Power Steering Fluid?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kevinztaco, Mar 17, 2018.
  1. Mar 11, 2020 at 11:50 AM
    shaeff
    shaeff Roaming Around
    Hudson Valley, NY
    '07 DCSB SR5 6MT 4x4
    I am reasonably certain the PS cap tells you to use Dexron ATF.
    I used Valvoline full synthetic when I replaced my rack last year.
    Micbt25 likes this.
  2. Mar 11, 2020 at 5:31 PM
    No Shoes Nation
    No Shoes Nation Well-Known Member
    2008 Taco SR5 Access Cab 4.0 4x4
    Hmm . . . none as yet, that's why i'm here . . .
    Valvoline MaxLife Synthetic ATF best stuff to use
    Micbt25, ABNFDC and shaeff like this.
  3. Mar 14, 2020 at 7:13 AM
    Joetee
    Joetee New Member
    Joe
    2016 Tacoma SR5
    Does it matter what year? Mine is a 2016.
  4. Mar 14, 2020 at 7:51 AM
    ABNFDC
    ABNFDC Well-Known Member
    Granite State
    2008 4WD Access Cab TRD OR "Rugged Trail"
    265/75/16 Wildpeaks, Dakar rear, HS 2.5" front coils
    Have you tried your owner's manual? They typically reside in the glovebox and can also be found online.
    https://www.toyota.com/owners/resou...se&csrfToken=15841964999067765803137174601218
    Fluid type Automatic transmission fluid DEXRON® II or III
    https://www.valvoline.com/our-products/automatic-transmission-products/maxlife-multi-vehicle-atf
    Recommended for the following applications:
    GM DEXRON® II, III and VI
    Toyota WS
    You also have:
    https://www.valvoline.com/our-products/automatic-transmission-products/dexron-vi-atf
    DEXRON-VI
    DEXRON-II
    DEXRON-III
    Mercon LV
    Of the two, I would use Maxliife. I do use Maxlife in both my transmission and my power steering. Your 2016 owners manual may require different fluid for the transmission, but Maxlife will work for your steering.
    USMC6521 likes this.
  5. Mar 14, 2020 at 9:41 AM
    Joetee
    Joetee New Member
    Joe
    2016 Tacoma SR5
    Yes I did. That's why I asked about the MaxLife.
  6. Mar 15, 2020 at 7:02 AM
    tathambenjamin
    tathambenjamin Well-Known Member
    ben
    2008 4Runner SR5
    -2.5/1.5 spacer lift -270/65/17 Cooper AT3
    Use atf- I put that same stuff you pictured in a while ago and got immediate leaking at lower rack seals. Turkey basted it out for atf and leaks stopped. Never listen to the guys who work at the auto parts store...I am in no way a mechanic and frequently know more than the auto parts kid. I had to explain in about 4different ways what a paint marker was the other day. “You know when you go to the junkyard and buy parts and there is writing on them?”
    Him: ....”no, I’m not sure”...ok, you know a sharpie marker? Like that but with paint... but I digress. ATF
  7. Mar 15, 2020 at 7:42 AM
    ABNFDC
    Granite State
    Can I suggest that instead of doing the turkey baster thing, just flush the power steering all at once.
    See post 8(by me) in this thread. https://www.tacomaworld.com/threads/power-steering-fluid-question-red-vs-brown.525029/#post-16722279
    Then follow the thread link link to the method used by hladun. You can buy plugs like rubber vacuum caps for the steering reservoir in the "help" sections at any big box auto parts place like Autozone, Advance, Oreillys, etc.
    Other than jacking up the front end, it only takes a half hour.
    2WD and Kolter45 like this.
  8. Sep 5, 2021 at 5:24 PM
    blur
    blur Well-Known Member
    I plan to flush my PS fluid soon and picked up 2 qts of Mobile 1 synthetic ATF https://www.walmart.com/ip/Mobil-1-Synthetic-Automatic-Transmission-Fluid-1-Quart/143537399?wmlspartner=wlpa&selectedSellerId=0&adid=22222222222000000000&wmlspartner=wmtlabs&wl0=e&wl1=o&wl2=t&wl3=10352200394&wl4=pla-1103028060075&wl5=&wl6=&wl7=&wl10=Walmart&wl11=Online&wl12=143537399_0&wl14=Mobil1 synthetic atf&veh=sem&msclkid=e03616ab250b14197b39779e7b761549&gclid=e03616ab250b14197b39779e7b761549&gclsrc=3p.ds
    The manual just says Dexron 2 or 3 and the bottle says this, so I’m assuming I’m good but looking for confirmation from someone that may have used the same fluid. Will this stuff work and will 2qts be enough for a flush?
    GMDEXRON
    GMDEXRON II
    GM DEXRON IID
    GMDEXRON IIE
    GM DEXRON IIiG
    GM DEXRON IIIH
  9. Sep 5, 2021 at 6:32 PM
    igno1tus
    igno1tus Small member
    Lehigh Valley Area , PA
    '07 Tacoma Access Cab TRD Off Road
    I use it in the ps , does a great job at conditioning the seals (I have a weep) …. How’s it in the trans ?
  10. Sep 5, 2021 at 6:32 PM
    igno1tus
    Super easy to flush
  11. Jan 6, 2024 at 3:41 PM
    SRick
    SRick Well-Known Member
    Rick
    2017 White Tacoma SR Access Cab Utility 4x4, 4 Cyl/5 SpdMT
    - ECGS Front 4x4 Needle Bearing Replacement Bushing - RCI Tacoma Skid Plate - Cooper, Discoverer AT3 4S, 265 /75 R16 116T SL OWL - 16" Dark Anthracite Alloy Wheel, PT94635160 - A/C Condenser Hose reroute - OEM all weather mats / OEM door sill protectors (stock) - Installed Intermittent Windshield Wiper Switch Assembly - Installed Towing rear light kit-4 wire - Installed Draw-Tite Max-Frame Trailer Hitch Receiver - Custom Fit - Class III - Installed CLAZZIO Leather Seat Covers, Gray - RCI Tacoma Gas Tank Skid Plate (on order) - RCI Tacoma Rock Sliders Rock Sliders
    Hate to revive this thread, but I have a ton of ATF Dexron IV. Can this be used in place of ATF Dexron II/III for power steering fluid in a 2014 and 2016 Tacoma?
  12. Jan 6, 2024 at 4:31 PM
    Micbt25
    Micbt25 Well-Known Member
    TM
    2015 MGM TRD Sport Access Cab 4X4 V6
    I’m petty sure dex 4 is backward compatible to dex 3. I would suggest Valvoline MaxLife.
  13. Jan 6, 2024 at 4:37 PM
    SRick
    Rick
    I should have been more specific, Toyota ATF Type T-IV
