power steering fluid question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JGreene_93, May 3, 2020.
  1. May 3, 2020 at 10:33 AM
    JGreene_93
    JGreene_93 [OP] Active Member
    Jon
    2017 Silver SR5
    Stock (Just bought)
    Is this what I’m supposed to use for power steering in my 2017 SR5? Does it matter that it’s “stop leak”? That’s all I can find
  2. May 3, 2020 at 10:37 AM
    Babybluetaco
    Babybluetaco Well-Known Member
    Austin
    Monroe, North Carolina
    09 5 lug
    Why not just store brand atf?
  3. May 3, 2020 at 10:38 AM
    JGreene_93
    Jon
    2017 Silver SR5
    Stock (Just bought)
    They don’t have any I’m at Walmart and my phone has 1% lol. Will this work?
  4. May 3, 2020 at 10:39 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Yeah, what @Babybluetaco said, I think you're looking for ATF in the power steering section. But look in the transmission section for "ATF"
  5. May 3, 2020 at 10:40 AM
    JGreene_93
    Jon
    2017 Silver SR5
    Stock (Just bought)
    It’s all right here together, power steering, transmission, everything
  6. May 3, 2020 at 10:42 AM
    Babybluetaco
    Austin
    09 5 lug
    Then your overlooking it
  7. May 3, 2020 at 10:43 AM
    Clearwater Bill
    Billy
    Largo Florida
    I would not use 'stop leak' in anything.
    And why a 17 needs fluid is a more important issue to solve.
  8. May 3, 2020 at 10:44 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    The manual states Dexron 2 or 3 ATF.
    The stop leak portion of that stuff is a pass for me. Is it going to swell and bust seals in the rack?
    4x4spiegel and shakerhood like this.
  9. May 3, 2020 at 10:45 AM
    Babybluetaco
    Austin
    09 5 lug
    Also Walmart sells
    Phone chargers get one of those to
  10. May 3, 2020 at 10:50 AM
    Clearwater Bill
    Billy
    Largo Florida
    Which were superceded in 2005(?) by Dex VI, which is fully compatible with all previous versions.
    (I think the manual is wrong)
    So OP you'll likely find Dex VI ATF in multiple brands with no issue
    splitbolt[QUOTED] likes this.
  11. May 3, 2020 at 11:01 AM
    JGreene_93
    Jon
    2017 Silver SR5
    Stock (Just bought)
    I’ve heard people get them from the dealer low on fluid before. I have a 17 and I just purchased it about 2 months ago and the power steering, coolant, and brake fluid are all low. I’m going to top them off and see what happens and if the levels lower again I’m going to take it back to the dealership and have them look
  12. May 3, 2020 at 11:03 AM
    JGreene_93
    Jon
    2017 Silver SR5
    Stock (Just bought)
    Yeah, I’m just going to get it somewhere else because that Walmart has a terrible selection when it comes to fluids.
  13. May 3, 2020 at 11:04 AM
    splitbolt
    NW Arkansas
    It's debatable that Dex VI is backward compatible as a power steering fluid, as GM/AC Delco has their own proprietary power steering fluid.
    Go to 2:12
    TaCoLoCoMaN likes this.
  14. May 3, 2020 at 11:14 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    no to Stop leak, if all your fluids are low take it back to the Dealership to top them off
  15. May 3, 2020 at 11:18 AM
    JGreene_93
    Jon
    2017 Silver SR5
    Stock (Just bought)
    Yeah, I didn’t get that. This is the first Toyota I’ve ever owned. I last owned a Ford where you use power steering fluid for power steering :rofl:
  16. May 3, 2020 at 11:25 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    My Ford takes Type F ATF in the power steering.
  17. May 3, 2020 at 11:41 AM
    BillsSR5
    bill
    2014 SR5
    they got nice free bagels,donuts,coffee,water while you wait at the Toyota dealership :toyota:
    Junkhead likes this.
  18. May 3, 2020 at 1:34 PM
    Sep1911
    Sep1911 Well-Known Member
    2016 Taco
    They dont use the proprietary stuff in all applications. Most of their newer vehicles use Dex 6. The argument that Dex 6 is not as good as Dex 3 for power steering fluid is that it's a thinner fluid. Although that's true, dex 6 is much more shear stable and wont thin out the way dex 3 will over it's useful life. I used to work from GM hence I know a lot about their fluids. I have about 4-5 gallons of dex 6 sitting in my garage that I cant get rid of so I've been servicing my 2016's power steering system with it, in hopes of eventually using it all up. No problems so far. Theoretically dex 6 will flow better and you'll have a smoother power steering system in the cold. I havnt noticed any major differences but where I live we typically get winters in the 30F, with occasional 20F temps. It'll probably be more noticeable closer to 0F.
    At the end of the day, the fluid is used a hydraulic fluid and you need a fluid that is compatible with your seals. I would just buy a quart of Mobil 1 ATF, or some other synthetic ATF and service your power steering fluid with it once a year. No need for a flush or anything, just empty the reservoir and top it back up. It'll save you the headache of having to deal with an actual flush once your truck is closing in on 10 years and the fluid is all black with build up in your reservoir.
  19. May 3, 2020 at 1:38 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Why are these fluids low? They're all closed systems?
    Normal for the brake fluid level to drop a small amount as the pads/shoes wear. That doesn't mean it's actually low
    Clearwater Bill, over60 and BillsSR5 like this.
  20. May 3, 2020 at 2:17 PM
    splitbolt
    NW Arkansas
    Cool...you'd be the guy to ask then.
    Doesn't GM only advise GM/AC Delco Dex VI as a substitute for non-GM power steering that require Dex III?
