Power Steering Fluid Top off
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaMike37, Oct 30, 2018.
  1. Oct 30, 2018 at 8:45 AM
    TacomaMike37
    TacomaMike37 [OP] Well-Known Member
    13' DCLB MGM
    What ya'll use when you had to flush/top off your power steering fluid?
    Need to top off my power steering fluid. It's a touch below the cold low mark.
    Manual says to use Dex 2 or 3.
    Was going to use this Super Tech MERCON V as it can be used for vehicles that call for Dex 2 or 3 :
    Super Tech MERCON V
    https://www.walmart.com/ip/Super-Te...hguid=7189a176-7ee-166c5a359fd2b9&athena=true
    Details:
    Super Tech MERCON V Automatic Transmission Fluid, 1 Quart:
    • Uses a unique combination of conventional base stocks and an advanced additive technology
    • Meets the performance requirements of Ford automatic transmissions calling for MERCON V fluid
    • Suitable for use where the following automatic transmission fluids are recommended:
      • Chrysler 3 and 4 (except C-604 transmissions)
      • DEXRON II (E, F)
      • DEXRON III (G, H)
      • DEXRON VI
      • Honda Z-1
      • MERCON
      • MERCON LV
      • MERCON SP
      • Nissan Matic-J
      • Toyota T-IV or Toyota WS
    • Not for use in vehicles requiring Ford Type F fluid or Continuous Variable Transmissions (CVTs)
    • Super Tech transmission fluid provides protection against wear and transmission shudder
    • Resistant to thickening due to high temperatures
    • Provides friction stability to maintain smooth consistent shift performance
    GrandTheftAngel likes this.
  2. Oct 30, 2018 at 9:47 AM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    I did a full flush of power steering fluid and I used Valvoine MaxLife synthetic ATF. I also use that in the transmission.
  3. Oct 30, 2018 at 10:19 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    You can't go wrong if you use what the manual calls for.
  4. Oct 30, 2018 at 11:28 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    thats what i used, 7 bucks n change at the autoparts store for synthetic fluid. Ill take that.
    inwood customs likes this.
  5. Oct 30, 2018 at 11:37 AM
    TheDevilYouLove
    Marylandistan
    $18 for a gallon of it at Wally World! Mixed with acetone it makes a heck of a penetrating lubricant as well.
    nd4spdbh[QUOTED] likes this.
