Power outlet
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dirt clod, Mar 20, 2025.
  1. Mar 20, 2025 at 11:43 AM
    dirt clod
    dirt clod [OP] Active Member
    Greg
    2023 Tacoma
    I do believe that I have everything figured out, with the info on TW, on what is needed and the how-to, to install an always hot power outlet to the rear of the bed.
    Now, for the interior outlet and possibly the USB. For the cig outlet, I want to cut the wire and save it for some other mod. Then connect an always hot wire to the cig outlet.
    Does anyone have a wire diagram or wire color for the existing outlet wiring ?
  2. Mar 20, 2025 at 12:34 PM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    Don't cut it, just unplug the harness and put spade connectors on your power and ground wires. Center pin is hot and outer shell is ground. Be sure to fuse it.
  3. Mar 21, 2025 at 9:06 AM
    dirt clod
    Greg
    2023 Tacoma
    I have been trying to figure out how to get to it. It doesn’t seem reachable from firewall side. I always feel that the plastic is going to break. So that’s where the wire cutting idea comes from
    After watching some videos, the wire might be accessible if the glove box is removed. Crummy videos.
    Also, it looks like I will have to bend a spackle knife in order to get to the tabs holding the air bag.
