Power sliding window..again
Discussion in '2nd Gen. Tacomas (2005-2015)' started by scratch, Dec 26, 2014.
  1. Jan 4, 2015 at 11:09 AM
    #61
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    Thanks, it was a Ford and I've been itching to get note done on setup I'm working on but had to get 5 stitches in my hand due to a hatchet accident
  2. Jan 4, 2015 at 11:46 AM
    #62
    scratch
    scratch [OP] Well-Known Member
    Oh man, that sucks. glad everyone is ok though, minus your hand.
  3. Jan 4, 2015 at 11:48 AM
    #63
    Timbo's Customs
    Timothy
    Lakeland FL
    How is your testing going today?
  4. Jan 4, 2015 at 11:55 AM
    #64
    scratch
    Good news, it works!!! Bad news, it's so cold outside right now none of my adhesives are sticking to the window, so I've got the truck in the garage warming up.
    I was able to shrink everything down to a 25mmx25mmx50mm package for the motor assembly, which means it will fit behind the seats with no modifications. Except for mounting the switch, you could literally stick this whole mechanism on your back glass and still have it out of sight.
    I had a hell of a time finding 3mm m.5 screws, so I modified the motor mount instead to hold the motor in place with more common #4 screws. Here is a shot of what the entire assembly looks like, minus the longer rod. You could build this right now and have a powered window that will work, you just need to release the button before the window is fully open or closed. I should have video tonight once the truck warms up and I can get this stuff to stick to the glass. Next up is the electronics to handle the end stops, one button open and close and automatically closing when the truck is turned off.
  5. Jan 4, 2015 at 12:06 PM
    #65
    leatherlungs
    leatherlungs Trained to save your ass, not kiss it
    North Carolina
    11 TRD Off Road Speedway Blue
  6. Jan 4, 2015 at 12:11 PM
    #66
    Cmurder
    Cmurder 2011 TX TRD Offroad
    B.C.
    Kansas City
    2011 TX TRD Offroad
    nothing cool
    Missed out on thr BenWa kits. I really hope this works out. Sub'd buddddddy
  7. Jan 4, 2015 at 12:32 PM
    #67
    sernaj64
    sernaj64 Aight
    Juan
    honolulu
    2011 prerunner V6 SR5
    N fab Step bars BHLM by Asianants Pro Comp 2.25" level lift kit rear leaf TSB
    Oh man looking forward to this good job guys subd
  8. Jan 4, 2015 at 2:41 PM
    #68
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Sub'd
  9. Jan 4, 2015 at 3:31 PM
    #69
    Robman
    Robman Well-Known Member
    Rob
    Hawaii
    '14 Tacoma Double Cab
    Sub'd
  10. Jan 4, 2015 at 3:52 PM
    #70
    Atomic47
    Atomic47 Well-Known Member
    Denis
    Manitoba, Canada
    08 V6 4x4 TRD Sport
    Leveling kit, AAL, air-ride, Rear diff breather mod, Illuminated 4wd Switch, 4 more D rings, fog lights anytime, 7 pin relocate, Coca-Cola mod, TRD Off-Road hook, Weathertechs, secret custom cargo light, 09 lower dash panel, heated seats, 2013 oem touch screen radio, reverse camera added into Pop'n'Lock locking tailgate handle, black powder-coated TRD Sport rims, 32" light bar in custom fabricated mount, aux reverse lights in rear bumper
    Clever!
  11. Jan 4, 2015 at 4:26 PM
    #71
    Spidious
    Spidious 2006 Tacoma SR5
    Fred
    Champaign, IL
    2006 Tacoma SR5
    Forward & reverse camera monitoring Bed Mat Tyger Black Tonneau Cover Tyger Sport Bar, 36" led light bar Hikity Android Car Radio Pro grill with lights Sport hood Cold air intake Sprint Booster throttle controller Flip down bed extender 265/75R15 tires 2"spacers New led tail lights Internal/external thermometer Chrome Bullbar Chrome step tubes LED F&R led turn lights
    What brilliant idea !
    Any idea on what the kits might cost, once you get to that point...
  12. Jan 4, 2015 at 4:34 PM
    #72
    Spidious
    Fred
    Champaign, IL
    2006 Tacoma SR5
  13. Jan 4, 2015 at 5:22 PM
    #73
    scratch
    OK gang, here is the first test video. Sorry for the potato quality, it's about 15F in my garage right now and I'm crammed in the backseat with a lab power supply on my lap and my phone resting next to my shoulder. A few things to keep in mind,
    This is in no way as pro as Bens, but it also requires 0 modification to your truck. Two pieces of 3m adhesive and some power wires and you will have a sliding window
    The Nylon is currently white, I will be dying that black
    It's not nearly as loud as the video makes it sound, not sure what the deal is there.
    The window is slow and hard to move because it's cold and wet, I expect it to go much faster as it warms up.
    I promise a better video and a permanent mount soon. For those of you following along, here is your bill of materials
    • 3d Printed Motor Coupler in Nylon or ABS , $3.70 using shapeways.com
    • 3d Printed Motor Housing in Nylon or ABS, $17.88 using shapeways.com
    • 3d Printed Window Mount in Nylon or ABS, $3.77 using shapeways.com
    • a #10-24 all thread rod (home depot) $4.00
    • a #10 nut (home depot) $1
    • 3M mounting tape (home depot) $5
    • Some wire (your neighbors speakers) priceless
    • The 800 RPM small form factor motor from Amazon $13.99
    • 2 2mm set screws (home depot) $2
    • 2 #4-40 1/2 inch screws (home depot) $1
    The grand total right now assuming that you have nothing and you are using shapeways for the printing is under $55. This will get you a hold down the button and the window moves power slider.
    Next steps will be adding a microcontroller and end stops to get an automatic slider, but if you are in a hurry, this will get you there. Here is a picture of what the final assembly looks like. I added the second bit of bracing around the coupler to protect in the event that the set screw on the motor fails. [​IMG]
  14. Jan 4, 2015 at 5:27 PM
    #74
    Spidious
    Fred
    Champaign, IL
    2006 Tacoma SR5
    Pretty nice, hard top see.. But looks to be way too slow. Maybe a faster motor ?
  15. Jan 4, 2015 at 5:41 PM
    #75
    scratch
    Right now it takes about 12 seconds to fully open or close the window, and honestly I'm good with that. I don't want to spin it too fast because it is just a bunch of homedepot hardware and 3d printed parts after all :) And in a week or so it will be an automated one touch open/close, so it's not like you'll have to hold a button down the whole time.
  16. Jan 4, 2015 at 5:43 PM
    #76
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    Awesome work. Good progress!
  17. Jan 4, 2015 at 5:44 PM
    #77
    Spidious
    Fred
    Champaign, IL
    2006 Tacoma SR5
    Going by your video, it could take ten or more seconds to close or open the window. Which is way too slow ! Try hooking up your 1200 rpm motor and see how much faster it would be ?
    A one touch would be nice. But 12 seconds is just way too slow.
    Time your side windows to see how long they take to go down.
  18. Jan 4, 2015 at 5:46 PM
    #78
    scratch
    I'll give it a shot when it's a bit warmer out, it's freezing out there right now.
  19. Jan 4, 2015 at 5:49 PM
    #79
    Rsoxfan1
    Rsoxfan1 Well-Known Member
    Mass
    2012 DCSB TRD Sport 4x4
    Very nice
  20. Jan 4, 2015 at 6:27 PM
    #80
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    Since you're no longer attaching a rack to the window and moving it with a gear, you could mount the motor and screwblock lower down and then attach an arm between the block and the window frame. (if this makes sense the way I described it) This way the motor, screw and screwblock would be lower and out of sight.
    Going back to the earlier design with the servo motor, if you were to attach the rack to the window frame, you could still drive it with a gear but on a shaft extension that would allow you to mount the motor lower as well.
    In either case you probably want to build some sort of cover over any rotating parts such as the screw/block or the gear/rack. This would help prevent someone's long hair from getting tangled up in the mechanism.
    I'm not trying to threadjack but I though you might want to build a little people protection in as well. :)
