Power Outlet on Dash Board - Not Working
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Thegigz, Aug 3, 2025 at 8:36 AM.
  1. Aug 3, 2025 at 8:36 AM
    Thegigz
    Thegigz [OP] New Member
    Sunday
    2022 TRD - Lunar Rock
    I just bought a 2022 TRD Tacoma, that only had 524 miles on it!! Sat in a garage for 3-years, Crazy....
    So I noticed the in-cab power outlet is not working. Of course I went and googled the issue and only found (2) solutions. Neither worked.
    - Check the fuse under the driver side dash. Fuse is good...
    - Check to make sure its plugged in. So I took apart the dash and found it was plugged in and the connection/wires looked in good shape. I also amped out the wires and had no power.
    I know its a 3-years old truck, but I am assuming the outlet never worked. Anyone else every come across this issue with a there new truck?
    Since I had the dash apart I ran a wire from the center console into the dash to power my magnetic phone charge. Much cleaner not seeing any wires.. So I am not to concerned about the outlet, but I can't let it go..
    Thanks in advance for the help!
  2. Aug 3, 2025 at 8:58 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    ^Which fuse did you check and how did you verify the it was good? With the fuse installed, probe the contacts from the top of the fuse with a test light. Make sure both contacts have power.
    Dm93 likes this.
  3. Aug 3, 2025 at 9:17 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Just because it is a 3 year old vehicle that has not been used much does not mean that this is the cause of your issue. I vote you checked the wrong fuse and I cannot believe you disassembled the dash just for this!
    PS: welcome to TW!
  4. Aug 3, 2025 at 9:37 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    You checked the P/Outlet No1 and P/Outlet No2/USB fuses?
    You said the truck sat for 3 years so rodents chewing wires is a possibility as well.
  5. Aug 3, 2025 at 9:37 AM
    Thegigz
    Sunday
    Buck, its not rocket science to take apart the dash!!! It took 5 minutes..
    But maybe your just not mechanically inclined..
    And I am well aware it may not be a new car issue, just asking questions.
    Just in case you don't know asking questions is what leads you to solutions.. Which is the whole point of this website.
    Next time move on before adding useless comments!!
  6. Aug 3, 2025 at 9:41 AM
    Thegigz
    Sunday
    Dm93: Funny you mentioned that, I thought the same thing.
    Not that I can see everywhere, but I actually checked for rodent damage before buying the vehicle.
    I did not however check the fuse box or the fuse with a tester... My Bad!!
    I did the old hold up to the light trick.
    I will grab a tester tomorrow..
    Thanks for the USEFUL advice....
  7. Aug 3, 2025 at 9:45 AM
    Clearwater Bill
    Billy
    Largo Florida
    Does the key have to be on for the outlet to work?
    Chew and BillF1564 like this.
  8. Aug 3, 2025 at 10:02 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Yes
  9. Aug 3, 2025 at 10:11 AM
    Clearwater Bill
    Billy
    Largo Florida
    I assume you tested the wires for continuity as well as voltage?
    So some type of DVM? You can check the fuses with that.
    And just for confirmation, the key was on, correct?
    BillF1564 likes this.
  10. Aug 3, 2025 at 10:45 AM
    Buck Henry
    LOL, if my benign comment triggered you this much, then you are going to have a lot of fun here.
    PS: I spent decades working on nuclear submarines, so I am definitely mechanically inclined. Taking apart a dashboard is the easy part. Getting it all back together and working properly can be a real nightmare. Glad to hear that is not the case with the Taco. As I said, welcome to TW!
    Old metals, musicisevil and BillF1564 like this.
  11. Aug 3, 2025 at 11:00 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    start here, and also note there is a data USB on the dash that I believe has a much lower output. So maybe there is a chance it does not have enough amps to power your device? I don't know electronics well at all, but I think to a few devices I own at home that will not charge or work without the proper charger, as some chargers (that all look the same, until I read the output) are too high or low. Just a thought.
    musicisevil likes this.
  12. Aug 4, 2025 at 8:14 AM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    Would you clarify if it is the USB outlet or the cigarette lighter adapter that you are referring to.
  13. Aug 4, 2025 at 9:55 AM
    fmb
    fmb Member
    USB or Lighter outlet?
    Oops, missed the post already asking this…apologies.
  14. Aug 4, 2025 at 1:40 PM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    Plot twist: Op is just a troll account to dog on Buck:drevil:
  15. Aug 4, 2025 at 1:47 PM
    Buck Henry
    Me thinks OP did not realize that the truck ignition had to be "on" for these dash power supplies to work. I think that is a Toyota thing as my wife's 2010 Camry is the same way. I really was not meaning to piss him off but I guess I did. My fear is he has slithered back into internet obscurity.
    musicisevil[QUOTED] likes this.
  16. Aug 4, 2025 at 4:00 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    Wow
    Someone with 3 posts ragging and lashing out at a veteran member with over 3,000 posts.
    Class act.
    Oh also a lot of people just look at a fuse and determine that it's "ok or good"
    Don't check with a multimeter or try a new fresh one.
