Power sliding window mod info thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by excorcist, Jan 6, 2017.
  1. Feb 28, 2017 at 1:59 PM
    #121
    Citadel
    Citadel Well-Known Member
    thanks. I dont know the amp draw of the motor... maybe it is listed in the details on TIS?
  2. Feb 28, 2017 at 2:01 PM
    #122
    Citadel
    Is there a reason why this stock Tundra/ tacoma sliding window switch is harder to wire up that say the stock Sienna window switch?
  3. Feb 28, 2017 at 2:05 PM
    #123
    Bocsy44
    Bocsy44 Well-Known Member
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    This that and the other thing.
    if I had to guess I would say the sienna switch is a DPDT switch, the Tacoma one is not but I really don't know for certain
  4. Feb 28, 2017 at 2:23 PM
    #124
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    Man-o-man.....My $25.00 Impala window motor runs on a fused 10 amp circuit, run to a $8.00 DPDT toggle, without a relay. I know, I know...If there had been a problem with the circuit, I would have added a relay, but, for over a year, none. Motor runs to limits and stops, both ways. Battery feed wire to the switch is 14ga., from aux fuse circuit under the hood.
    kgarrett11 likes this.
  5. Feb 28, 2017 at 2:35 PM
    #125
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    but its not OEM bro hahahaha
  6. Feb 28, 2017 at 3:50 PM
    #126
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
    here is the diagram with the proper pinouts for the relays you need to use.
    Do not switch wires on pins 87 and 30, you will cause an instant short to ground.
  7. Feb 28, 2017 at 4:10 PM
    #127
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    could have used this a week ago! hahaha would have saved us a lot of head scratching lol a lot fancier then the hand drawn one on the last page that's for sure ahaha
    just a quick question tho. how come purple needs to be a switched source? why does purple need a 30amp fuse, its only energizing the coil in the relay, wouldn't imagine that drawing very much amperage. and last question haha how come purple and red require separate lines? could u not just tap them all off one main line? they would, in theory, both be coming from the battery anyways
  8. Feb 28, 2017 at 4:21 PM
    #128
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
    In short, I just went off the factory diagram - but it doesn't have to be 30a fuse feeding the switch. a switched source (purple wire) will be up to the end users preference. keeps the window from being operated when the vehicle is completely off.
    the factory has a third relay in the mix - not really required for the ones adding on to an older truck.
    05Taco4x4, Citadel and Bocsy44 like this.
  9. Feb 28, 2017 at 4:57 PM
    #129
    jbrnigan
    Midwest
    "but its not OEM bro hahahaha"
    You're right "bro".... but my window was working, the same day my install was finished, and still is, for $100.00 bucks total - LOL
    vssman and Bocsy44 like this.
  10. Feb 28, 2017 at 5:03 PM
    #130
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    :rofl: you got me there ;) I haven't even bought anything to start this mod hahaha just like staying in the loop cuz I will want to do it eventually :thumbsup:
  11. Feb 28, 2017 at 6:33 PM
    #131
    Citadel
    Fergyz is a hero!
  12. Feb 28, 2017 at 9:43 PM
    #132
    adio
    adio Well-Known Member
    HI
    2015 INFERNO TRD PRO
    @Up2NoGood @Bocsy44 Unfortunately it looks like Toyota tweaked those plastic bins for the 3rd Gens.
    You can actually see where they tweaked it after comparing the pic @Citadel provided of his bins to mines.
    Pictured is the bins that I took out on my 15. See where the anchor point symbols are(circled in red) that portion of the bin is flat meaning it would sit flush against the back metal panel.
    7AE8D715-B4BF-4F50-9055-18CD3AEF7CFC_zps_51bb9b715586ed57cd020d159189e890b188c3a6.jpg
    5D28F199-1C29-4472-B97C-EA350348B1BF_zps_d05daff51458cbefd15cd030c7435153ffc8adb0.jpg
    Where the 3rd Gens plastic bin has a slight hump to it to accommodate for that motor set up as pictured below. Now I wanna know if those bins would fit on a 2nd Gen, by looking at it, it seems like it would but not 100% sure. I'll be on the hunt locally since Tacoma owners seem to upgrade their sound system and they remove this bins to accommodate for those speaker box.
    7f9621c48d42263898074605e3ba26b6_zpstesq_7ddd9321e67970c4a9d106b64192ce54d56314c8.jpg
    Yes sir. Worst case scenario for me is to order some from Fastenal, unless someone knows where I could get some, maybe HD or Lowes?
    Any chance of taking a closer pic on this, appreciated. Zooming in just makes everything blurry.
    Awesome, thanks a lot for the input on the wiring @fergyz
    Bocsy44[QUOTED] likes this.
  13. Feb 28, 2017 at 11:04 PM
    #133
    adio
    HI
    Storage plastic bins on a 2016. That hump is more prominent looking at clearer pictures of it. Looking at it, it might just fit 2nd Gens since I don't see any major changes.
    a5a28aafb98eb3933380657bc96c70aa_zpscdi2_4337c76185e579972ae9c6b7101ead58abbc5f54.jpg
    5c9aa97c090210dfa317de1506f6becd_zpslfhb_ae9ab7586510b33eef53858d893f253fb380909f.jpg
  14. Feb 28, 2017 at 11:28 PM
    #134
    fishin1981
    fishin1981 Well-Known Member
    Richie
    NY
    13 dbl cab limited
    A sliding rear window should have been a factory option
  15. Mar 1, 2017 at 6:42 AM
    #135
    Citadel
    Are the latches/ hooks in the same place for the gen 2 as the gen 3?
  16. Mar 1, 2017 at 11:37 AM
    #136
    adio
    HI
    Seems like it. Toyota kept everything the same and just tweaked some.
  17. Mar 4, 2017 at 4:56 PM
    #137
    Citadel
    IMG_2751.jpg Any of you guys tried to wire the switch up yet?
    Also check out the image attached of the relays I will be using.
    Does it matter that the pins on the relay instructions don't match up with the guidance above from @fergyz ?
  18. Mar 4, 2017 at 5:14 PM
    #138
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    Ignore what's on that sheet of paper besides the actual pin # designations and wire it like the diagram fergyz posted. Terminals are designated the same for all these generic 5 pin relays, but the way you can wire them up can change based on application.
    Citadel[QUOTED] likes this.
  19. Mar 4, 2017 at 7:06 PM
    #139
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    I cant read what the writing says but I'm with JdevTac on this one. If you just focus on the relay itself it matches up. Look at the little diagram of the inside components of the relay, bottom left. 85 and 86 is ur coil Pin 86 from switch and 85 ground which matches. 87A is normally closed to Pin 30, so its important that 87A is a Ground and 30 goes to your motor. then 87 is your fused +12v.
  20. Mar 4, 2017 at 10:00 PM
    #140
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
    I agree with @JdevTac & @Bocsy44 - You can wire up a relay a few different ways, but in this case, it has to be a fairly specific. Most aftermarket lighting harnesses use a 4pin relay setup. The fifth wire (87a) would be an unconnected "live" wire in those setups and is not needed or warranted. The biggest thing to pay attention to is the actual pin numbers on the bottom of the relay (if there). The diagram that was provided by the vendor/Mfg is a fairly standard diagram.
    As long as you match wires to the specific pins laid out earlier, you're golden.
    hope this doesn't confuse anybody but it lays out the flow of electricity in this circuit
    UP
    Down
