Power steering and Engine coolant flush
Discussion in 'Technical Chat' started by bajaracer, Apr 24, 2011.
  1. Apr 24, 2011 at 3:20 PM
    bajaracer
    bajaracer [OP] Well-Known Member
    Charly
    Chandler
    05 PRERUNNER DBLCAB SPORT 4.0
    AEM DRY BRUTE FORCE, FLOWMASTER 50 SERIES, 285/70/17 BFG'S AT KO2'S MOTO METALS 17X8 885's with 5100's LOUD STEREO
    Were always concerned about changing the plugs, oil, filters, tranny, an diff fluid BUT what about the engine coolant and powersteering fluids. Those two never get that much attention. How many of you have included this in your Maint Sched's and what type of fluids did you use? Thanks.
  2. Apr 27, 2011 at 8:11 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    I changed them both on my truck around 100k. I've got a 4 banger so the scheduled maintenance might be different for the 4.0.
    I drained the coolant from the radiator and the engine block. Then used Toyota long life coolant (the stuff specified in my manual) to refill.
    For the power steering, I followed a write up someone did on here. I flushed out the old fluid and used some AMSoil ATF to refill. I used the AMSoil because that's what I had on hand and it should do the job just fine. I think the manual says that ATF is okay to use, can't remember exactly what is specified though.
  3. Apr 27, 2011 at 6:52 PM
    monkey wrench
    monkey wrench Well-Known Member
    sean
    somerset, ca
    stock 4x4
    new stereo, rear leaf tsb, front 5100s @ .75. weather tecs and wet okoles.
    I flush the coolant in my veh. the newer toyotas use the ultra long life coolent so I flush around 100,000. I use the pink zerex "Asian car formula". I've only found it premixed at 50/50. I'm not sure why they don't sell it straight.
    I have never flushed a power steering system.
  4. Apr 27, 2011 at 7:13 PM
    bajaracer
    Charly
    Chandler
    would the toyota ATF IV tranny fluid work for the power steering since it asks for ATF dexron?
