Power Running Through Instrument Cluster When Vehicle Shut Off?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 76CLE76, Oct 2, 2021.
  1. Oct 2, 2021 at 5:08 PM
    76CLE76
    76CLE76 [OP] Active Member
    Charles
    Divide, CO
    2011 White Tacoma Off Road and Towing packages
    Aluma coil-overs with 3” lift Toytec 1" body lift Toyota Cat-Back exhaust JBA Standard High Caster Upper A-Arms Spydertrax 1.25" spacers Yokohama Geolander M/T G003, 285/55r16 on stock rims N-Fab Nerf Step Bars
    I had recently installed a Hypertech Speedometer Calibrator. Worked great for about six weeks but then the speedo, odo, and cruise control went out. CEL and VSC lights came on. Had a auto repair shop (not parts store) scan it. Said all sensors are fine, most likely a short, loose or broken wire in the instrument cluster. Dug around back there and couldn't find anything loose or broken. Removed the Calibrator, put everything back together, and problem solved.
    When I removed the Calibrator I noticed it was warm. Not super warm but definitely warm. The truck had been sitting in the garage all night and hadn't even been turned on. After it had been removed it did cool down to what you'd expect from inert plastic. So I assume there had been a slight current running through it.
    Should that be happening with the truck shut off?
    Thanks for any advice!
  2. Oct 2, 2021 at 7:11 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    In short no, sounds like a problem with your calibrator unit.
    The cluster does have a full time battery feed via the ECU-B fuse so if your unit was shorted or drawing current that would explain it getting warm with the truck off.
    TnShooter likes this.
  3. Oct 3, 2021 at 12:50 PM
    76CLE76
    Charles
    Divide, CO
    Thank you!
