Power RPM loss - Revving Issue
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DrakeInAlabama, Mar 2, 2019.
  1. Mar 2, 2019 at 5:17 PM
    DrakeInAlabama
    DrakeInAlabama [OP] Member
    Drake
    2016 Tacoma SR5 Dbl CB 2.7
    I have the following Tacoma:
    2016 Tacoma Double Cab w/ 2.7 4 cylinder engine, Auto, 70,000 miles
    I'm experiencing a loss of power at highway speeds. When I place my truck either in Park or Neutral, my truck will rev up to 3k or 4k rpm and hang for a while until breaking loose. I believe this is the cause of my loss of power at highway speeds. I took my truck to the dealership and they told me it was my MAF sensor. They replaced the sensor and I'm still having the issues. I posted two videos of the problem below. Has anyone had this problem or know what it is?
    https://youtu.be/Ph4At2CiE_k
    https://youtu.be/CUcphqm16xo
    Thanks,
  2. Mar 2, 2019 at 5:37 PM
    yorttam83
    yorttam83 Chaotician
    Douglas, MA
    2021 GX460
    Soccer Mom Delete Kit
    I thought I read that in neutral or park the RPM's were limited and wouldn't allow it to redline. I could be wrong, though.. What do you mean a loss of power at highway speeds?
  3. Mar 2, 2019 at 5:41 PM
    DrakeInAlabama
    Drake
    I'm experiencing loss of power at highway speeds on top of the rpm problems during Park and Nuetral. I believe they're connected since at highway speeds, the rpms are not allowed to increase.
  4. Mar 2, 2019 at 5:42 PM
    Shellshock
    Iowa
    Pretty sure it’s capped in neutral and park by the ecu and will force the revs down before shifting to drive to protect the drivetrain so you can’t neutral bomb it
    yorttam83 likes this.
  5. Mar 2, 2019 at 5:42 PM
    floodedkiwi
    floodedkiwi Well-Known Member
    Ken
    Naw'lins, Louisiana
    2019 GMC AT4
    Dog.
    Vacuum leak???? Just a guess on my part...
  6. Mar 2, 2019 at 5:48 PM
    yorttam83
    Douglas, MA
    2021 GX460
    If there is a vacuum leak I would imagine there'd be a fault for it.. Cars nowadays are so sensitive to mixture issues due to emissions regulations even the slightest vacuum/ intake leak can trigger a fault. The OP said the MAF was replaced.. I wonder if it was an air to fuel fault they were chasing, or just throwing parts at it. I've never driven a 4 cylinder 3rd gen but I can't imagine it wouldn't feel very peppy at highway speeds since the 3.5 needs to wind out a bit.. Again, not knocking the OP's truck, or the 2.7....
  7. Mar 2, 2019 at 5:48 PM
    DrakeInAlabama
    Drake
    I thought that too but it doesn't do it every time. It randomly does it. Once I start experiencing a loss of power on the highway I pull over and the RPM revving problem occurs.
  8. Mar 2, 2019 at 5:50 PM
    floodedkiwi
    Ken
    Naw'lins, Louisiana
    2019 GMC AT4
    Dog.
    10-4... I guess I’m showing my age with that one.... Got points and a capacitor on that thing?
    yorttam83[QUOTED] likes this.
  9. Mar 2, 2019 at 5:50 PM
    yorttam83
    Douglas, MA
    2021 GX460
    Did you request to drive a comparable truck? I'm a service advisor for BMW and when I get drivability issues that are "normal", I plate up another car for the customer to drive back to back. Again, not saying yours is normal, but it's worth a shot.
  10. Mar 2, 2019 at 5:51 PM
    Shellshock
    Iowa
    Whet happens on the highway? Does it just shut down or what? Loss of power is pretty vague. Does it happen consistently? Is it repeatable?
  11. Mar 2, 2019 at 5:51 PM
    DrakeInAlabama
    Drake
    Yeah I understand. I don't expect it to be peppy but when the loss of power occurs, I literally have to mat the pedal to the floor to keep it at 70.
  12. Mar 2, 2019 at 5:53 PM
    DrakeInAlabama
    Drake
    I have to keep the pedal to the floor to keep it at 70 on the highway. It didn't used to do that when I first bought the truck.
  13. Mar 2, 2019 at 5:54 PM
    yorttam83
    Douglas, MA
    2021 GX460
    I see.. My suggestion still stands.. Ask the dealer to drive another truck like it. See how it performs.. Again, this is if it is consistent and you're able to replicate it.
  14. Mar 2, 2019 at 5:58 PM
    Vonhetzer
    Vonhetzer Well-Known Member
    IN
    19 Taco
    Sorry if you mentioned, is this a new vehicle to you or did this just start behaving this way? I’m not much help just looking for clarification.
  15. Mar 2, 2019 at 6:00 PM
    DrakeInAlabama
    Drake
    No, I've had it since new. The truck now has 70k miles. This just started happening with the loss of power and rpm issues since 2 months ago.
  16. Mar 2, 2019 at 6:00 PM
    Shellshock
    Iowa
    Wind? Hills? Flat ground?
  17. Mar 2, 2019 at 6:02 PM
    DrakeInAlabama
    Drake
    All grades. That's why i think something is holding it back.
  18. Mar 2, 2019 at 6:21 PM
    Shellshock
    Iowa
    Weird. Maybe disconnect the battery for a while and see what happens. Maybe ecu is just confused.
  19. Mar 2, 2019 at 6:43 PM
    JNG
    JNG Shitposter extraordinaire
    2019 Silver TRD OR DCSB 4x4 AT P&T
    Do any mods lately? Namely larger and heavier tires? A lift? Big rack?
  20. Mar 2, 2019 at 7:36 PM
    DrakeInAlabama
    Drake
    No, all stock.
