Power source for rear dashcam?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bikerscum, Mar 11, 2023.
  1. Mar 11, 2023 at 12:15 PM
    Bikerscum
    Bikerscum [OP] Well-Known Member
    2023 TRD Prem. OR 4 dr. short bed, Adv. Tech, LED headlights, Mag grey
    '23 TRDOR 4 dr.
    I'm putting a rear facing Garmin dashcam in my Tac. For power I'll need a constant 12v source as well as a switched 12v. Any convenient places to tap in back there? Go under the carpet to the center console?
    Tried to find a wiring diagram online but no luck.
    Thanks!
  2. Mar 11, 2023 at 12:34 PM
    dowNNshift
    dowNNshift Well-Known Member
    I had a similar dilemma last month when I was wiring up my rear facing Garmin Mini 2 as well.
    What I ended up doing was adding it to a 5A circuit of my Auxbeam controller. I then ran a new wire set through the cab firewall, then through the doorwell channel, then made a USB termination in the rear utility area. Turned out classy and works well. I can turn the rear camera on when needed with a simple press of a button.
    Auxbeam Switch:
    Wiring Lead Bundle that I created:
    Auxbeam Relay block:
    End Result with a decent view:
    AlwaysDirty likes this.
  3. Mar 11, 2023 at 12:44 PM
    caribe makaira
    Caribbean, Puerto Rico
    You'll find both at the amplifier connector.
  4. Mar 11, 2023 at 1:09 PM
    Bikerscum
    PERFECT!
    Thanks to all!
  5. Mar 12, 2023 at 10:20 AM
    TacOCD
    TacOCD Active Member
    CP
    Pennsyltuckey
    2022 BlueCrush Tacoma 4x4 TRD OFF Road DCSB Auto
    Black TRD Pro Wheels 21’ 6 Spoke; GY Duratrac 265/75/16; Head Rail; Rocky Mounts; Useless Interior Red Trim; TRD Shift Knob; Red Meso Start Button and Trims; Tint
  6. Mar 12, 2023 at 10:28 AM
    caribe makaira
    That would be a very long wire to the rear window.
    Chew likes this.
  7. Mar 12, 2023 at 10:38 AM
    TacOCD
    CP
    Pennsyltuckey
    Lol… yes very long! Likely an easy fix on a 2 door- Keep us posted on how it goes… enjoy and take care
  8. Mar 12, 2023 at 11:21 AM
    caribe makaira
    S31 Assembled harness to intercept the fused battery source.
    Connector is same as R44 on overhead console.
  9. Mar 12, 2023 at 11:37 AM
    caribe makaira
    Ground
    shakerhood likes this.
  10. Mar 25, 2023 at 2:54 PM
    Bikerscum
    I probed around pretty good & did not find constant 12v on the 24 pin connector. I did find it on the white wire on the top connector. I found 12v switched on the 24 pin, grey wire (see photo below, and yes I'll be covering that solder joint lol)
    Thanks to all for the help, camera is working perfectly!
  11. Mar 25, 2023 at 3:12 PM
    caribe makaira
    If you revisit post #3, it shows IGN (Switched) on the 24 pin (S23) connector and constant on S31, as you have it now.:smack::rofl:
  12. Mar 25, 2023 at 3:36 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Oh man, you guys are doing it the hard way if the camera is in the back window. For switched power, go off the ceiling mirror wire, for power, go up the A pillar from any hot lead on the fuse box with a add a fuse tap and then go along the headliner along the right side - you can stuff the wire under the headliner edge without having to take it down anywhere. Then in the back corner go down behind the back seat or up over it.
    beergeek and AlwaysDirty like this.
  13. Mar 25, 2023 at 3:38 PM
    caribe makaira
    :rofl::rofl::rofl:
  14. Mar 25, 2023 at 3:49 PM
    Bikerscum
    My reading of your diagram also showed 12v constant on pin 1&5 on the 24 pin connector.
    Shows what I know about wiring lol.
    Thanks again!
  15. Mar 25, 2023 at 3:52 PM
    Bikerscum
    Think I'll stick with the amp method, thanks tho :thumbsup:
  16. Mar 25, 2023 at 3:53 PM
    caribe makaira
    :hattip::thumbsup:
  17. Mar 25, 2023 at 5:00 PM
    OnHartung'sRoad
    No, seriously! ;) Or did I miss something?
    the routing I used on mine along the side of the headliner works very well and snuggly hides the cable from the mirror all the way to the back of the cab.
  18. Mar 8, 2024 at 1:17 PM
    DAS POWDER
    DAS POWDER Active Member
    2021 MGM TACOMA TRD OFFROAD, MT
    TRD Lift Kit, 17" TRD wheels, B&M short shifter, Oil catch can, extra bed tie-down points
    I have a 2021 trd offroad, does not have a sub or amp.
    Question is, can I use a 24 pin wiring harness to wire the back up camera into the S23 connector. Giving it a "plug and play" install.
    Im hoping that even without amp, the cables are still there. I haven't taken the rear apart yet to verify if male wiring harness is there.
    What are your thoughts on this?
  19. Mar 8, 2024 at 2:11 PM
    caribe makaira
    Test the pin at the unused connector for juice.
  20. Mar 9, 2024 at 9:58 PM
    DAS POWDER
    I just finished tearing the rear apart. The cable harness isn't there, so I guess I will have to try something else to get 12V to the rear dash cam.
