Power rear sliding window fail
Discussion in '3rd Gen. Tacomas (2016-2023)' started by klowie, Jan 17, 2024.
  1. Jan 17, 2024 at 7:55 AM
    klowie
    klowie [OP] Member
    Kris
    San Juan Capistrano
    21 White TRD 4x4 Off Road
    My power slider would not open more than an inch and then was stuck open. The motor snapped off below the window. Toyota quoted me over $1,000 to replace. I did a search of forums but didn’t find much here (probably didn’t use the correct terms). Anyone else have trouble with the power sliding window?
  2. Jan 17, 2024 at 9:47 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I have read it only a few times over the years, it sounds like it's doable for the DIY'r.
    I have been suggesting to folks; as soon as that sucker starts acting up, to leave the MF'r shut and never open it again. It's such a small pointless window, if it was sealed, it wouldn't be worth the cost and hassle for me to repair.
    MannyS, Toycoma2021 and wilcam47 like this.
  3. Jan 17, 2024 at 10:10 AM
    rndsommer40
    rndsommer40 Well-Known Member
    Ralph
    2022 TRD OffRd DCSB
    I've only opened that window 1x when I first bought the truck.
    wilcam47 likes this.
  4. Jan 17, 2024 at 10:31 AM
    rolled93slc
    rolled93slc Well-Known Member
    Jerry
    Lynchburg VA
    16 Tacoma TRD Sport DCSB MGM
    I have only seen one fail, so far. The customer didn't want to fix it, just get it shut. Had to remove the trim panels behind the rear seat to get to the motor and cables to close it.
    Sometimes I'd like to have a power sliding window. But I just have my daughter, who sits in the back, open it for me.
  5. Jan 17, 2024 at 10:39 AM
    Jesse H
    Jesse H Well-Known Member
    Jesse
    Texas
    '22 TRD Pro 6MT
    I love that power window. When the weather is nice I can crack the sunroof and open the back window and have good airflow without too much buffeting. During the summer it helps evacuate the 120 degree cabin air from when it's been parked for a while.
    I accessed it when I was installing sound deadener back there. I'm not sure why the dealer is quoting so much
  6. Jan 17, 2024 at 10:43 AM
    bcmbcmbcm
    bcmbcmbcm Well-Known Member
    Brett
    22 Barcelona Red TRDOR 6MT worth the wait !! Hang in there !!
    do they make an aftermarket non-sliding picture window to fit that spot?
  7. Jan 17, 2024 at 10:45 AM
    rolled93slc
    Jerry
    Lynchburg VA
    That's the best part of it, no buffeting with the sunroof open.
    Depends on what's broken, as to the cost of repair. Sounds like he has an issue with the cables. not the motor. The labor to replace them, I'd imagine, is close to 4 hours, plus parts. I know we are $165/hr labor. That alone is $660, plus parts, tax, shop fees.
    shakerhood likes this.
  8. Jan 17, 2024 at 2:30 PM
    Mbtstaco
    Mbtstaco Well-Known Member
    2023 Tacoma Pro MGM
    You have a 2021 are you already out of warranty? If so that timing just sucks.
  9. Jan 17, 2024 at 2:47 PM
    Jackie Moon
    Jackie Moon Well-Known Member
    CO
    2021 DCSB OR 6MT
    That window is important to me because it’s important to my dogs! I also like seeing the people behind me smile and wave to the protruding snouts.
    OP I hope you get it fixed!
    rolled93slc, Jesse H and RustyGreen like this.
  10. Jan 17, 2024 at 2:50 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    If you haven't already gotten this far, it's pretty easy to get to the rear window mechanism. Once the panels are removed it should be a pretty standard repair depending on which part has actually failed. Definitely something I'd try to do myself before getting the dealer involved. Any chance something could have just gotten lodged in the track itself?
    Pic from when I was starting my sound deadening project:
    klowie[OP] and shakerhood like this.
  11. Jan 17, 2024 at 3:08 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Parts are not that expensive
    https://toyotaparts.ourismantoyotao...il--3-5l-v6-gas/body--glass-and-hardware-back
  12. Jan 17, 2024 at 4:08 PM
    twtaco$
    twtaco$ Well-Known Member
    I stick a long pipe, board or something through that window or something other than that not sure what its for.
    MannyS likes this.
  13. Jan 17, 2024 at 4:18 PM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    It’s most likely the regulator assembly
  14. Jan 17, 2024 at 4:58 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    I'm not promoting the brand or this exact product, but yes, they do.
    Stationary Encapsulated Back Window Back Glass Compatible with Toyota Tacoma Pickup 2005-2022 Models https://www.amazon.com/dp/B00X6I0M42
    Edit: you could also order the OEM rear glass from a 2nd gen regular cab, as they never had sliders.
    klowie[OP] and Gmak621 like this.
  15. Jan 17, 2024 at 5:08 PM
    klowie
    klowie [OP] Member
    Kris
    San Juan Capistrano
    Thanks for all the information. Tacomaworld is the best! Total shitshow at the dealership today. The motor broke off its mounting. They charged me $200 in labor to tell me that, left the window stuck open (I gave it to them closed) and had the headrests in backwards. They lost a 20 year customer. I don’t think they care.
    GSDLVR123 likes this.
  16. Jan 17, 2024 at 6:45 PM
    bcmbcmbcm
    Brett
    Thanks. That may be the ticket when the sliders fail. I am sure a local glass shop can secure factory, OEM, or aftermarket glass and install it too.
    Malvolio and Bertw192[QUOTED] like this.
  17. Jan 17, 2024 at 8:27 PM
    Dead-Weight
    Dead-Weight Well-Known Member
    Scott
    Sedalia, CO
    ‘22 OR Lunar Rock
    Pine tree air freshener
    Sorry for your troubles, Klowie and hope you get it resolved. Like someone else said, I’ve only opened and closed mine one time while in the dealer parking lot.
  18. Jan 17, 2024 at 8:37 PM
    MannyS
    MannyS Well-Known Member
    Republic of Texas
    Rear Glass with a manual sliding window is $300
    Malvolio likes this.
  19. Jan 17, 2024 at 8:43 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    Not Karen
    The wild west
    2016 SR5 DCSB
    Aesthetically Challenged
    If it's something you can do yourself, spend 4 hours on a saturday with an 18 pack and fix it up.
    faawrenchbndr likes this.
  20. Jan 18, 2024 at 3:00 AM
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Sorry to hear that. The question is, “why did the motor break its mount locations”
    If you replace the motor, get a regulator assembly as well, it’s like $50
    klowie[QUOTED][OP] and Chew like this.
