Power Steering Fluid Gen 3 Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tak07, Feb 28, 2024.
  1. Feb 28, 2024 at 2:34 PM
    Tak07
    Tak07 [OP] Member
    Grey 2017 Tacoma TRD Sport RWD
    None
    Got a leaky steering rack. I got atf castrol tansmax import multi vehicle; says meets requirements of dexron III H. This should be dexron atf fluid compatible with my truck? Also should I try and get out all the old dirty ps fluid and then refill? Will mixing two different brands of the same dexron compatible atf fluid not work out?
  2. Feb 28, 2024 at 2:37 PM
    HondaGM
    HondaGM CallSign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    This is what i use..good stuff
  3. Feb 28, 2024 at 2:38 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Mixing is fine as is that fluid, but I would recommend this:
  4. Feb 28, 2024 at 2:59 PM
    Tak07
    Tak07 [OP] Member
    None
    Would you recommend using conventional or synthetic blend atf in power steering for a gen 3 Tacoma? Thanks for keeping it real:thumbsup:
    tonered likes this.
  5. Feb 28, 2024 at 3:48 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You're welcome!
    Anything that meets the spec. But, I feel that particular Mazda stuff helped with the weeping that I had.
    Tak07[QUOTED][OP] likes this.
  6. Feb 29, 2024 at 3:04 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Would you by chance have a part# or link for the one you used? My boots have always been wet and I checked my fluid yesterday and it was a wee bit below the cold min line.
    tonered[QUOTED] likes this.
  7. Feb 29, 2024 at 3:18 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
  8. Feb 29, 2024 at 3:33 PM
    Technique
    Alex
    Utah
  9. Feb 29, 2024 at 3:46 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It was on the shelf because the Mazda 3 that we had for too short of a time needed some. I thought about heading to the local store, but I had some Amazon rewards points and couldn't argue with Free. :D
    I was pleasantly surprised that the specs matched and put some in the Taco.
    Technique[QUOTED] likes this.
  10. Feb 29, 2024 at 3:47 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Any red ATF is fine, doesn't matter if it's conventional or synthetic.
    Steering rack leaks are common, you're not going magically seal it up with any special fluid.
