power steering blockage
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2002tacoma6bolt, Sep 29, 2016.
  1. Sep 29, 2016 at 8:10 AM
    2002tacoma6bolt
    2002tacoma6bolt [OP] Member
    saint john new brunswick Canada
    2002 tacoma 4+4 3400
    the pressure in the power steering system keeps blowing the return line off the rack.---my questions are----is there any check valves anywhere in the system also is there a screen in the reservoir----anyone know whats causing this? the truck is a 2002 tacoma 4x4 3400 engine--thank you
  2. Sep 29, 2016 at 8:20 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Is the return line clamped on good enough? Have you bled the system totally free of air? Is there anything between the return line from rack to reservoir?
    2002tacoma6bolt[OP] likes this.
  3. Sep 29, 2016 at 8:24 AM
    98tacoma27
    Ben
    Not Beech Creek
    Have you tried running it without the cap on?
  4. Sep 29, 2016 at 8:29 AM
    WinSlow939
    WinSlow939 Road Salt Life
    Nate
    The Rock, Mass
    2002 with some '99 thrown in for fun
    All the Money I Have
    There is a screen in the reservoir that gets blocked (remove it and put an in-line filter in) but enough to blow the return line, I think not :notsure:
  5. Sep 29, 2016 at 8:34 AM
    WinSlow939
    Nate
    The Rock, Mass
    I thought all the fittings on the rack were threaded!?
  6. Sep 29, 2016 at 8:35 AM
    2002tacoma6bolt
    texoma---i put 2 new clamps on both ends of return line at the rack---there is nothing between the rack and reservoir ---the line blew off twice while trying to fix it
  7. Sep 29, 2016 at 8:38 AM
    98tacoma27
    Ben
    Not Beech Creek
    it's a mixture of both...
  8. Sep 29, 2016 at 8:38 AM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    It sounds like you may still have air in the system. Bleed it down with the engine off, keep the res cap off, then start it and cycle the rack back n forth. Before anything, check that line for blockage.
  9. Sep 29, 2016 at 8:44 AM
    2002tacoma6bolt
    winslow939---the high pressure line is threaded but return is clamped-----i'll take out the screen ,see if it helps
    WinSlow939 likes this.
  10. Sep 29, 2016 at 8:51 AM
    2002tacoma6bolt
    98tacoma27----thanks for the diagram
  11. Sep 29, 2016 at 8:51 AM
    98tacoma27
    Ben
    Not Beech Creek
    I think you should take the return line off (or disconnect it at both ends) and try to blow through it.
  12. Sep 29, 2016 at 9:04 AM
    2002tacoma6bolt
    98tacoma27----roger that and will connect a hose to the reservoir take cap off and blow though that
  13. Sep 29, 2016 at 9:06 AM
    WinSlow939
    Nate
    The Rock, Mass
    good diagram, should of figured soft lines from reservoir had to connect into rack hard lines somewhere, derr
    with how many kinks there are in the return line, it might be good to give it a blast of air from a compressor if you have one, you might turn purple trying to blow air through yourself
  14. Sep 29, 2016 at 9:10 AM
    WinSlow939
    Nate
    The Rock, Mass
    oh, if your leaving it attached to reservoir, don't do compressed air, you'll have a power steering fluid party all over the engine bay. I meant if you disconnected the whole line and removed it from truck, then blow air through
