Power steering fluid question.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Roger in AZ, Aug 27, 2019.
  1. Aug 27, 2019 at 5:46 PM
    Roger in AZ
    Roger in AZ [OP] Member
    Arizona
    2013 Double Cab 4X4 TRD Off-Road Package
    Is it okay to use Dexron-VI automatic transmission fluid for power steering fluid in my 2013 Tacoma? The owners manual says to use Dexraon II or III.
    Thanks
    Roger
  2. Aug 27, 2019 at 5:48 PM
    Thuguon2.7
    Thuguon2.7 Cheeehuuu
    J
    SoCal.
    ‘15 1GRFESR5AC
    You could for they are both hydraulic fluids. But I’d stick to what the manual says.
  3. Aug 27, 2019 at 6:35 PM
    Derk33
    Derk33 Well-Known Member
    Derek
    Pennylvania
    22 Army green TRD OR
    I believe all dexron numbers are backwards compatible. As in dexron 5 will cover all applications for dexron 1-4 but someone correct me if I’m wrong
  4. Aug 27, 2019 at 6:58 PM
    Tacomafella
    Tacomafella Member
    Nik
    Lake Elsinore California
    2013 Tacoma TRD sport
    Bilstein 5100's Method grid 309 Bfgoodrich k02 CBI aluminum skid plate Aero turbine muffler
    Yeah I think your right but I would still try to just stick to what the manufacture recommends.
    Thuguon2.7 likes this.
  5. Aug 27, 2019 at 7:01 PM
    Bishop84
    Bishop84 Well-Known Member
    Dex 3 is recommended, but honestly any red transmission fluid works.
    Dextron Mercon is Toyotas house brand, and I've used WS fluid in the system with good results.
    Dex 4 will be more than ok.
