Power steering fluid
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Peru, Sep 28, 2010.
  1. Sep 28, 2010 at 5:16 PM
    Peru
    Peru [OP] Well-Known Member
    Jonathan
    Redmond WA
    SR5 -- V6 -- 2005 -- 4X4
    none
    was checking the PS fluid and noticed it was an amber color and i also noticed that it listed dexron ATF on the cap. ATF is always red so i went to the dealer. They tell me its not supposed to be ATF so i show them the cap.
    Then starts the backtracking, well this that and another. I bought it from them and it was one of these precertified deals so i assumed they may have changed it out with the wrong fluid and i thought i had them in BS mode. I asked them to show me some of the new trucks on the lot and they all have the same fluid -- so i felt bad. They then show me the fluid they use to service the PS fluid and its some BG product that is also amber colored. On the container all it say is its good for some foreign manufacturers.
    So, what if anything has everyone here done to the PS system. In the past i used to flush the system out. Anyone here done anything similar or just leave it alone? what did you use?
    1Shifter likes this.
  2. Sep 28, 2010 at 5:25 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    When I flushed mine I used ATF. I don't know if it matters or not. The only area I could think a problem would arise is with the deterioration/swelling of the seals. PS fluid is after all just a hydraulic fluid to be used as a medium by which power is transferred.
  3. Sep 28, 2010 at 5:51 PM
    Peru
    Jonathan
    Redmond WA
    none
    On my ford or other vehicles id use the turkey baster method. Draw old oil out till container is empty fill with new turn steering wheel back and forth and repeat a few times till oil is somewhat red again. I'd do this every 15 to 20k. The Tacoma has a fill hole which makes that method difficult or better said impossible.
    Did you do a place input hose in container with new fluid and output in empty container and work the system till all the new oil was drawn in to the system and the old oil flushed out then reconnect container and fill to proper level.
  4. Sep 28, 2010 at 5:57 PM
    Fortech
    CANADA
    Yes, very easy to do with an old 2 Liter pop bottle or similar.
  5. Sep 28, 2010 at 6:15 PM
    Peru
    Jonathan
    Redmond WA
    none
    So input is the large Diameter one?
    Btw -- thanks for the info
  6. Sep 28, 2010 at 6:29 PM
    Peru
    Jonathan
    Redmond WA
    none
    So I am thinking if I disconnect the output/discharge line and rout it into into the 2liter bottle and plug off the opening to the oil resaviour I leave the input connected and start filling while someone works the steering back and forth till oil discharging into the 2liter bottle is red again reconnect and fill to proper level and I am good to go.
  7. Sep 29, 2010 at 5:41 AM
    romafern
    romafern Hug diz nuts
    Rob
    80918 Let's meet!
    Paid for and saving a shit ton of $$$$$
    Thinking of adding a second battery...
    tagged.
  8. Sep 29, 2010 at 11:57 AM
    Fortech
    CANADA
    Remove the return line, which I believe is the top one if memory serves. Run the new fluid through the system until you see it in your pop bottle (or similar).
    Very, very easy to do.
  9. Sep 29, 2010 at 1:13 PM
    hate2work
    hate2work Well-Known Member
    Washington State
    06 standard cab
    Did a complete flush on mine this summer, very easy. Route the return line( top one) to a bottle, raise the front of the truck off the ground, then simply turn the steering wheel lock to lock which pumps the fluid through the system and at the same time continue to refill the resorvoir with new fluid. I used Amsoil ATF.
    yotaTom likes this.
  10. Oct 3, 2010 at 11:55 PM
    Peru
    Jonathan
    Redmond WA
    none
    Thanks for the info -- I'll do it this next weekend
  11. Feb 8, 2011 at 5:08 PM
    Foxer
    Foxer Well-Known Member
    U.S.A.
    Access Cab PreRunner
    What is the fluid capacity of the power steering system??
    I went to Toyota and got a printout of all the fluid capacities for my 06 Prerunner v6 and the PS Capacity is BLANK.
    I can't find a straight answer searching the forums or online.
    It would be nice to know exactly how much to buy....
    Anyone know???
  12. Feb 8, 2011 at 5:23 PM
    MassTaco
    MassTaco Well-Known Member
    Massachusetts
    V6 4x4 SR5 DC AT5
    Exactly, this is what I did. I used mobil 1 ATF and installed a magnefine filter on the return while I was at it.
    It took less than a quart before fresh ATF was coming out of the return line. After I reconnected the return and topped it off I had used just under a quart.
  13. Feb 8, 2011 at 8:26 PM
    Foxer
    U.S.A.
    So 2 quarts will be plenty.
    Thanks,
  14. Feb 8, 2011 at 10:17 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I know for certain...the 1st gen trucks use ATF in the power steering system.
  15. Oct 16, 2011 at 8:12 PM
    BoTacoGA
    BoTacoGA Damit man
    Bo
    Newnan, GA
    08 Rugged OffRoad TRD
    Hid headlights an fog lights, LED blinkers an brake light bulbs. anytime fog light mod, brighter reverse light mod, Access Vanish bed cover, color match grill, black rocker guard painted skid plate, rear TSB, 5100's with front set at 1.75, BF T/A KO 265/75/16, yo mama riding shotgun.
    Anyone ever use Toyota WS trans fluid in the PS?
  16. Oct 17, 2011 at 2:35 AM
    Wallygater
    Wallygater Well-Known Member
    USA
    '11 SR5 DBL Cab 4x4 6 speed
    Softopper, All-pro bolt-on sliders, Tom Wood's drive shaft, Goodyear 235/85/16 Dura-trac's, SG, USA-Spec I-pod adaptor, Amsoil in everything
    I did it like this on my old truck and I couldn't fill the reso fast enough while my friend turned the wheel. On my new truck I have been doing it the lazy/ignorant way. Every few months, I have been draining the reso with a syringe and then adding back Amsoil ATF. After about 317 times doing this I should have all Amsoil in there. :p
  17. Oct 17, 2011 at 4:33 AM
    BoTacoGA
    BoTacoGA Damit man
    Bo
    Newnan, GA
    I just followed the return line down to its source an removed it to let it drain. Refilled an did it again. I'm going to do it twice tonight too before I install the ps cooler.
  18. Oct 17, 2011 at 8:22 AM
    Wallygater
    USA
    Please post a write up on that ^^^^:cool:
  19. Oct 17, 2011 at 8:47 AM
    BoTacoGA
    BoTacoGA Damit man
    Bo
    Newnan, GA
    LOL, I'm not that good at explaining things but i'll try an get some pics. The source of the return line is right behind the driver side wheel. Its the one with the hose clamp not the hard line next to it. If that helps any. We should try an get Chris4x4 to write one up.
  20. Oct 17, 2011 at 5:27 PM
    BoTacoGA
    BoTacoGA Damit man
    Bo
    Newnan, GA
