  2. Jun 11, 2023 at 11:42 AM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    check fuses?
    mines works on and off because the connector is bad.....where it plugs into the actual power outlet.
    check that they are plugged in properly
  3. Jun 11, 2023 at 2:05 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    They both get their power and ground from the same source.
    There a small possibility it’s a wiring issue, but I’d say the socket itself is more than likely the problem.
  4. Jun 11, 2023 at 3:22 PM
    TacoTuesday1
    SD CA
    Start by checking the fuse. It's probably behind the drop down cubby left below the steering wheel.
    cig lighter port fuses can easily be blown by overloading/overdrawing them plugging in something that takes more power than it can provide, whether that be a device, or even just a shitty adapter thing plugging into it, which can even fail itself internally
    get a decent pack of assorted fuses and keep in the truck for emergency repair. They're small, light, and you never know when one is gonna go out on the road.
  5. Jun 11, 2023 at 4:21 PM
    Reese986
    Tony
    13 Tacoma TRD sport
    Thanks it's not the fuse or relay. So it looks like I'll be ripping the dash apart to take a peek! I also have p0333 code suspect critters chewed on wires since it was sitting in the Georgia mountains for a year, and there was a nest in the heating system.
