Power steering fluid
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Brendanp412, Apr 16, 2022.
  1. Apr 16, 2022 at 12:40 PM
    Brendanp412
    Brendanp412 [OP] Member
    2018 toyota tacoma trd off road
    Ok, I have a 2018 Tacoma TRD off road with alil under 52k miles. The power steering fluid is low and has never been flushed or changed let alone topped off. the dealership is saying the will not top it off with fluid cause they will contaminate it. They said they have to flush the system to fill the system. Had anyone run into this issue, is this a common issue or a thing that actually needs to be done?
  2. Apr 16, 2022 at 12:53 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Run!
    More seriously...
    Is the truck at the dealer for this issue alone or was this "discovered" during part of another service?
    First, is the fluid just low in the reservoir, that is still showing on the stick and just below the "add" line? If so you can refer to section 7.3 Do it Yourself Maintenance (pg 461 in my 2017 manual) for the easy procedure.
    If the system is dry and the pump is making bad noises you add fluid the same way obviously but must address the question of where did the fluid go?
    Who has been doing your routine maintenance if the fluid has never been topped off, that is part of a regular oil change.
    SpanishTaco likes this.
  3. Apr 16, 2022 at 1:01 PM
    Clearwater Bill
    Billy
    Largo Florida
    That's gotta score pretty high on my 'what a crock' list of statements.
    Someone was out fishing that day about the time you came by.
    Warranty or recall is the only reason to ever darken the door of that place again.
    It's foolery like that that creates poor reputations for repair shops. And hurts the overall business in the long term, including the honest techs who try to make a living working there.
    kahanabob, JJ Diablo and zoo truck like this.
  4. Apr 16, 2022 at 1:16 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    When my steering rack began to leak on my tundra, i filled the reservoir with some leftover atf i had. After all i had nothing to lose. This was going on for several months adding more, and more tranny fluid till the leak got way worse. Then it was adding this lucus power steering stop leak stuff. That worked good for about a month to slow the leak till my driveway said no more, its time to replaced that rack.
    I doubt adding new power steering fluid to the old has any affect to contaminate the system. I've done the same with brake fluid with no ill results.
  5. Apr 16, 2022 at 1:40 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Many moon ago, I had a Volvo 240 wagon and it developed a power steering fluid leak down at the rack & pinion assembly. Being too poor to spend money on fixing it (it needed a complete new rack and pinion assembly) I would drive it to work and put an empty margarine tub under the car to catch the fluid. When I went to leave work to head home, I would pour the fluid back into the reservoir, using a small hand held kitchen strainer to filter out the dead bugs. I did this for several years without any issues before I sold it.
    Moral of this story; top it off with some quality power steering fluid and have a nice day.
    05 4x4, joeyv141, TartanEagle and 2 others like this.
  6. Apr 16, 2022 at 3:13 PM
    mquibble
    mquibble Well-Known Member
    Michael
    2021 TacomaTRD Pro
    I applaud your commitment.
  7. Apr 17, 2022 at 4:05 AM
    JJ Diablo
    JJ Diablo Well-known member.
    JJ.
    CT
    2021 Cement TRD Sport Premium
    BOSS HTX Snowplow, Bilstein 5100s, Vled reverse light kit, Vled interior lighting, FitCamX dashcam, Timbren SES
    Ahh yes. The contamination of old fluid by adding NEW fluid. You definitely dodged a bullet there. Good thing they didn’t top you off..
    Im kidding, that’s the second dumbest thing Ive heard from dealership this week.
    05 4x4, kahanabob and TartanEagle like this.
  8. Apr 17, 2022 at 4:11 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    A DIY PS flush is simple enough to do. Topping off is even simpler.
    shotgunbilly420 and zoo truck like this.
  9. Apr 17, 2022 at 6:21 AM
    Spacecoast
    Spacecoast Well-Known Member
    2022 White SR5 2.7L
    Trailer wiring kit, hitch, seat risers
    Does that also apply to the fuel tank, or washer fluid, or coolant?
    kahanabob likes this.
  10. Apr 17, 2022 at 8:52 AM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    i have a 50ml syringe that i suck out all the PS fluid in my reservoir and just top off with new fluid. It's not a 'full' flush, but doing this every 3 months or when i remember, keeps the fluid looking pretty new and prevents me from having to do a full flush down the road. I've done this for the past 10 years with all my cars and never run into any significant PS issues, leaks, etc
    05 4x4, JJ Diablo and RustyGreen like this.
  11. Apr 17, 2022 at 8:56 AM
    baltimorebirds2
    baltimorebirds2 tacomama
    Brooks
    Maryland, United States
    2018 MGM Tacoma TRD Sport DCSB 4x4
    TRD Pro 17” Wheels, Toyo Open Country AT3 33s” (255/80/R17), Hooke Road Offroad Roof Rack, LEDs (Low Beams, High Beams, Fog Lights, Interior Lights, Reverse Lights, License Plate Lights), Diode Dynamics SS3 Sport Fog Lights (Yellow), Sequential Turn Signals, OME Nitrocharger Plus, OME 4004's & HS 0.5 Spacer for 3" Lift, JBA UCA, Icon RXT Option 2 Leaf Springs 2.25" Lift, Yukon Clamshell Bushing, Alpine ILX W-650 Stereo, Infinity Primus 6004a Amplifier (140w*2), Sound Ordnance M75-4 Amplifier (75w*4), Infinity Kappa 693C Component 6x9 Speakers, Infinity Kappa 63XF 6.5 Speakers, TRD Shift Knob, Black Emblem Overlays, TRD Grille Badge, OEM Door Sill Protectors, Driver’s Seat Jackers, Pop and Lock Power Tailgate Lock, AJT Designs start button and trim, 4x4 knob, shifter trim, and cupholder trim, MESO Customs Vent Rings and Door Handle Covers, Gasshole, Drop Stops, AC Drain Mod, Bed Lights, Rough Country Roll Up Tonneau Cover, Window Tint, KDMAX Tune
    I think from the factory, they aren’t filled to the max, maybe to minimum or a little below. I would honestly just flush the PS fluid my disconnecting the return line, running it into a container, plug the reservoir, add new fluid, and then just start turning the wheel with the truck jacked up. Then just keep adding fluid until the fluid coming out of the return line is clean, then you’re good.
    JJ Diablo likes this.
  12. Apr 17, 2022 at 10:14 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    My method too. Vac out and refill the reservoir every oil change (or two) keeps the fluid nice and clean without much effort.
  13. Apr 17, 2022 at 10:22 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    I just do a couple of drain & fills at the reservoir with a suction gun every 5 years or 60k. It takes Dexron III transmission fluid. My local dealers carry Mobil ATF D/M which is compliant to the Dexron III standard.
    If the fluid is low, though, check your steering rack boots for signs of seepage. You may need a new rack. Known problem with 2nd gens that Toyota hasn't fixed with 3rd gens.
  14. Apr 17, 2022 at 10:24 AM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    I also do that in the brake master cylinder
  15. May 3, 2022 at 5:57 PM
    ScodyDood
    ScodyDood Member
    Sean
    2013 White Tacoma TRD Sport
    N/A (Yet ;})
    What fluid do you guys recommend? I’ve read around and some people are saying don’t use synthetic in the power steering and some people are?
    Never thought power steering would be a hassle topic but here I am… hassled.
  16. May 3, 2022 at 6:31 PM
    JJ Diablo
    JJ.
    CT
    Dextron III Atf
    Tacowin1013 likes this.
  17. May 4, 2022 at 5:16 AM
    rnish
    Tacoma 2nd gen
    Currently using Valvoline MaxLife for Transmission and PS
    OregontoBajaCA likes this.
  18. May 4, 2022 at 5:22 AM
    Tacowin1013
    Same
  19. May 4, 2022 at 7:42 AM
    bbartol
    bbartol Well-Known Member
    Brandon
    Central Ohio
    2025 TRD Off-Road Premium in Terra
    Glad I found this thread, appreciate the info. Planning on doing a bunch of fluid refreshes as I hit 30k miles and this was on my list.
