Power Ports Not Working
Discussion in '1st Gen. Tacomas (1995-2004)' started by Taco II, Jan 22, 2012.
  1. Jan 22, 2012 at 9:13 AM
    Taco II
    Taco II [OP] Member
    Jan 22, 2012
    DC Metro
    04' TRD 4x4 - 06 TRD 4x4
    2004 Tacoma...Power Ports will not energize...Upon inspection (I removed the panel they are installed in) I noticed one had a bad fusible link however the other looked OK. The interior 30 amp fuse tests OK. I removed the Power Relay from the fuse box under the hood and installed a jumper to allow the power to present itself full time but still no power. No Power getting to the connectors that attach to the rear of the power port(s).
    Question: Can you test the Power Relay to determine if it is any good?
    Question: Do you have to buy a replacement from Toyota?
    Question: How in the heck do you remove the Power Port Cylinder from the housing?
