Power sliding window mod info thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by excorcist, Jan 6, 2017.
  1. Aug 23, 2017 at 11:13 PM
    #161
    7ender
    7ender Well-Known Member
  2. Nov 25, 2017 at 3:48 PM
    #162
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Anyone do this in an access cab.
  3. Nov 25, 2017 at 4:03 PM
    #163
    bagleboy
    Scott
    Norcal, Santa Rosa
    Also, any advice on what to look for in a motor besides cable operation.?
  4. Nov 28, 2017 at 9:21 PM
    #164
    bagleboy
    Scott
    Norcal, Santa Rosa
    Just ordered a Sienna switch, razzers to the two others who were caught looking. I think I can braze/drill/tap some 1/8" x 1/2" metal(brass or steel) to make the brackets(need one for the shell as well). I might see about mounting the actuator for the shell window above the opening. Anyone put the switch in the armrest with the other window controls?
    excorcist[OP] likes this.
  5. Nov 28, 2017 at 10:09 PM
    #165
    excorcist
    excorcist [OP] Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    Your going to do two separate motors / brackets for your rear slider and your shell slider?
    Interesting idea about using the armrest for a mounting point for the switch, I have a double cab so I don't believe there is anymore room for switches.
  6. Nov 29, 2017 at 9:15 AM
    #166
    bagleboy
    Scott
    Norcal, Santa Rosa
    That's the idea anyway. Still early in the design stage so several options are on the table. I'm looking for 3 particular features in a regulator assembly, 2 rollers(some have just one with a fixed curved guide at the other end), dual spring cable stops(again some only have them on one of the cable housing stops), and lastly, wires terminating in a plug rather than an integrated plug so I can provide my own plug disconnect. The first feature is probably the least important.
    Since the windows already slide in a track the one that comes with the regulator is somewhat redundant, all that's really needed are the pulleys and even they can be eliminated if the cable housings are routed with a large enough bend radius. Eliminating the track is a big part of making this more feasible for an AC since there's less space between the sheet metal exterior and the plastic panel. Long enough cables/housings to mount the motor down at the level of the under seat cubbies is another. Doing that might require the use of Teflon coated cables and Teflon housing sleeves to minimize drag in the longer runs.
    I still have some studying to do on switch wiring to see what motors are most compatible with the sienna switch as well but using a relay should provide ample current to drive two motors.
    excorcist[QUOTED][OP] likes this.
  7. Nov 29, 2017 at 9:06 PM
    #167
    bagleboy
    Scott
    Norcal, Santa Rosa
    Fwiw if this can be done in an AC you could probably swap in a DC master window switch control panel and use the rear window switches for the cab and shell sliders. I just checked and since the AC has just the front row window switches, lock, and passenger controls lock there's room for a switch behind them. When it arrives I'll see if the Sienna switch can be mounted there cleanly otherwise I'll use one of the 5 empty spots left of the steering wheel. One advantage to having nothing is there's plenty of room for more shit.
  8. Feb 18, 2018 at 2:03 PM
    #168
    atebit
    atebit What's all this, then?
    The basement of the Alamo
    18 Inferno TRD OR 4x4 AC
    So, is there a DIY for this? Seems complicated enough to justify vs trying to price it together across ~170 messages in the thread
  9. Feb 18, 2018 at 2:08 PM
    #169
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    Rear Sliding Window
    84810-0C090
    82998-24290 JPN
    82998-12790 JPN
    bobsuruncle, stvhwrd, lo2hi and 2 others like this.
  10. Feb 18, 2018 at 9:14 PM
    #170
    atebit
    Thanks for the parts list. Maybe their’ll be a DIY someday...
  11. Feb 18, 2018 at 10:46 PM
    #171
    duckytw
    duckytw Well-Known Member
    Anyone have tips on how to connect the cables up to the track? Seems they are always too short on o e side or another. I think maybe 2 people... one to toggle the switch and the other to yank out some cable?
  12. Feb 19, 2018 at 4:30 AM
    #172
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    I know in my case I actually ran the cables to the window track, and then screwed them tight to the bracket while it was out of the channel. Once I got both sides mounted I then stuck it in the channel. Took a good bit of struggling to do it as a one man show. And this was after I had trimmed the cables to “just” make it to the bracket.
  13. Feb 19, 2018 at 2:03 PM
    #173
    duckytw
    Thanks, I may just do that because I have no idea how the winding mechanism manages to make both ends shorter no matter what I do.
  14. Feb 19, 2018 at 5:23 PM
    #174
    JdevTac
    Josh
    MD/GA
    2nd gen
    Yeah it’s sort of a crap shoot when there isn’t good tension on the cable ends and your trying to secure it. I had to supplement my setup with 2 cable tensioner like you find on bike brake lines to really dial it in. It will also help with taking out any minor slack down the line as the system breaks in.
    Skynet Surfer likes this.
  15. Feb 23, 2018 at 4:14 AM
    #175
    bagleboy
    Scott
    Norcal, Santa Rosa
    Likely one end is jammed. Probably have to open the spool to fix it and might need to replace the cable if it got kinked as that might make it hinky.
  16. Apr 18, 2018 at 12:28 PM
    #176
    bwawuz02
    bwawuz02 Well-Known Member
    Any idea if these will fit a 2nd gen?
  17. Apr 18, 2018 at 1:46 PM
    #177
    ajsabra
    ajsabra Fully locked 3rd gen
    Sin city
    2016 Tacoma DCSB 4X4 Manual
    Front suspension : Extended travel Kings with Total Chaos UCAS Rear suspension : Deaver progressive AAL w/out overload & Kings Rims : SCS SR8 17" Tires : Bfg KO2s 285/70/R17 ARB Compressor ARB Lockers front and rear with 4.88 gears Nitro 4.88 Gears TRD Pro Grill, and fogs Headlight BHLM Rigid Radiance 32 stealth mounted.
    they will, but you will need to either remove the plastic bins or find 2016 bins
  18. May 2, 2018 at 7:24 PM
    #178
    Skynet Surfer
    Skynet Surfer Well-Known Member
    Dis
    15 DC v6 SR
    Hood struts Weathertech floor mats Roll n lock bed cover With custom Yakima rack over the bed Poploc tail gate Bed mat Retrofit source led fog lights Hitch and or 4 pin wiring Or just random small crap!
    The 2015 and the 2016 bins are the same.
  19. Jul 4, 2018 at 6:45 PM
    #179
    thisnameisnowmine
    thisnameisnowmine Active Member
    Little confused, I want to do this to my truck. Can you post pics and the part number of the assembly? Is that all you had to purchase to accomplish this?
  20. Jan 12, 2020 at 2:01 PM
    #180
    xMaverickx
    xMaverickx Well-Known Member
    Jeremy
    New Brunswick, Canada
    2016 MGM Limited V6 4X4 DCLB
    Got a question if someone can answer it. I’m wondering if pin’s 85 and 87 off of the relays can be connected to the same 30A fused battery source, and if 87 needs to be on constant power or if it can be on a switched circuit as well.
