Power Sliding Rear Window BRACKET
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by kgarrett11, Jan 27, 2017.
  1. Jan 27, 2017 at 12:15 PM
    kgarrett11
    kgarrett11 [OP] Master Yoda
    Garrett
    CA desert
    2015 DCLB
    This bracket will allow you to complete your DIY rear sliding window kit. This is only for the bracket, NOT a kit. Brackets are $49 shipped to your door. $10 more for those in Canada. Pm me to order. I will post updates along the way. Happy modding everyone!
    Here is a very detailed write up from member @Poitrasbh
    EDIT: They are in and have been shipped to several members!
    2023**If you're reading this, then yes I still have some left. Message me**
  2. Jan 27, 2017 at 12:18 PM
    kgarrett11
    Garrett
    CA desert
    2015 DCLB
    @bobsuruncle
    @realBIG
    @medjah
    @Sleipnir
    @seoulja99
    @Cmurder
    @Zac of all trades
    @Bocsy44
    @Ner-d-s
    @3378jakesr5
    @lucas224
    @ACEkraut
    @YamaDirtrider
    @eAreEyeSee
    @JdevTac
    @big_jarv
    @gibby11
    @Boomkanani
    @excorcist
    @tacoycoy
    @Hit n Run
    @mrlee
    @Zandroid
    @DistortedAxis
    @glorifiedwelder
    @Jason McCabe taco
    @ZionPro
    @jmaack
    @PottMatter
    @FXHO
    @clemsontaco
    @Prettiboy98
    @bogginator
    @Kerrigan911
    @d33pdown
    @Jimmah V
    @AYates
    @Subtle
    @itaro
    @Timbuktu
    @katsina 44
    @Championsumo
    @Skynet Surfer
    @gmann1972
    @Jubei99
    @oldhorse
    @TRD-Merchant_Marine
    @Citadel
    @Victory
    @Yemiville
    @Michgnxj24
    @braves73
    @SRC
    @bgoods
    @Jimbouy
    @tacticaltaco85
    @96tacoforlife
    @lobsterbait
    @skkzhg
    @Mach375
    @Drtgrl
    @crutch024
    @dirteeboy808
    @Hit n Run
    @Dr Crawl
    @malay4785
    @datpurp
    @AuDigger
    @chubrok
    @Superman910
    @skkzhg
    @Mireland7
    @Grumpy
    @GG24
    @Knowledge4YoMama
    @Jinseiganai
    @Kevinlc6817
    @Schleinj
    @Green Mohawk Kayaker
    @jakub4
    @S.B.
    @redtaco2007
    @redrelyt12
    @Trailblazin.ID
    @apoteker
    @Custom Reef
    @Droptopfox
    @icfusion
    @paxromano
    @Toy4me
    @hwyrun
    @dyerkes
    @thunderstick12
    @stvhwrd
    @christian06
    @Poitrasbh
    @TacoManSupreme
    @SpicyTaco21
    @Tgcole
    @bybim
    @Jonny Quest
    @Yamota1617
    @bwrapped
    @Snowbored
    @RI Tacoma
    @TheJerseyDevil
    @xMaverickx
    @Leopico
    @tacopearl
    @rayban1
    @crepitus
    @Dp2020
    @mmyriel
    @nabu
    @60centenergy
    @2000tacobro
    @TACOMA2NDGEN
    @jack_thomas
    @Bwthomas77
    @easeup
    @Waitin4Snowfall
    @slowrodent
    @ElectricDoozer
    @SparkyIX
    @Scalleywag
    @AdrenaliNate
    @indiangk87
    @Gr8gatzby
    @2ndgen_714
    @TipsyTaco918
    @werleyr20
    @MadChicken
    @BlueT@com@4×4
    @will.i.was
    @OldSchlPunk
    @Brandedspade069
    stealthmode, medjah and ChadsPride like this.
  3. Jan 27, 2017 at 12:27 PM
    kgarrett11
    Garrett
    CA desert
    2015 DCLB
    Note at the moment. like the OP states they are being made and I wont know the details until I find out how much materials and shipping come out to be. This is just a list to gauge interest to determine volume.
    **EDIT- They are in and have been shipped to several members. $49
    seoulja99[QUOTED] likes this.
  4. Jan 27, 2017 at 12:35 PM
    kgarrett11
    Garrett
    CA desert
    2015 DCLB
    My understanding is that the kit is easy to assemble as a motor, cabling and wires are all that is needed. The tough part is attaching it to the window in order to slide. And thats what this bracket will accomplish. The wise and Mighty @nazlax10 can elaborate further as he has successfully completed this mod
    Cmurder[QUOTED] likes this.
  5. Jan 27, 2017 at 12:35 PM
    Bocsy44
    Bocsy44 Well-Known Member
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    This that and the other thing.
    MarX and Cmurder[QUOTED] like this.
  6. Jan 27, 2017 at 12:50 PM
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
  7. Jan 27, 2017 at 2:19 PM
    nazlax10
    nazlax10 Check out my build thread for any products used!
    David
    Woodstock, GA
    '21 Toyota Rav4 LE... At least it's a Toyota
    https://www.tacomaworld.com/threads/nazlax10s-build.408318/
    That's pretty much it. Mount a window regulator of your choice. I used one from an 02 trailblazer. Then run the cables up to the window channel. You drill holes to run the cables through. Then connect the cables to the bracket and that's really it. Here's some pictures from my install.
    You can see here my mounted motor, and how the cables run into the channel a little bit.
    Here's with my panel back on. I had to cut it to fit.
    Then here's with a motor cover I built.
    Here's the switch I used. It's a rear window switch from a Toyota Sienna.
    stvhwrd, KTM753, MarX and 3 others like this.
  8. Jan 27, 2017 at 3:37 PM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    Add me to the list please :popcorn:
    kgarrett11[OP] likes this.
  9. Jan 27, 2017 at 9:39 PM
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    The ghost of BenWa is going to haunt you for eternity.
    lol psyche... Glad someone stepped up to the plate and carried this mod on.
    For those just looking into this, there is plenty of information on the necessary steps to complete this here:
    https://www.tacomaworld.com/threads/benwas-2005-power-sliding-rear-window-quick-install-kit.171805/
    (also mentions of intellectual property blah blah... that guy "BenWa" clearly hasn't protected his "property" and has showed no interest in pursuing any type of sales of said "property")
    So again I will say glad you took the initiative to keep things rolling here. Assuming your not looking to make millions like some people seem to think this idea is worth from that thread I am most definitely in. I have a build thread for my rear slider going already and will link this one in there if things move forward.
    Edit: Just want to mention I also fully appreciate BenWa's contribution to this. Definitely the O.G. of this mod.
    toyotacoblur and Sleipnir like this.
  10. Jan 27, 2017 at 10:36 PM
    kgarrett11
    Garrett
    CA desert
    2015 DCLB
    This is this is by no means a money making venture, if it was obviously Benwa would still be doin this. I've been wanting to do this mod forevvvvver and I know others wanted to do the same. I am simply giving back to the tw community so ppl can complete their diy kit. This is only for the bracket, no kit. The goal is to break even at best and help as many members as possible complete their sliding rear window kits.
  11. Jan 28, 2017 at 7:09 PM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    In price pending
  12. Jan 28, 2017 at 7:13 PM
    robupstateny
    robupstateny Well-Known Member
    Rob
    Upstate NY
    2003 Lunar Mist Tacoma DLX
    Gray wire mod, Gentex 177 mirror, cupholder from @bradrn22, custom dog seat., AJT Design shift knob., Cb install
    http://www.aztrucks.com/product.asp?pr=Power_Sliders
    Just found this kit. EXPENSIVE seems to be my thought. My 03 is around 600. Just trying to get an idea of what this whole thing would cost. Not trying to step on toes, just surfing the net and finding ideas.
  13. Jan 28, 2017 at 7:47 PM
    MNmtb
    MNmtb Well-Known Member
    Jeff
    2015 Tacoma Lifted
    Interested. Pending price and difficulty on sourcing other components and install
  14. Jan 28, 2017 at 9:37 PM
    PottMatter
    PottMatter Well-Known Member
    CoLoRfUl CoLoRaDo
    2012 Red Baja Taco
    Interested in price
  15. Jan 29, 2017 at 4:17 AM
    Do58
    Do58 Well-Known Member
    2015 white tacoma limited
    Op.... I know your working hard to get this done to help others. I also know that you wouldn't be going through the trouble and HARD work for free, nor should you be. I myself greatly appreciate what your doing and it's a great idea that can impact many people beyond this board. My thing is that you have to have an idea as to what the bracket costs and what you want to sell it for. this is just for the bracket not the motor or anything else. Even if you shot from the hip and said a number I think you would get more people willing to commit. You know.... under promise over deliver and explain that this number CAN go down. It's great to see 5 pages and I'm sure more to come of people that say "interested" vs " commit or in". It's all about the price initially with people because it's not a must have. There is still a lot more involved than what your offering. I am intreagued myself but when I see a new post hoping for a price, it's just more "interest upon price". Your business and world. We are just living in it
  16. Jan 29, 2017 at 5:21 AM
    adio
    adio Well-Known Member
    HI
    2015 INFERNO TRD PRO
    If anyone is wondering what the braket looks like.
    61E83EB2-EBDC-4197-BC86-CF6CD6BF8FAB_zps_374f5691e207359afb73072e8ff77b82e249976a.jpg
    A94317BC-0F56-4C41-B6F2-655CA7D98B4E_zps_dde34031d3a96356c8f5de328fcb65ea13c388a7.jpg
    Sits on the channel between the window and the trim.
    0CA65F81-9A4B-468D-A7E7-847D25234756_zps_19876c6dbdaad933399e72b3a8f944e7834f4170.jpg
    Uses set screws, 10-32 thread, 3/16" long to secure the cable.
    53128687-B658-4847-921A-6AEF239B2FC4_zps_fcc6a35b939bc125d94c065adbb060418bd3083d.jpg
    2C3E9066-9F96-4DF0-8332-6F5312756081_zps_aa38b5962a2e3ef446c79a16f5f239a7bbb2a054.jpg
    kgarrett11[OP], Cmurder and docloco like this.
  17. Jan 29, 2017 at 5:23 AM
    TRD2010SpeedwayBlue
    TRD2010SpeedwayBlue Well-Known Member
    Brandon
    2010 Speedway Blue TRD Offroad
    so is this just for the bracket? or? i want the whole kit everything needed
  18. Jan 29, 2017 at 5:24 AM
    adio
    HI
    Pretty sure just for the bracket.
  19. Jan 29, 2017 at 5:24 AM
    TRD2010SpeedwayBlue
    Brandon
    ah if just for the bracket count me out as i dont have anything else
  20. Jan 29, 2017 at 7:37 AM
    Boomkanani
    Boomkanani Well-Known Member
    Goldsboro, NC
    2009 TRD OffRoad DCSB - 6 Speed
    Some stuffz
    You can buy everything else from Toyota...check out toyotapartsdeal.com
