power steering fluid
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pudge151, Dec 7, 2010.
  1. Dec 7, 2010 at 2:32 PM
    pudge151
    pudge151 [OP] Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    i was checking my fluids today and i noticed that it was low. it says to use Dextron Type ATF. I have a half quart or Dextron III / Mercon Auto Trans Fluid. It is red in color while the fluid in the truck looks like motor oil. Is this the right stuff to use? or is Dextron III ATF not the same as Dextron ATF?
  2. Dec 7, 2010 at 3:12 PM
    TRDKenE
    TRDKenE DAMN GOOD DEAL!!
    Kenny
    Richmond, Virginia
    '10 D-CAB OFF-ROAD 4X4
    TRD CAI, GrillCraft.
  3. Dec 7, 2010 at 3:16 PM
    pudge151
    Sean
    Connecticut
    yes is the right stuff or yes its Dextron III is not the same at Dextron
  4. Dec 7, 2010 at 3:37 PM
    boonduff
    boonduff Proud American
    Gordie
    Chandler, AZ
    2011 DC TRD OFFROAD
    Bone stock brand new
    Yes its the right fluid. If the fluid in your truck is that dark it should be changed.
  5. Dec 7, 2010 at 3:38 PM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    The service manual says Dexron II or III ATF, so you are good to go. The fluid will discolor over time due to moisture, heat, contamination...
  6. Dec 7, 2010 at 3:56 PM
    pudge151
    Sean
    Connecticut
    its not dark its golden color like new oil
  7. Dec 7, 2010 at 3:57 PM
    pudge151
    Sean
    Connecticut
    thanks
  8. Oct 16, 2011 at 8:15 PM
    BoTacoGA
    BoTacoGA Damit man
    Bo
    Newnan, GA
    08 Rugged OffRoad TRD
    Hid headlights an fog lights, LED blinkers an brake light bulbs. anytime fog light mod, brighter reverse light mod, Access Vanish bed cover, color match grill, black rocker guard painted skid plate, rear TSB, 5100's with front set at 1.75, BF T/A KO 265/75/16, yo mama riding shotgun.
    Anyone ever use Toyota WS trans fluid in the PS?
  9. Oct 16, 2011 at 10:48 PM
    saugus
    saugus Well-Known Member
    Mine was like that too. I flushed it and added dex.
