Power steering fluid flush
Discussion in '2nd Gen. Tacomas (2005-2015)' started by beavis87, Oct 18, 2015.
  1. Mar 7, 2018 at 10:56 PM
    #41
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    My turkey baster is too wide for the PS reservoir opening. I used a 2-foot long clear tubing to suck out the PS fluid (don't remember if 3/8 or 1/2 inch OD). Took 3-4 'sucks' to get the fluid out. Used Valvoline Dex/Merc ATF in the blue gallon jug; it's Dexron III, and it's what Toyota recommends. The MaxLife ATF in the red jug is Dexron VI rated - in most applications, Dexron VI is backwards compatible to Dexron III. However, some folks, mostly GM, have recorded issues with DexVI in vehicles that originally called for DexIII, and mostly in transmissions. However, I choose to stick with DexIII since it is still readily available - $17 at Walmart, and the steering system is not a critical component that would benefit from DexVI.
  2. May 14, 2018 at 1:25 AM
    #42
    Brie
    Brie Well-Known Member
    Brieanna
    CA
    2001 Tacoma TRD, Prerunner & 2016 Taco Sport
    No such thing as a dumb question!
    "It's better to ask a question, even if you may be considered a fool for a minute, then to never ask - and remain a fool forever" - some wise quote guy! ;) (just sayin'!)
  3. May 14, 2018 at 7:19 AM
    #43
    SphericalCow
    SphericalCow Member
    Alternative view:
    "There is no such thing as a dumb question, only dumb people that ask questions." -One of my high school teachers :p
  4. May 14, 2018 at 7:49 PM
    #44
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
    I've been watching this thread for some time. I decided to go ahead and flush out the PS fluid today.
    I'll try to document what I did since the OP pics are gone.
    Here's before and after looking at the res.
    Before
    After its flushed
    Along the way
    First suck out the old fluid - btw I think this may be unnecessary? Why because once you pull the return line and direct it to a container and plug the res as soon as you start moving the steering wheel back and forth the res is drained really fast. I turned the wheel back and forth and checked and the res was empty :eek:. Oh well I figured I was going through several cycles so if it did suck a little air it would be pumped through and I had about 2 quarts left over from when I did the tranny flush. Anyway I sucked out the old fluid before I started using a baster some fuel hose and 3'8" tubing. Luckily it all fit together nicely.
    So as I said it drains fast so you must keep an eye on it and top it off constantly. It helps to have some small funnels. I had these and I'm glad I did (99c store I think)
    Next time I'll try to have someone inside turning the steering wheel so it would be much faster.
    This is what I had on hand and just filled a water bottle since I didn't want to pour from a gal jug.
    Here one showing the return line going into a clear 1L water bottle and the res plugged
    Anyway it worked out well and no mess! I counted 3 drops of fluid on the ground. Just a rag or two and a few paper towels later and it was all done. Here's the drain bottle the first time I pulled it up with old fluid vs new ATF
    Steering is smooth as butter now. :thumbsup:
  5. Jul 13, 2018 at 12:55 PM
    #45
    Babyruthless87
    Babyruthless87 Well-Known Member
    Joey
    2011 Tacoma TRD Sport DCSB
    Super great right up. I unfortunately can’t see any of the images I posted.
  6. Jul 13, 2018 at 1:33 PM
    #46
    CMD-KY
    CMD-KY Well-Known Member
    South Central Kentucky
    2104 Tacoma AC SR5 4wd
    I got most of mine exchanged using a baster every few days and emptying then filling the reservoir. Now, every time I change the oil, get the baster out and suck the reservoir dry and refill it.
    My fluid was quite dirty when I first started. after a few rounds with the baster, it became almost crystal clear. I noticed a difference at the extreme ends of turning, not a huge improvement but certainly noticeable. I am glad I did it.
    Lester Lugnut likes this.
  7. Jul 15, 2018 at 1:42 PM
    #47
    RHHousehold
    RHHousehold Well-Known Member
    CA
    2008 Access Cab TRD Offroad 4x4 V6
    I just followed this procedure on my truck - thanks for the write up. This is a great forum.
    I used a siphon pump to get the fluid out of the reservoir and used max life ATF with a small funnel directly into the reservoir.
    CMD-KY likes this.
  8. Jul 23, 2018 at 10:30 AM
    #48
    Shaneeck
    Shaneeck Member
    2010 tacoma Ted off road
    None
    Why can’t I see the pictures
  9. Jul 23, 2018 at 10:54 AM
    #49
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    OPs links are broken
  10. Jul 25, 2018 at 10:45 PM
    #50
    beavis87
    beavis87 [OP] Well-Known Member
    El Paso
    '10 Silver TRD OR
    Thanks HB Taco. Unfortunately I cant seem to find the original images anywhere to reupload but it's pretty straightforward and I'm sure you can find a video or the process on YouTube.
    HB Taco likes this.
  11. Aug 17, 2018 at 2:19 PM
    #51
    LGE RAW
    LGE RAW Well-Known Member
    Rob
    Dothan
    2020 TRD Off Road DCSB 6AT Magnetic Gray Metallic
    New Mods in the works.
    Did the flush today. Took quite a few pushes on the wheel to get the drain started, and seemed to go quicker when turning the steering wheel instead of pushing the tires from lock to lock. Made no sense! I flushed about a quart through it and had nice clean red Valvoline Max Life coming out the return hose. Went so quickly I decided to throw on 3 racks of baby backs on the smoker.... :)
  12. Aug 17, 2018 at 2:42 PM
    #52
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    What's the point of this? It's a sealed system and the discoloration just stems from heat.
    Are y'all worried that the fluid degrades so bad that it can't adequately lube the Gears any longer?
  13. Aug 17, 2018 at 3:12 PM
    #53
    Sandman614
    Tim
    '06 SR5 Off Road
    How often do you think it should be changed, if ever?
  14. Aug 17, 2018 at 3:14 PM
    #54
    TireFire
    Olympic Peninsula
    I don't know. It was an honest question. I wasn't trying to be an ass!
    Perhaps when the whole rack gets replaced is what I'm thinking
  15. Aug 17, 2018 at 6:44 PM
    #55
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Flush the system annually and you may not have to replace the rack.
    Norton and beavis87[OP] like this.
  16. Aug 17, 2018 at 7:25 PM
    #56
    beavis87
    El Paso
    '10 Silver TRD OR
    The fluid can become contaminated by the components inside as they wear and so all those contaminants will be recirculated through the system increasing wear, which usually will show as a leak and once it starts leaking you pretty much have to pull the steering rack out to fix or replace and that ain't cheap. There is no real filter in the system so it makes sense to replace the fluid every now and then or add a filter and just change that filter ever now and then, which is exactly what some members have done.
    reallifedog and E-Paz 732NJ like this.
  17. Aug 18, 2018 at 9:51 PM
    #57
    HB Taco
    Curt
    Once every 6 or 7 years is probably sufficient? at least for the first time. My truck was 7yo with 75k mi so I decided to do it since everything else has been done. I dont believe its called for in the maint schedule because it could go 15 + years before it takes a shit? But why not since its easy to do.
    RHHousehold likes this.
  18. Aug 21, 2018 at 3:59 PM
    #58
    dawgn86
    dawgn86 Well-Known Member
    2013 Toyota Tacoma
    I wish I could see the pictures
  19. Nov 22, 2019 at 2:01 PM
    #59
    wags
    wags Well-Known Member
    Walleye Capital of the World, Ohio
    2012 2.7L 5-Speed Manual SR5 4x4
    Today I flushed and filled my Power Steering system for the first time (91,205 miles). It took about 45 minutes and I took my bloody time. Fluid used was Valvoline ATF Dexron/MERC (Dexron III) as stated in my owners manual. I bought a gallon jug at Wally World for $13.97. And only used a little over a quart in the end!
    1. 1st Sucked out old fluid in reservoir until empty.
    2. Disconnected return line.
    3. Inserted plug on Reservoir inlet.
    4. Raised front tires off ground onto jack stands.
    5. Inserted a plastic line into return line then into a small clear jug.
    6. Filled reservoir with new ATF fluid then turned wheels slowly back and forth watching old fluid leave system.
    The power steering fluid currently in system was a BROWN. Not murky looking but BROWN. Once fresh red ATF fluid starting showing up behind the BROWN fluid I knew system was flushed and I added fluid two more times to the reservoir while turning wheels back and forth. Once reservoir was about empty I pulled the plug on return inlet and re-attached return line. No spills or mess. Then topped off system and took a 10 minute drive and back home. Once home made final top off and was completed. Did I notice a difference in my steering? Nope. But a piece of mind knowing system was flushed and I have new fluid for the next how many years. Very easy procedure.
    Micbt25, Buildit, nd4spdbh and 2 others like this.
  20. Jun 11, 2021 at 6:41 PM
    #60
    TheBlueBeast15
    TheBlueBeast15 Well-Known Member
    Kevin
    H-Town
    2015 Blue Ribbon Metallic TRD Off Road double cab short bed
    i have some extra Toyota ATF WS left over too. So is it ok to use that for the power steering? I just want to make sure.
