Power Routing Advice Please
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SManZ, Apr 8, 2010.
  1. Apr 8, 2010 at 4:20 AM
    SManZ
    SManZ [OP] el tráfico más lento se queda derecha
    Haymarket, VA
    '10 Supercharged 4x4 Sport 6-spd
    TRD Supercharger, King 2.5" extended travel remote-resi coilovers, OME Dakar leaf packs, King 2.5" extended travel rear shocks, Total Chaos UCAs, MBRP turndown exhaust, TRD intake, TRD Quickshifter, Goodridge SS brake lines, EBC Sport Rotors, Hawk HPS pads, TRD FJ Cruiser Special Edition 16" Anthracite Rims, Spidertrax wheel spacers, 265/75R16 A/T, Autometer oil pressure, oil temp gauges, TRD boost gauge, PLX DM-100 OBD II scanner, flexpod mounts, A-pillar gauge pods
    I'm looking to add some accessories to the interior and exterior of the truck over the next few months like gauges, bed lights, interior lighting, etc.
    I would like to have one junction box under the hood and one in the cab so that I can easily connect 12v accessories to it. I do not want a nest of wiring running all over the engine compartment and 6 connections to the positive battery terminal.
    Ideally, I'd like to have just one cable coming off the battery, have it relayed so it is on only when the truck is, and split to the 2 junction boxes. My thinking is that if I relay the main cable I won't have to tap relays for each accessory separately.
    Can someone recommend a good junction box for this purpose? Whats the best way to go about doing this?
    -Thanks!
  2. Apr 9, 2010 at 4:37 AM
    SManZ
    Haymarket, VA
    Bump?
  3. Apr 9, 2010 at 5:01 AM
    86ceeten
    86ceeten Well-Known Member
    Brian
    NW Florida
    08 TRD Off Road PreRunner
    Limo tint, 18x10 Diamo Karat, Toyo 285-60's, Rear TSB, 5100's all around, front at 2.5", Debadged, Sound System (evolving)
    Look in a marine store. They have really nice weather resistant fuse/junction boxes that work great for this.
  4. Apr 9, 2010 at 5:27 AM
    Cars0n`
    Cars0n` Well-Known Member
    Carson
    Edmonton AB
    07 2wd access cab base.
    Kenwood DDX-512 Deck, Boston Acoustics G5 Sub in Ported Bassworx Box, Kenwood eXcelon KAC-X10D Amp, Sirius Satellite Radio, Magellan GPS, DDM 55w bi-xenon headlights, 2 HID Hella 500ff's mounted behind grill, 4 pc ebay Billet grill, Fog Lights (my truck didnt have them stock), Pioneer Speakers 6x9's(front) 6.5's(rear) AFE Cold Air Intake, Hose Clamp Mod, Tailgate Strengthen Mod, Removed Gay Mud Flaps, De-Badged, BHLM, 245/45/20 on velocity wheels. VW865a, Extra D Rings In Box, OEM Cruise Added Optima Red Top Battery
    could you tap into the existing fuse box for an accessory power to provide power to the fuse block you add? or would this overload the fuse tap in the fuse box?
  5. Apr 9, 2010 at 5:32 AM
    SManZ
    Haymarket, VA
    Thanks 86ceteen, I'll check out a marine shop when I'm in Occoquan next. There's a marine shop close to the river.
    Carson, I don't know much about the math for figuring out electricals, but I doubt that I'll be running much power. It'd be mainly for lights in gauge pods and accent lights. The highest draw would be the bed lights. Still, I would rather have these on a dedicated circuit than piggybacked onto an existing fused connection. I could use an existing fused circuit for the relay input to switch on all the other accessories.
  6. Apr 9, 2010 at 5:44 AM
    Cars0n`
    Carson
    Edmonton AB
    ahh makes sense.
    i just figured seeing as how the fuse box has some extra fuse locations that are not used we could tap into that to power the fuse block. im looking into the same thing but was a little skeptical about adding that to the fuse box in fear of popping some hidden main fuses or something.
    post up how you go about adding a relay to this i was thinking about doing this
  7. Apr 9, 2010 at 5:46 AM
    TOYOTA 09
    TOYOTA 09 Kicking Ass Since 1981
    Maine
    2009 SR5 MT 4x4 Access Cab
    Preview 2009 SR5 4x4 MT Black Sand Pearl (Access Cab) SUSPENSION ToyTec 5100 Billstein Coil Overs (3" Lift) Fox 2.0 Remote Res Rear Shocks Total Chaos UCAs Full Dakar Leaf Pack w/Extra AAL TIRES & WHEELS BFG AT KOs 265/75/16 load range E American Rancing AR-23 Wheels Borla CAT back exhaust AFE cold air intake w/custom TRD clear cover Satoshi grill w/Grill Craft insert Hella 500 behind grill lights Rigid Industries Backup lights Interior Custom LEDs and Bed Lights Backup Cam Anytime MOD Leather armrest and rear seat MOD Weathertech floor liners Custom rear gear/dog platform Cobra CB and Garmin GPS Bed Mat UWS low pro tool box with Custom LED lights Diff breather MOD Custom painted engine cover Wet Okole seat covers
    just use LEDs....they use VERY little power and you don;t need a relay!
  8. Apr 9, 2010 at 11:17 AM
    OTG
    OTG Member
    Bill
    Maryland
    09 DCSB
