Power Steering bad after applying breaks hard
Discussion in '1st Gen. Tacomas (1995-2004)' started by Markley, Feb 21, 2016.
  1. Feb 21, 2016 at 8:04 AM
    Markley
    Markley [OP] Active Member
    Hey all,
    I have a 99 Tacoma (4wd, 2.7L) with about 185,000 miles and have a number of maintenance needs (so I'll likely be posting a few threads). The first is that I am having issues with my power steering, mostly right after heavily applying the breaks (makes a loud "winding" sound and feels rough). From what I've read, it appears that I likely need a new pump? Anything else I need to consider? I'd like to make any necessary fixes myself.
    Thanks in advance.
  2. Feb 21, 2016 at 8:07 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Is the fluid at the right level?
  3. Feb 21, 2016 at 10:15 AM
    Markley
    Yes, the fluid appears to be fine so I'm pretty sure that there is not a leak anywhere. Also, at startup, I am getting a lot of squealing from somewhere (belts, bearings?), especially if the fan is on. Not sure if this would be related.
  4. Feb 21, 2016 at 1:38 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    U need to check those belts cause one of them runs the PS pump.
  5. Feb 22, 2016 at 5:13 AM
    Markley
    Yeah, I likely am due for new belts. From a visual inspection they look ok, but have not been changed in a while. Also, they do not see to be to loose. Although I'm not exactly sure how to check to see if the tension is to spec (did the turn 90 degree test?). I've read in other threads about cleaning the screen at the bottom of the reservoir, however I can't see how to get to it without removing the belt?
  6. Feb 22, 2016 at 6:09 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    when you suck air in the power steering it does this screaming while it bleeds itself
    so, the symptoms sound like: when braking it sloshes and sucks air, and the noise is that air bubble(s) routing
    back out
  7. Feb 22, 2016 at 6:11 AM
    Markley
    Thanks! So would there be a leak? Causing air to get sucked in?
