Power steering clarification
Discussion in '3rd Gen. Tacomas (2016-2023)' started by zenny, May 22, 2019.
  1. May 22, 2019 at 9:33 AM
    zenny
    zenny [OP] Well-Known Member
    2017 tacoma access cab TRD Off Road
    Hello everyone...you have always been so helpful so here goes. I have a 2017 Tacoma TRD 4x4 Off Road. I want to top off my power steering fluid. Here is the issue:
    When I purchased the vehicle, the color of the fluid is a clear amber color. Then I looked at my owners manual and it says to use ATF Dexron II or Dexron III. Well, the color of Dexron is RED. So there is a discrepancy in color between the fluid listed in the manual and the fluid in my Tacoma when I purchased it.
    I certainly want to use the correct fluid. I hesitate to add a red fluid to my clear amber fluid. I called Toyota.com and they told me that they are not sure why there is a discrepancy and to email them about the issue...thanks alot but no thanks.
    I really do not know what type of power steering fluid is in my Tacoma. Has anyone else had this issue? If so what did you find out? What is the solution to this issue/problem. What fluid can I use? I do not want to cause any damage and want to use the same color of fluid.
    Any assistance and your knowledge would be appreciated. Thanks in advance.
    Zenny
    Amorak likes this.
  2. May 22, 2019 at 10:03 AM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    It may be as simple as, the factory gets all the fluids in bulk, and the fluid they use in the power steering res. is not dyed.
    I dont know that for a fact, but its all I can think of.
  3. May 22, 2019 at 10:05 AM
    NJtaco421
    NJtaco421 Well-Known Member
    NJ
    17 DCSB Sport MGM
    Was your truck manufactured in Mexico?
    Might be a corona fill in there.
    Geneyota and Skydvrr like this.
  4. May 22, 2019 at 10:06 AM
    Bishop84
    Bishop84 Well-Known Member
    It's simply not dyed from the factory. It's transmission fluid but they have no requirement to dye it, thus cost savings.
    Factory top up is Toyota D/M but ANY transmission fluid works. You can use synthetic, non, dextron, mercon. It doesn't matter.
  5. May 22, 2019 at 10:07 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    If its going to worry you take it into the dealer.
    kahanabob likes this.
  6. May 22, 2019 at 10:31 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    How come ya need a top off anyway? Leak?
  7. May 22, 2019 at 3:31 PM
    zenny
    Thanks all for your replies. The following questions are in order:
    1. Saying that Corona is in if manufactured in Mexico is not helpful.
    2. I cannot find ATF that is not dyed. All that I have found is RED in color. Can I mix the Red Dexron with the amber color fluid that was in the reservoir when I bought the Tacoma?
    3. I do not have a leak...I just want to add to top off.
    4. The dealer cannot clarify why the owners manual says ATF Dexron II or III, which is RED and the fluid in the reservoir when purchased is amber in color.
    I am still unsure as to what fluid to use in my 2017 Tacoma.
    Any additional clarification is welcomed and thanks in advance.
    Zenny
    Amorak and ancient11 like this.
  8. May 22, 2019 at 3:34 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I went through this just a month ago when I flushed my system. Yes, it's Dexron that is not dyed. Pretty much any Dexron that is widely available has the red dye. It is compatible with the non-dyed Dexron. Hope that answers your question.
    Big tall dave likes this.
  9. May 22, 2019 at 3:40 PM
    Bishop84
    I bet you're loads of fun to deal with. If I could use a larger font I would.
    Go and buy Ford power steering fluid, it's not dyed and it will make you happy. Who knows what will happen to the pump, but at least its the right colour.
    bax, synaps3 and Boghog1 like this.
  10. May 22, 2019 at 4:19 PM
    Invid
    Invid Well-Known Member
    New Braunfels, Texas
    2016 Tacoma Limited
  11. Jul 3, 2021 at 12:54 PM
    va2va2
    va2va2 New Member
    I had the same issue with my Fj cruiser, I had to move my power steering reservoir to fit a large battery. I’ve heard that you need to drain all the old power steering fluid and fill it with new which is red, basically you can’t mix them, that’s what I’ve been told by Toyota dealer technician. It is relatively easy task, You need to remove this skid plat and at the bottom Of engine bay you can take one of low pressure rubber hoses out, And use one of those cheap oil pumps to suck all the fluid from steering system. The Oil pump hose perfectly fits on metal hose of power steering system and you can drain all the fluid. Just to be safe I drained it once and I filled the system with new red power steering fluid ran it for 10 min then did the process again and drain it so make sure there is no old fluid left in the system.
